first run
Michael Gilligan | 29/06/2016 19:33:13 |
![]() 23121 forum posts 1360 photos | Posted by Mike Bondarczuk on 29/06/2016 17:03:58:
Reading through the last few messages regarding the wobbling effect I do now recall that after uploading onto YouTube an option to activate the "steadying software" was accepted and in hindsight I think that this was a bad move as the original has no visible wobble, apart from the shaky human stand "me". . Mike, Thanks ... You have encouraged me to have a look Here is a short explanatory video, but there are also quite a few very negative discussions! ... First impression is it's "too clever by half" and best left alone. MichaelG. |
Mark Davies 4 | 23/01/2022 09:06:11 |
![]() 11 forum posts | Hi all, Im currently half way thro this project and was wondering what peoples thoughts were on the fixing i should use, eg studding with nuts or hex headed bolts. Think whatever i decide i will make them from brass. thanks. |
JasonB | 23/01/2022 10:17:57 |
![]() 25215 forum posts 3105 photos 1 articles | Studs and nuts always look better and replicate the full size practice though I would go for steel myself. You can get some nice small hex steel nuts which look better than the usual mass produced items |
Jim Nic | 23/01/2022 12:20:16 |
![]() 406 forum posts 235 photos | Definitely studs and nuts, usually steel. When I say studs, I actually use cut down bolts or threaded rod rather than the correct form of stud with a plain portion. BA sizes available from EKP supplies.
Jim
Edited By Jim Nic on 23/01/2022 12:22:10 |
Mark Davies 4 | 24/01/2022 21:58:16 |
![]() 11 forum posts | Thanks very much for the replies gents. Studs n nuts it is. thanks again. Mark |
JasonB | 25/01/2022 06:58:24 |
![]() 25215 forum posts 3105 photos 1 articles | You may find standard metric nuts a bit large but you can get smaller hex from Polly engineering or GHW in Germany, I use theirs on all my own design models which are metric. |
Mark Davies 4 | 05/02/2022 03:22:38 |
![]() 11 forum posts | Thanks for the help about studs n nuts guys. does the height of the centre of the cylinder, the slide and the crank shaft have to be the same height exactly from the base. I assume they do, but drawing is vauge on this and was after a bit of valued knowledge please. thankyou. |
JasonB | 05/02/2022 07:04:08 |
![]() 25215 forum posts 3105 photos 1 articles | The cross head guide bars and the cylinder certainly need to be the same height and in line. Ideally the crankshaft bearings too but there are a few engines about with off set crankshafts, shaft should be at 90deg to cylinder ctr line. I'm not sure what the latest drawings show but the early set I have will need some adjustment to the heights so they are all the same. Edited By JasonB on 05/02/2022 07:43:17 |
Mark Davies 4 | 05/02/2022 09:22:40 |
![]() 11 forum posts | Brilliant. Thats what i thought as the dimensions were all in the same ball park. Thankyou. Jason. is there a way i can set it up so i get a notification on my phone if my post gets a reply?
cheers. Take care. |
JasonB | 05/02/2022 10:06:35 |
![]() 25215 forum posts 3105 photos 1 articles | Right at the bottom of a thread below the add posting button you will find "bookmark this thread" if you click that it will go to your bookmarks list accessed from the green bar along the top of the page and you will also get e-mail notification when a post is added to any bookmarked threads. |
Mark Davies 4 | 05/02/2022 10:45:52 |
![]() 11 forum posts | Brilliant. Thankyou jason. |
Mark Davies 4 | 17/02/2022 19:19:59 |
![]() 11 forum posts | Hi folks, im about to start to assemble my parts for this engine. I know that i have to put gland packing behind gland on the valve chest , but does any go behind the cylinder hex headed gland type fitting that the piston rod goes through. cheers in advance for any help. |
JasonB | 17/02/2022 19:29:03 |
![]() 25215 forum posts 3105 photos 1 articles | Yes |
Mark Davies 4 | 17/02/2022 19:37:01 |
![]() 11 forum posts | Cheers jason. I really wanna get on with this but i have so little time at the mo, but getting there slowly. Rveryones help is very much appreciated. |
Stewart Hart | 18/02/2022 08:03:24 |
![]() 674 forum posts 357 photos | Hi Gents Only just found this thread Mike/Jim Your engines look great it always gives me a great buzz when I see one completed and running. I'm extremely pleased that you enjoyed building it. Jim I like how you've added the valve and governor and piped it for steam have you ever run it on steam ?. I know that one of my grasshoppers has been run on steam successfully but I've never heard of the horizontal being run on steam. Jason is spot on regarding the use of studs and nut sizes, I just used standard M3 nuts with studs as they are easy to get. When using studs the trick is to get them all the same length the easy way to do this is to assemble the parts with two nuts then file down the stud level with the top nuts, remove the top nut and you've got the same length of stud standing proud making things look nice a neat. As an aside I'm just completing a book for Crowood press on building this trilogy of engines, hopefully it will be out sometime this year: so keep a look out for it. Stay Well Stew |
Jim Nic | 18/02/2022 12:03:36 |
![]() 406 forum posts 235 photos | Hi Stew Thanks for the comment. I like making your designs and always try to do justice to them. I have never run any of my engines on steam; I know it would be a good thing to do but many of my earlier efforts have been assembled using adhesive where silver solder would be required for steam. Maybe one day a boiler will come to the top of the "round tuitt" list. Just for interest here is a pic of my "Stew Hart Collection". Jim |
Stewart Hart | 18/02/2022 13:50:18 |
![]() 674 forum posts 357 photos | Wow Jim that's an impressive collection of engines nice to see it includes the popcorn engine and the over crank engine, the over crank was the first I designed and built and submitted for publishing. You must do the the Grasshopper next to complete the trilogy Ok you've shown me yours I'll show you mine Thanks for your comments and interest in my designs Stew |
