collet chuck
Brian G | 26/09/2019 14:45:32 |
912 forum posts 40 photos | Posted by JasonB on 26/09/2019 14:08:12:
Careful Paul, you will then be wanting a second set of collets for when you want to hold work while cutting with a cutter of the same diameter That's where starting with a cheap set comes in handy. They may not be as accurate, but they still hold turned parts in collet block without marking. Brian |
john brown 17 | 27/09/2019 13:53:50 |
135 forum posts 3 photos | Well with thanks to the other members on here and the great deal of help from jason who has gone out of his way with his help ,am now sorted out ,and orders have been placed regards to all john |
Paul Lousick | 27/09/2019 14:05:25 |
2276 forum posts 801 photos | Even the cheaper collets are more accurate than an older 3 jaw chuck. Jaws could be ground to make them run on centre but if the scroll is worn, it will only work for the specific diameter that you ground the jaws. Paul. |
john brown 17 | 27/09/2019 16:11:30 |
135 forum posts 3 photos | Mind from what you read ,some of the cheaper 3 jaw chucks are not that great,After placing my order l thought that the mill could do with a clean up etc,then it stuck me the new collet chuck has a m16 thread for draw bar,nope a m16 will not go down the spindle to tight ,after sulking and moaning an why did l not check before buying ,so have made a plug with the m16 thread on it then a m12 thread in to that,when the chuck comes and its as good as they say ,l will remove the plug an loctie it in,oh well it will turn out ok in the end. john |
