Lainchy | 10/09/2019 15:38:01 |
![]() 273 forum posts 103 photos | Just out of interest John, Have you looked at Tenacious tape? It's usually used for tent / inflatable repair. I'd be interested in seeing what model you are looking at hinging
Ian |
JasonB | 10/09/2019 15:42:10 |
![]() 25215 forum posts 3105 photos 1 articles | I thought one of your requirements was for a weather proof tape, I assume the model also needs to be weather proof as hardboard is not known for being weather resistant even in the oil tempered form so you may need to think again. |
old mart | 10/09/2019 16:58:47 |
4655 forum posts 304 photos | The difficulty is not just the adhesive being weather proof, but the flexibility required. |
Andrew Steward | 02/10/2019 10:07:47 |
18 forum posts | I'm the technical director of a company that makes pressure sensitive adhesives, including those for automotive applications. The problem with any PSA is that it will be prone to creep. If there is a constant pull on the adhesive it will eventually fail. The time frame over which this will occur will depend on the strength of the pull as well as the adhesive. Aluminium foil could be held on with pretty much any permanent PSA as it will provide very little strain. Baking it in an oven will completely change the properties. PSA adhesives will never set. I would be happy to advise if you PM me. |
