drying out of flux / prefluxing of silver solder.
Tim Stevens13/01/2016 17:05:46
1779 forum posts
1 photos
A further idea which may help is to use charcoal as a packing around the part to be soldered. Heat from the torch will light the charcoal so it becomes as it were a negative insulator - adding its own heat, not taking it away. A further advantage is that the extra CO from the hot charcoal provides a reducing atmosphere, easing the job of the flux.
Ordinary barbeque charcoal is good, or collect the black lumps of residue from a wood stove. The only extra to remember is to quench the charcoal thoroughly with water or it will continue to glow quietly and might set the shed on fire.
Regards, Tim
julian atkins13/01/2016 18:28:31
1285 forum posts
353 photos
hi Tim,
you can use charcoal if you want smoking away and ruining the job. i will stick to my thermalite blocks which dont give off smoke or fumes. i also do all my silver soldering indoors. i dont want a BBQ in my workshop!
cheers,
julian
Bill Dawes13/01/2016 18:45:31
605 forum posts
Interested to see Julian's comment on his use of a 2943 nozzle for boiler work, I have struggled with a 3525 (10.3kw) on my Emma Victoria boiler (not that I have got very far with that in 2015, 2016 will the year of great progress!!) As they say I am 3 years into a 3 year project, well that was my original expectation.
So now have a 2943, not yet put it to the test but Julians comment gives me new heart, accepting Julian's greater expertise is also a big factor.
Got as far as cutting the boiler for the firebox and one failed attempt at the silver soldering on the extension piece (with the 3525 nozzle) a quick light up of the 2943 shows a fieresome flame.
I have high expectations of this new nozzle as I have always thought I took all the right care in preparation but most time ended in frustration( apart from small components) the problem I seem to struggle with is complying with the 'rule' of keeping the flame away from the flux/solder,
Bill D.
CotswoldsPhil13/01/2016 19:32:18
196 forum posts
112 photos
Posted by Bill Dawes on 13/01/2016 18:45:31:.
.........I seem to struggle with is complying with the 'rule' of keeping the flame away from the flux/solder,
Bill D.
Is it really possible, or necessary, to keep the flame away from the flux? Keith's mantra (Cup-Alloys) about letting the work melt the silver solder once the flux has gone clear worked very well for me on my test pieces, moving the flame away to apply the silver solder. In Julian's photo of the fluxed up back-head nestling in the Thermalite blocks, keeping the flame off the flux would be impossible.
Phil
Edited By CotswoldsPhil on 13/01/2016 19:42:55
julian atkins13/01/2016 19:57:34
1285 forum posts
353 photos
hi phil,
keith never stated keep the flame away from the flux. the flux doesnt mind being in the flame. it does it no harm. what you must not do, as keith advises, is let the stick of silver solder melt in the flame. the silver solder must be melted by the metal being at a high enough temperature otherwise you get bad joints. in boiler work it is particularly important to have good joints.
keith has recently done a series of articles in EIM on silver soldering which i can thoroughly recommend.
it is not difficult in miniature loco boiler work letting the work get up to heat with propane and then applying the silver solder of correct grade with the correct grade of flux. i would agree that with some stages of boiler work very careful set ups are required and constant attention to the flame and where it is directed, but after the first few 'easy' joints on a boiler these things become intuitive. there are a few tricks for various awkward set ups in making boilers.
i am afraid i have no experience of oxy-acetylene silver soldering where quite different techniques and set ups are required, plus you have to be very careful on some designs to avoid localised heating and cracking of throatplate to boiler barrel joints previously done.
hi bill,
your Emma Victoria boiler is smaller than the Don Young Railmotor No.1 boiler i started when aged 18 with a 5 pint paraffin blowlamp. if you read Don Young's construction series for his Railmotor boilers in ME 1968 i think you will find it an excellent guide and one of the best, except the use of coke and easyflow flux. if you want all silver soldered stays i can give a bit of advice for doing this with propane.
always happy to help via PM or on here if you have any problems.
the cost of commercial boilers is very great and the savings by doing it yourself ought to encourage more to 'have a go'.
cheers,
julian
CotswoldsPhil13/01/2016 20:19:25
196 forum posts
112 photos
Hi Julian,
All very encouraging, I think I need to obtain a Sievert 2943; the largest I have at the moment is a 2942 at 26kw. Would you recommend a long neck tube?
It was Bill who mentioned keeping the flame off the flux. I was looking to obtain an informed response which you supplied, thank you. I have Keith's articles (from EIM) which are very informative.
