Member postings for ŞABAN ÖZYAZGAN
Here is a list of all the postings ŞABAN ÖZYAZGAN has made in our forums. Click on a thread name to jump to the thread.
Thread: speed control board
01/09/2022 06:54:31
Friends, I gave 220volt ac to the motor, but the motor did not run. When I give dc voltage with pwm and bridge diode, it makes a sound like DINNN. someone install a 24 VDC scooter motor to emco lathe.for you is this better.if I use a 24VDC scooter motor, can I control easy VDC with 3055.
30/08/2022 07:20:47
This motor is an universal motor.I want a cleaner DC voltage because the motor have loud. I have tried with drill battery(20 vdc) and the motor runs very quiet.
29/08/2022 10:14:42
img_3365.jpgimg_3368.jpgHello friends, I have a tiny homemade lathe. There is the following motor on it and I use this motor with dc voltage with pwm driver and bridge diode. But I want a cleaner dc voltage. Ready-made drivers are very expensive. Is there a circuit I can make? By the way, I do tube radio repair as a hobby.
Thread: SMALL LATHE
14/10/2021 12:28:15
Hi,friend I am a new member and from turkey.perhaps you can help me.I want to buy a small lathe( adept or wizard lathe).but There is n that lathes in turkey.Where can I buy thats lathes.
