pgk pgk | 01/08/2020 10:05:59 |
2661 forum posts 294 photos | A ply board top and bottom, multiple bolts and compress the 6" down to 4" total. Cut around the edges and you have new nice firm cushions....<exits stage left> pgk |
mechman48 | 01/08/2020 11:24:32 |
![]() 2947 forum posts 468 photos | As I understand it the foam ,as used in furniture, gives off cyanide fumes when set alight, would this not apply to hot wire cutting... just remembering Fire brigade videos of home safety. Play safe & spend a few shekels on new cushions. George. |
Fowlers Fury | 01/08/2020 12:08:08 |
![]() 446 forum posts 88 photos | Re: " As I understand it the foam ,as used in furniture, gives off cyanide fumes when set alight, " It's a complex issue and drifts way off topic but in essence:- Relevance to model engineering? Very little I guess unless you insulate the loco's firebox with flex PU or feathers ! |
Packmule | 01/08/2020 16:26:23 |
133 forum posts 6 photos | Hi Duncan, You've two choices really. First take to a foam converter if there's one near by , probably only charge you a tenner to cut or if you've access to a band saw cut in to strips and rejoin using spray glue. when finished cover with 2oz of 4oz polyester wadding (Dacron). Remember to leave the foam 1" bigger on all dimensions than the actual cover or the cover will slip round . The foam HAS to force against the cover. Regards, Bob . 40 years as upholsterer |
norman valentine | 01/08/2020 17:19:18 |
280 forum posts 40 photos | Bit late in the day to advise against hot wire cutting foam but if you do it you will be left with a horrible sticky surface. It will cut with a band saw but a band knife is better.
Cyril Bonnett | 01/08/2020 22:51:01 |
250 forum posts 1 photos | I worked for years as an upholsterer/ furniture restorer/ part time fisherman and radio controlled aircraft flyer, just two of us. We cut foam of all sizes with a Russell Hobbs electric carving knife and a 14 inch long thin butchers carving knife, one that was used for slicing cooked meat. To do what you want to do we would cut all around the block with the electric knife and then reach in to finish cutting with the long knife. We tried using an hot wire but found it quicker for us using the knives. If the sun was shining and the mates wife was out working we stopped work and went flying or fishing, great life. |
Packmule | 02/08/2020 12:52:12 |
133 forum posts 6 photos | I agree with Cyril you can cut it with a electric carving knife but its far from easy keeping the blade straight and flat and the result is far from perfect, and depending on the fabric on your furniture it will show, especially on leather. |