Phil
duncan webster13/01/2016 21:34:13
5307 forum posts
83 photos
To echo CuP alloys comment, I once attended a talk given by them where he stated you don't need to clean before silver soldering. When I got home I found a bit of copper that had been buried in the garden for over a year, cut 2 bits, fluxed, heated, solder ran beautifully.Would I do this on a boiler, probably not, cleaning first might not be necessary, but it feels a lot better and you'd feel an awful twit if it didn't run.
julian atkins13/01/2016 22:53:23
1285 forum posts
353 photos
hi duncan,
i am not sure i understand the point you made, but i agree making miniature loco boilers requires a lot of 'know how' which to the best of my knowledge hasnt been thoroughly described in ME for very many years. those of us taught by old hands doesnt seem to have become accepted knowledge in many clubs especially with propane. and many mis-interpret LBSC's descriptions of 'braze' ie sifbronze the barrel to throatplate joints for which they were designed with often awful expensive results.
i am a great believer in silver soldered double flanged or single flanged throatplate to barrel joints silver soldered. you will never see such joints on LBSC's designs because he brazed them with sifbronze with his 'Alda' oxy-acetylene equipment which was well ahead of it's time and what most model engineers could not do with ordinary set ups in those days.
there have been many comments over many years that boiler designs supplied by the trade and ME ought to be updated. nothing has happened, leading to many tyros into a myriad of pitfalls and potential costly disasters none of their own making.
i know of at least 3 3.5"g Britannia LBSC boilers that have had cracked throatplate to barrel seams because the joint has been silver soldered as opposed to sifbronzed as per the original design. an extremely disheartening and costly experience for those involved.
cheers,
julian
Bill Dawes14/01/2016 00:12:59
605 forum posts
Hi Julian, I have read many times in the past about the danger of overheating the flux so probably misunderstood that to mean not having the flame directly on it. Would I be correct though in saying it is best to heat up the job keeping the flame away from the flux in early stages where possible. I realise every job varies, in your photo example I guess it would be near impossible to do that with so many parts to be soldered close together. I have seen videos with the flame definitely on the rod but I suppose that is ok once the parent metal is up to temperature.
What diameter rod would you suggest?, I am thinking of 1.5mm.
I propose to use HT5 flux everywhere, do you think that is ok?
Do you use two torches on boilers?
Bill
julian atkins14/01/2016 01:18:29
1285 forum posts
353 photos
hi bill,
CupAlloys HT5 flux is excellent for boiler work as identical to Thessco F or Tenacity 4A. different brand names, same product.
if you heat up the job within a reasonable timescale you have no worries about heating up the flux. that is what it is supposed to do with heat.
for the currently available non cadmium stuff ie J&M silverflo 55 or CupAlloys equivalent you would be better off with a larger diameter than 1.5mm for most boiler work ie plain joints. just my personal preference here, and others may disagree. 1.5mm is easily caught in the flame plus waves about too much with the sweat pouring and nerves on boiler work! i would use 1mm for rings around the tubes when silver soldering to the inner wrapper and tubeplate already done. i do however probably over do the silver solder - but this is better IMHO than being too mean. again just my personal opinion .
cheers,
julian
Bill Dawes14/01/2016 13:13:47
605 forum posts
Hi Julian, thank you for response, I think I will go for 2mm then on joints, I have wondered if more than 1.5mm would be better as it does, as you say, wander about.
Interested you talk about sweat and nerves, I imagined someone that has done a lot of it would just calmly sail through the process, everything heating up quickly and solder running freely etc etc.Makes me feel a bit better about it.
Full up with a stinking cold at the moment so my new year resolution to get cracking on my build has already lost a few days. However now encouraged, I will make my first job soldering on the firebox extension, my confidence for the whole year ahead will depend on this being a success, I have high hopes of the right size burner and encouraging advice will see a new dawn in my silver soldering abilities!!!!.
(having had a lifetime in engineering from the age of 15 to now 74 years old I think it is about time I got this sorted)
Many thanks.
Bill
CotswoldsPhil14/01/2016 14:10:36
196 forum posts
112 photos
Hi Julian,
This has become a very interesting thread...
The throat-plate to bottom-of-barrel joint on the Minnie TE boiler is just a silver-soldered butt joint as designed by Mr Mason. Could this be considered as a weak point especially as there will be some stress here in a TE boiler?
Phil
julian atkins14/01/2016 14:58:49
1285 forum posts
353 photos
hi phil,
i have just had a look at the Minnie boiler drawings in ME january 1969.
on a relatively small boiler i dont see a problem with the throatplate to barrel butt joint so long as you avoid localised heating on the later and final stages. as a precaution i would use J&M silverflo 24 on the above joint, and do the outer firebox wrapper to barrel and throatplate joint at the same time also using silverflo 24.
however silverflo 24 melts at 740 degrees C and it requires a lot of heat, and a bit of practice to use. the remainder of the boiler can be done with silverflo 55 which melts at 630 degrees C.
(L.C. Mason suggests C4 silver solder for the barrel to throatplate and outer wrapper joints, but this is no longer available)
if you are lucky enough to still have some easyflo silver solder or easyflo No.2 save it for the backhead to outer firebox and last bit of the foundation ring.
before you start, best in any event to discuss the matter with your club boiler inspector and show him the drawings.
cheers,
julian
CotswoldsPhil14/01/2016 16:15:01
196 forum posts
112 photos
Hi Julian,
The shell - barrel, throat-plate and wrapper were silver soldered with C4 the best part of 40 years ago, with some help at night-school. The shell has remained in the cupboard since then, having failed to get any farther with a firebox. I managed to buy a boiler from Reeves (in Moseley, remember them) at the time, to continue construction of my Minnie.
I hope with some new found knowledge to complete the boiler, so that I can say I built the complete engine. I will be joining the local club for moral and practical support. Not least of which is how to implement the requirement for two boiler feeds on this engine with just a single pump.
Phil
