soluble
Robin | 14/10/2017 12:28:54 |
![]() 678 forum posts | In the suds pump on my mill I use whatever soluble oil is cheapest. Sometimes I use a brush in a tin of paraffin for cast iron even though I was taught to cut it dry. For drilling, generous blobs from a squeezy bottle of Rocol RTD |
Jon | 14/10/2017 22:49:01 |
1001 forum posts 49 photos | Depends on usage and whether a diyer or semi pro. Either way i wouldnt go mister absolutely useless for above basic lathe work, generally ok in limited fashion for milling. The aim is to keep job and or cutter cool and provide a little lubrication, cutters last longer and should get a better finish. Misters for me dont provide enough cooling, in no time developing steam but far better than running dry. My main tanks running a bit weak now not long finished off 25ltrs of Castrol about 18 months to two years, need to get some more or an alternative.
If really tight, make your own.
Neil Lickfold | 15/10/2017 11:36:11 |
1025 forum posts 204 photos | If you are buying a soluble cutting fluid, I buy the one that is chlorine free. Mainluy because from time to time I do turn and dril Titanium, either grade 2 or grade 5. On most things I just use the rice bran oil in a spray can. Was using canola oil but it does make a mess on the tools after a while. nasty to clean off too. If I am reaming holes and need a really nice sized hole off the reamer, I then use a mixture with castor oil in it. It will allow a hole to be reamed so close to the reamers size that the reamer becomes hard to pit back into the hole. I don't have a flood coolant system, only a suds botle for when needed. Neil |
