Michael Gilligan | 30/08/2022 22:08:37 |
![]() 23121 forum posts 1360 photos | Posted by Steve Withnell on 30/08/2022 21:15:59:
If that motor is only 9 Watts as per label, why not just get a lamp dimmer from B&Q? . ‘cos lamp dimmers are [typically] not specified for inductive loads [ but there again … ] MichaelG. . https://pe2bz.philpem.me.uk/Comm01/-%20-%20Parts-NonActive/Lights/Dimmers-Control/lightdimmer.html Edited By Michael Gilligan on 30/08/2022 22:12:38 |
ŞABAN ÖZYAZGAN | 01/09/2022 06:54:31 |
![]() 4 forum posts 4 photos | Friends, I gave 220volt ac to the motor, but the motor did not run. When I give dc voltage with pwm and bridge diode, it makes a sound like DINNN. someone install a 24 VDC scooter motor to emco lathe.for you is this better.if I use a 24VDC scooter motor, can I control easy VDC with 3055. 6p2H; touchmove:FwuNnf; touchend:yfqBxc; touchcancel:JMtRjd; focus:AHmuwe; blur:O22p3e; contextmenu:mg9Pef;mlnRJb:fLiPzd" jscontroller="xzbRj" jsname="UsVyAb" lang="">6p2H; touchmove:FwuNnf; touchend:yfqBxc; touchcancel:JMtRjd; focus:AHmuwe; blur:O22p3e; contextmenu:mg9Pef;mlnRJb:fLiPzd" jscontroller="xzbRj" jsname="UsVyAb" lang=""> 6p2H; touchmove:FwuNnf; touchend:yfqBxc; touchcancel:JMtRjd; focus:AHmuwe; blur:O22p3e; contextmenu:mg9Pef;mlnRJb:fLiPzd" jscontroller="soHxf" jsname="kImuFf">6p2H; touchmove:FwuNnf; touchend:yfqBxc; touchcancel:JMtRjd; focus:AHmuwe; blur:O22p3e; contextmenu:mg9Pef;mlnRJb:fLiPzd" jscontroller="soHxf" jsname="kImuFf">content_copy 6p2H; touchmove:FwuNnf; touchend:yfqBxc; touchcancel:JMtRjd; focus:AHmuwe; blur:O22p3e; contextmenu:mg9Pef;mlnRJb:fLiPzd" jscontroller="soHxf" jsname="IOOiDc">6p2H; touchmove:FwuNnf; touchend:yfqBxc; touchcancel:JMtRjd; focus:AHmuwe; blur:O22p3e; contextmenu:mg9Pef;mlnRJb:fLiPzd" jscontroller="soHxf" jsname="IOOiDc"> 6p2H; touchmove:FwuNnf; touchend:yfqBxc; touchcancel:JMtRjd; focus:AHmuwe; blur:O22p3e; contextmenu:mg9Pef;mlnRJb:fLiPzd" jscontroller="soHxf" jsname="ymIaV">6p2H; touchmove:FwuNnf; touchend:yfqBxc; touchcancel:JMtRjd; focus:AHmuwe; blur:O22p3e; contextmenu:mg9Pef;mlnRJb:fLiPzd" jscontroller="soHxf" jsname="ymIaV">share |
Michael Gilligan | 01/09/2022 08:14:48 |
![]() 23121 forum posts 1360 photos | Posted by ŞABAN �ZYAZGAN on 01/09/2022 06:54:31:
Friends, I gave 220volt ac to the motor, but the motor did not run. When I give dc voltage with pwm and bridge diode … . That suggests that the motor itself is DC only, and that the bridge rectifier sometimes supplied with it **makes it useable [and presumably reversible] on AC Further investigation [and maybe dissection] required, methinks ! MichaelG. . ** see the photo in the post by Andy_G Edited By Michael Gilligan on 01/09/2022 08:21:54 |
SillyOldDuffer | 01/09/2022 09:52:13 |
10668 forum posts 2415 photos | Posted by Michael Gilligan on 01/09/2022 08:14:48:
Friends, I gave 220volt ac to the motor, but the motor did not run. When I give dc voltage with pwm and bridge diode … . That suggests that the motor itself is DC only, and that the bridge rectifier sometimes supplied with it **makes it useable [and presumably reversible] on AC Further investigation [and maybe dissection] required, methinks ! ...The motor may have been an unlucky choice for Şaban. Although labelled as an AC motor, it appears to be DC, a suspicion confirmed by it sometimes being supplied with a bridge rectifier. 9W output is small for a high-voltage motor, so my guess is the motor is normally used to drive the turntable of a microwave oven where rectified mains AC is an easy option. However, the need for high-voltage DC makes a variable power supply for speed control difficult. A Triac type is likely to vibrate the motor badly, and a PWM might be audible too. I'd change the motor for one that matched a low voltage DC controller but much depends on what Şaban has available. Quite cheap if the parts are in one's junk-box, pricey if they have to be bought new. Dave . |
