What's it for
The Real Ron Skingley | 10/09/2021 16:05:35 |
46 forum posts 2 photos | Yep. But my 4 jaw won't reach, it's too small. |
old mart | 10/09/2021 16:07:57 |
4655 forum posts 304 photos | The alignment of the toolpost matters most if you are using a parting off tool which must be at right angles to the spindle axis. For most home use having exact location is optional as long as the toolpost can be tightened securely. John Haine's toolpost mod is the neatest and stiffest that I have seen, and it can be removed quickly if the compound is needed for a specific job. |
DiogenesII | 10/09/2021 16:22:27 |
859 forum posts 268 photos | Faceplates.. ..Just on the off-chance, you might as well give us the the spindle nose / flange dimensions.. ..even if nothing used turns up, you might at least find out if something new can still be obtained..? |
Mike Poole | 10/09/2021 17:38:31 |
![]() 3676 forum posts 82 photos | The hole in question has often had a pin with a knurled end on some of the lathes I have encountered. If using it as a setting aid then the fit of the tool post to the fixing bolt will need to be checked. Mike |
The Real Ron Skingley | 10/09/2021 17:47:42 |
46 forum posts 2 photos | Posted by DiogenesII on 10/09/2021 16:22:27:
Faceplates.. ..Just on the off-chance, you might as well give us the the spindle nose / flange dimensions.. ..even if nothing used turns up, you might at least find out if something new can still be obtained..? The chuck mounting is a bit of a pain. |
The Real Ron Skingley | 10/09/2021 18:04:53 |
46 forum posts 2 photos | I think I might be on the way. So now I've got a 7" faceplate that mounts in the four jaw chuck, and can be jiggled to get the flywheel running true to the inside edge of the rim. And take things very carefully. |
Howard Lewis | 10/09/2021 18:34:41 |
7227 forum posts 21 photos | And I thought that you were going to make a faceplate for your lathe. If you find the the Allen screws are a PITA, why not make nuts with a reduced shank (to fit into the counterbores ) and use studs instead of the Allen screws. The choice of spanner to use, or the size of hexagon, is up to you. Howard. |
The Real Ron Skingley | 10/09/2021 18:58:43 |
46 forum posts 2 photos | Well I could of course. |
lfoggy | 10/09/2021 19:31:36 |
![]() 231 forum posts 5 photos | This is my setup with a Bison QC toolpost and a rigid mount replacing the topslide. The hole is used for an extra M6 bolt to prevent movement. |
The Real Ron Skingley | 10/09/2021 20:01:47 |
46 forum posts 2 photos | That looks good. If only I could do away with the topslide I might do something similar. |
old mart | 10/09/2021 21:06:13 |
4655 forum posts 304 photos | Wow, 2 pictures of a properly thought out replacement for the compound slide in one thread, Ifoggy has one too! |
Martin Connelly | 11/09/2021 08:56:22 |
![]() 2549 forum posts 235 photos | This is my mod to my lathe with the compound removed. It's an old photo so does not show all the features. I removed the compound and fitted a T slot plate (3 slots) on top of the cross slide. Between the T plate and the tool holder block is an intermediate plate with machined in tenons that fit snugly into the slots. The tool post was aligned with the spindle centre of rotation, clamped down, rechecked for alignment then a drill was used through the index hole to drill into the intermediate block about 6mm (plus the cone from the drill tip). I turned a snug fitting pin with a small taper on the tip and a knurled top. I can remove the T slot plate and refit the compound and 4 way tool post if I ever feel the need to. Martin C |
The Real Ron Skingley | 11/09/2021 11:26:08 |
46 forum posts 2 photos | That's a nice mod Martin. Unfortunately I can't do away with the topslide. |
The Real Ron Skingley | 13/09/2021 12:01:12 |
46 forum posts 2 photos | Posted by JasonB on 10/09/2021 16:03:11:
Victoria flywheel should be OK held with a 4 jaw gripping inside the rim. I hardly ever use a faceplate for turning flywheels finding the 4-jaw much better. 4 jaw not big enough to get to the rim. |
John Haine | 13/09/2021 12:09:40 |
5563 forum posts 322 photos | Posted by The Real Ron Skingley on 13/09/2021 12:01:12:
Victoria flywheel should be OK held with a 4 jaw gripping inside the rim. I hardly ever use a faceplate for turning flywheels finding the 4-jaw much better. 4 jaw not big enough to get to the rim. Reverse the jaws and grip from the inside? |
The Real Ron Skingley | 13/09/2021 12:11:22 |
46 forum posts 2 photos | Yep. Won't reach. |
The Real Ron Skingley | 13/09/2021 12:20:55 |
46 forum posts 2 photos | OK, to be fair, I've just tried it again, and it is possible, just. But VERY dodgy. Literally another quarter turn on the key and the jaw falls out. |
The Real Ron Skingley | 13/09/2021 13:03:03 |
46 forum posts 2 photos | Other problems with this is, 4 jaws and 6 spokes. |
