Morse taper spec.
Michael Gilligan26/05/2018 15:18:40
23121 forum posts
1360 photos
Posted by Neil Lickfold on 26/05/2018 13:24:57:
Posted by Georgineer on 26/05/2018 12:23:26:
I read somewhere, a long time ago and I can't remember where, that the angles were purposely made different so that male and female tapers of different sizes couldn't be wedged together with resulting difficulties in separating them.
George
This is correct. I can't find the reference ...
Footnote 47, on p57, here [?] :
https://books.google.co.uk/books?id=F8jtCwAAQBAJ&pg=PA57&lpg=PA57&dq=morse+taper,+metrology&source=bl&ots=BqKPWUOhBN&sig=BYWM2lRezho2_e4A3oCWjKgnD9U&hl=en&sa=X&ved=2ahUKEwit5fDvxqPbAhWEAcAKHTuuARMQ6AEwAnoECAIQAQ#v=onepage&q=morse%20taper%2C%20metrology&f=false
Neil Wyatt26/05/2018 18:51:06
19226 forum posts
749 photos
86 articles
George
Disproven easily, I'm afraid - try fitting MT tapers in the wrong socket. Either they won't fit in or they will rattle like a stick in a bucket - the size differences are too large.
And if they did fit, would they be more likely to stick then the matching taper?
The B-series chuck tapers are interesting.
Georgineer26/05/2018 22:31:23
652 forum posts
33 photos
Pete - Jarno tapers weren't published until 25-odd years after Morse tapers, and we know that engineering moved on a lot in that time. Besides, who can say what bees designers have in their bonnets? I know I have made allowances in designs for things which turned out not to be a problem, and I'm sure a lot of others on this forum have done exactly the same.
Michael - Interesting footnote, but it doesn't cover the reasons for the difference
Neil - It looks as though your comment proves the point, as in neither case does the wrong Morse taper cause problems by jamming...
George
John Haine27/05/2018 06:32:44
5563 forum posts
322 photos
Posted by richardandtracy on 26/05/2018 12:09:02:
It would only need one setup on the machine for different tapers, though. Many machines have different tapers at the head and tailstock, and need to make bits for both. It would make it easier to use the same setup.
Richard.
That's true if you decide to have a taper-making session, but in my experience I either have to make one for the tailstock (MT2) or headstock (MT4, shortened). Anyway, it's just a different set of parameters for the taper turning wizard!
