Clarke CL500M longitudinal feed screw
john halfpenny04/01/2021 19:57:54
314 forum posts
28 photos
Google images has plenty of shots of the standard bent tin guard - which can easily be extended or given a telescopic section. The standard length guard works quite well.
martin perman09/01/2021 20:43:26
2095 forum posts
75 photos
Stuart,
As promised pictures of the guard for the lead screw, very basic but it does the job.
Hope this helps,
Martin P
Stuart Cox 309/01/2021 21:44:33
130 forum posts
25 photos
Posted by martin perman on 09/01/2021 20:43:26:
Stuart,
Hope this helps,
Martin P
Thanks Martin...... just trying to figure out what you've done?
martin perman09/01/2021 21:51:34
2095 forum posts
75 photos
How do you mean, this is the underside of the traverse lead screw, showing the guard from both sides of the traverse which also shows how its mounted.
Martin P
Peter Seymour-Howell09/01/2021 21:59:23
125 forum posts
25 photos
Hi Stuart
I basically have the same lathe although under the Warco badge, I've had mine since 1998 and they are very capable machines. As noted above the cross slide works on the same priciple, ie you tighten the bolt to take up any slack. You do need to keep them oiled just like any other lathe. My own cross slide 8s getting a little worn now although Warco sell the parts. I have found the dials a fraction out but a DRO can take car of that.
As Howard said above, our forebears produced excellent work on equipment less able than these humble machines. They are very rigid and can produce excellent results, they also have double the capacity of a Myford in turning.
Pete
Stuart Cox 309/01/2021 22:28:44
130 forum posts
25 photos
Posted by martin perman on 09/01/2021 21:51:34:
Martin P
I'l have look at my machine tomorrow, I'm sure it will make sense.
Thanks Martin, much appreciated
Stuart
