Think I have burnt out my lathe motor
Les Jones 118/08/2016 19:47:38
2292 forum posts
159 photos
Hi Dave,
If you post some pictures of the speed controller board then someone on the forum may recognise it.
Les.
Dave Harding 118/08/2016 20:01:07
148 forum posts
4 photos
Thanks I will remove the boards and go from there. The wiring diagram is useless.
Dave Harding 119/08/2016 19:28:59
148 forum posts
4 photos
I contacted SPG the company I bought it from. If I send the boards to them they will test them and advise. Sounds fair enough to me. At least I will know for definite if one or both are goosed. Before I start throwing money at it. It sounds like they keep spares.
Edited By Dave Harding 1 on 19/08/2016 19:29:41
Dave Harding 123/06/2017 20:34:54
148 forum posts
4 photos
Up date:
In the end I think it was more to do with the wiring in my workshop. I up dated the electrics in the mean time I purchased an inverter a new motor and a speed controller. The lathe now runs like a sewing machine. I binned the old motor and all the Chinese electrics.
Mark Fleetwood13/08/2017 16:00:15
1 forum posts
Hi , i have the same problem ,could you tell me what motor and gear you used please ? ta ,Mark
larry Phelan13/08/2017 21:03:13
544 forum posts
17 photos
You are wrong Pete,
It was the butler,with the lead pipe !
There is a lot to be said for a simple induction motor with a push button switch and no gimmics,and let a gearbox or a beltdrive take care of the speeds. I HATE those vati speed plastic board machines. They are a pain-in-the-arse.
Dave Harding 113/08/2017 21:52:24
148 forum posts
4 photos
I bought a package from transwave. An inverter a motor and a speed controller. It was not difficult to fit and it works a treat.
Neil Wyatt13/08/2017 22:16:25
19226 forum posts
749 photos
86 articles
Very similar to a Chester DB8VS as well although the name 2109 suggests it may be between a DB8 and a DB10...
There's quite a family of these 'larger than mini lathes' although the DB7 isn't practically greatly different from the usual Mini-lathe.
I don't think the board from a C2/3 would be ok for this as it's a rather bigger. But I thought it was from SPG who do carry spares?
Edit - just read the last post properly - that's exactly what I did with my mini lathe in the end.
Edited By Neil Wyatt on 13/08/2017 22:17:33
Dave Harding 113/08/2017 22:34:43
148 forum posts
4 photos
The inverter package has transformed my lathe its the best thing I ever did. It runs like a sewing machine.
