Gear drive problem
Neil Wyatt27/05/2017 10:45:02
19226 forum posts
749 photos
86 articles
No doubt the question was set by the engineer brother of the literature professor who set the Shakespeare paper...
www.theguardian.com/education/2017/may/26/error-gcse-paper-leads-to-apology-ocr-exam-board-romeo-and-juliet-tybalt-shakespeare
duncan webster27/05/2017 10:55:55
5307 forum posts
83 photos
Posted by Neil Wyatt on 27/05/2017 10:45:02:
I love the way a spokesperson blames a typo. Getting one or 2 letters wrong is a typo, writing Capulet when you meant Montague is a cock up, which should have been spotted in the checking process, or don't we bother with those any more.
Michael Gilligan27/05/2017 11:06:05
23121 forum posts
1360 photos
Posted by duncan webster on 27/05/2017 10:55:55:
... I love the way a spokesperson blames a typo. Getting one or 2 letters wrong is a typo, writing Capulet when you meant Montague is a cock up, which should have been spotted in the checking process, or don't we bother with those any more.
An interesting interpretation of the spokesperson's statement, Duncan
... I read it rather differently:
[quote, with my added emphasis]
Typos are easy to make, but a mistake of this sort is rather unforgivable
[/quote]
Hopper27/05/2017 11:14:19
7881 forum posts
397 photos
Oh oh. Stones, glass houses, pots, kettles, black etc etc.
It was not the spokesperson who called it a typo. The spokesperson quite correctly called it an error. In fact nobody called it a typo. A language teacher, speaking out against the exam board, said "Typos are easy to make, but a mistake of this sort is rather unforgivable" implying it is a different sort of mistake from a typo.
See how easily these things can happen? And, no we don't bother with the checking process any more. wink
Martin Connelly27/05/2017 11:48:31
2549 forum posts
235 photos
Duncan, turbochargers for boat, train or ship engines go to multi megawatts. Same type, just a different size.
Martin C
Edited By Martin Connelly on 27/05/2017 11:50:10
duncan webster27/05/2017 20:49:40
5307 forum posts
83 photos
Just shows how easy it is to make a complete twit of yourself by not reading it properly. Perhaps I'll apply for a job setting English Lit exams!
Edited By duncan webster on 27/05/2017 23:52:52
Hopper29/05/2017 09:28:53
7881 forum posts
397 photos
Posted by duncan webster on 27/05/2017 20:49:40:
LOL, well you could hardly do worse than the current mob responsible for the Capulet crock up.
Howard Lewis30/05/2017 18:38:02
7227 forum posts
21 photos
The original question appeared to call for an overall gear ratio of 1:12; resulting, in speed being reduced by a factor of 12, and theoretically, in an increase of torque by a factor of 12. Based on the 10:36 first stage, my calculations agree with everyone else who cited a 12T pinion to drive the 40T gear in the second stage.
If the turbine is required to produce 1 Mw then doubling the diameter of the rotor, would, presumably still result in an output of 1Mw, but at a quarter of the original speed? I can only share the fears of those who believe that maintaining the original speed would result in failure from overspeed. If failure did not occur, and the pressure drop across the turbine was the same in both cases, one would expect that, theoretically, the output should become 4Mw?
Turbochargers, IF the turbine and compressor wheels are small diameter, can run at very high speeds (over 100,000 rpm for the sizes currently employed on small petrol (gasolene) or diesel engines.
How do you measure these speeds?
By magnetising the nut retaining the compressor wheel, and having a sensing coil, with pole pieces surrounding the compressor casing, with resulting voltage displayed on an osilloscope. A signal generator trace displayed on the same screen, and synchronised will allow the speed to be calculated from the frequency. Alternatively, the compressor nut is painted black on one half, and white on the other, to allow the speed to be sensed optically, and the pulses counted electronically.
The original gas turbines originally used in jet aircraft were limited by the creep properties, at high temperature, of the materials available, for the turbine rotors. Initially, this was circa 1,000'C Hence the development, by Henry Wiggin, of Nickel alloys of the Nimonic type which increased the ability to withstand high temperature. We now have Rolls- Royce growing a turbine blade as a single crystal, which has no interstices, (and with internal cooling ducts) for the current ultimate in high temperature creep resistance.
At various times compound engines have been developed which geared an exhaust turbine to an internal combustion engine. The engine was acting as a gas producer to feed the turbine. Indeed experiments have been carried out where a reciprocating engine, or a free piston engine, was purely used as a gas producer to drive the turbine, to which it was not coupled.
Currently, these alternatives do not seem to have not proved to be viable for whatever reason, (weight, fuel economy, complication, cost?)
