noel shelley | 28/06/2021 10:15:58 |
2308 forum posts 33 photos | I have put holes in ball bearings by using copper wire and a spark eroder. Noel. |
John Haine | 28/06/2021 12:07:45 |
5563 forum posts 322 photos | Something is trying to tell you that a spherical tip is too hard. Why spherical anyway? For a probe concentricity is needed and that is easier if you turn the tip cylindrical. |
gerry madden | 01/07/2021 00:17:46 |
331 forum posts 156 photos | A metallurgist colleague advised me that for 'perfect' annealing of 100Cr6 ball steel, the cooling-down process should theoretically take 25 mins. Since this long time period would only result in more scale formation (which I would then have to remove and mess up the diameter in the process) I decided to experiment with the carbide drill today. First I used a 4mm carbide spotting drill. Strangely this really didn't seem to make an impression. Well in truth it made a pin-prick of a mark but it didn't seem to want to go any further. I checked the point of the drill under the microscope and didn't see any obvious damage. Expecting to get another poor result I then popped my new 1.5mm carbide drill in a collet and tried again. Immediately I could tell it was cutting. I ran the mill at 3000RPM and just maintained a light finger force on the quill lever. After about 10 minutes it was through. Perhaps I could have done it quicker by applying more force but these drills are easily broken so I was happy to take my time. The hole quality was superb too. I didn't need this but its always nice to have. So that was the trial. As was suggested I held the ball in a collet. My centre was found by eye but I have to admit now that it wasn't perfect. What I plan to do for the next time around is drill a 'vee' socket in a bit of aluminium and then glue a ball into this. If I keep the X and Y controls locked that should keep me on the perfect centre for drilling the ball. Thanks to all ideas contributors. Gerry. |
gerry madden | 14/07/2021 12:10:23 |
331 forum posts 156 photos | Thanks all for your thoughts and guidance on how to drill holes in balls. After some trial and error I think I have perfected the art a little further and just to help the next one along that wants to do something similar here is the technique that seemed to work well for me. 1) Hold a small piece of a relatively soft material like aluminium in the mill vice. Check the vice is secure and the X and Y slides are locked solidly. 2) Using a conventional centre-drill make a hole in the material. Select a size of centre drill that will ensure that the ball doesn't rest on the entrance to the cylindrical portion of the hole. The ball will be much more stable when it sits in the 'V' portion. 3) Put the ball in the hole then, protecting it with a piece of soft metal to prevent surface damage, give the ball a bit a bit of a thump with a hammer. This will plastically deform the soft seating material and increase the area of contact of the ball in its 'socket'. 4) Remove the ball and put a little super-glue on the seating. Replace the ball and press it into its socket for about 30m seconds. 5) If you still haven't moved those X and Y slides the quill will still be completely concentric with the ball that you want to drill. Its now just a case of drilling with your carbide drill. But one needs to be a little bit 'sensitive' to ensure that the drill doesn't wander off the centre due to other 2nd order excentricities such as chuck runout etc. To help, what I did was remove the strong return spring in my Wabeco mill's quill. Once this was out the quill will drop slowly with only viscous drag under its own weight. The quill clamp should of course be adjusted to remove as much clearance as possible but too much that is stops the quill from moving. 6) Let the drill run for about 1 minute with only 'quill weight' on the drill. Once it's made a small indent you can safely begin to apply finger pressure on the quill arm and begin to cut at a much faster rate. (This is enough to get through a 3mm ball in about 45 seconds running at 3000RPM. ) 7) I couldn't tell if there was much heat being developed in the cut but I dont think so. Quite honestly though with such small parts its difficult to tell what's going on anywhere ! What one does find though is debris builds up and obscures the workpiece so I stopped every so often and cleaned things up with a squirt of WD40. 8) When the drill is through the ball it very kindly pulls the ball out of the socket for you. All you need to do then is slide the ball off the drill and drop it in some acetone to dissolve the remaining hardened glue. 9) If you haven't loaded up the quill too much you will have no chipping on the surface of the ball at break out. You will also have a very high quality hole. For some strange reason the hole is always very slightly tighter on one end. I haven't worked out whether this occurs at the entrance or exit end but its a very small amount and not something that should worry most people. With this technique I feel I could drill holes in bearing balls all day long, completely concentrically and without any surprises or broken drills, and probably on an even smaller scale too. I hope others find this useful. Gerry |
Michael Gilligan | 14/07/2021 12:34:52 |
![]() 23121 forum posts 1360 photos | Nice description, Gerry MichaelG. |
