A thread for new owners of these machines to post in.
John Haine | 29/01/2022 07:26:26 |
5563 forum posts 322 photos | OK the drivers are different so preferably need photos of Mick's machine control box. The Yako drives have a rotary switch to set current. I don't agree that there is much risk of damaging the motors or drivers by increasing the current a bit. Within the setting range of the drives the current is limited to the set value, and unless the motors are already running hot they are not going to overheat from a few minutes at a higher current. I've run the steppers on my mill for quite long periods nearly too hot to touch without issue, though I did establish that the high current wasn't needed so reduced it. But it's obviously a good idea to make sure everything is moving sweetly and not binding. From all the symptoms Mick described I still think it's most likely to be an electrical problem. |
JasonB | 29/01/2022 07:49:01 |
![]() 25215 forum posts 3105 photos 1 articles | As was suggested somewhere I would consider swapping the X & Y steppers over which should show up if it is the stepper that is at fault assuming they are the same. Does your manual not give the torque for the steppers? Mine gives X&Y as 4Nm and Z as 6Nm for the KX3 |
John Haine | 29/01/2022 09:52:42 |
5563 forum posts 322 photos | Yes good idea. Swap the wiring initially so the Y drive runs the X motor and vice versa. |
Emgee | 29/01/2022 11:18:05 |
2610 forum posts 312 photos | If a stepper has gone faulty by losing or shorting a winding it could have caused damage to the driver, changing X & Y axis cables over could lead to the faulty stepper causing the same damage to the good driver, it's a risk you may not want to take. Best to check for equal resistance of the stepper coils and insulation resistance to the motor frame before changing leads over. Emgee |
mick | 30/01/2022 11:56:24 |
421 forum posts 49 photos | Good morning all. Haven't posted for a couple of days as we've had visitors! Update. I've tried swapping over the X & Y steppers, as the Y stepper wiring is part of a loom I could only swap the X (which maybe the problem) and connect to the Y stepper, there's no movement at all not even a slight stutter, swap them back over and all's fine. I've been through every page of my manual and there's no reference to any stepper motor torque. As I've said before I can only adjust the gib with the table centrally positioned and then I can only find one sweet spot that allows 50mm or so jog in both directions until the slide jams. I can move the slide to both limits by spinning a small BA spanner attached to the square on the ball screw using only one finger, so it would seem like the X stepper only needs a bit more umph to drive the slide to its limits. With 2,800 hours on the clock the limited movement may be due to wear as most machining is done with the table centrally positioned, but until I removed the gib and cleaned the slides the table could be jogged to limits, it was only the situation of programs stalling and the control loosing its zero home position that prompted me to clean the gib and slideways. As I've said, when it comes to electronics I'm a bit at sea, so would the consensus be that I try a new stepper motor and as there are no markings on the X stepper what torque would be the one to go for. Thanks. |
JasonB | 30/01/2022 13:05:35 |
![]() 25215 forum posts 3105 photos 1 articles | Sounds like your assumed lack of Torque is just a result of things going back together a bit tighter if the stepper was capable of jogging all the way before. I'd leave the stepper alone and try to sort out the initial stalling that you mentioned, Don't think you detailed that in the last post when you were asked for an explanation of what the stall actually was. Torque should be on the machine spec in the last section of the manual just before the parts diagrams etc. |
Ketan Swali | 30/01/2022 13:31:33 |
1481 forum posts 149 photos | From the KX1 Manual put together by John Stevenson, Adam Stevenson and Alan Simmonds in 2008: X & Y axis 1.35 Nm each, Z axis 2.2 Nm
I am unable to assist or advise on dismantling, re-assembling, electronics, computers or software. Some electrical components are still available, without guarantee or warranty. Ketan at ARC
Edited By Ketan Swali on 30/01/2022 13:32:59 Edited By Ketan Swali on 30/01/2022 13:36:31 |
mick | 30/01/2022 17:03:19 |
421 forum posts 49 photos | Thanks Ketan. Plenty to think about there, I'll start by disconnecting the stepper from the ball screw. The one thing that stopped me from completely removing the X axis slide for checking and cleaning was the prospect of loosing all the balls! Judging by the machine serial number mine is a 2009 machine. As I said its got over 2,800 hours on the clock and I'm completely lost without it as its become an integral part of my workshop. Thanks. Mick. Edited By mick on 30/01/2022 17:05:14 |
John Haine | 30/01/2022 19:08:18 |
5563 forum posts 322 photos | Here is a summary datasheet for the motor. It's the third one down in the shaded table. Torque 0.9Nm at 3A per phase. Shaft diameter 6.35mm if it isn't clear in the picture. From Ketan's pictures the drives look as if they are the same as in the KX3, which would be logical as I guess you wouldn't want to have two designs. If they are the current is set by a screwdriver-operated control just below the screw terminal strip. The top left diagram shows the switch in close-up, from looking at its setting you can see what the current is set to at the moment. With this drive the maximum setting is 3 amps. This is the YKA2304ME, an alternative the YKA2404MA/B can supply 4A/phase. If the current setting is close to these maxima the scope for an experiment to increase the current is limited. Interesting that the manufacturer torque rating for the motor is less than what Ketan quoted. Edited By John Haine on 30/01/2022 19:08:39 Edited By John Haine on 30/01/2022 19:11:36 |
JasonB | 30/01/2022 20:05:11 |
![]() 25215 forum posts 3105 photos 1 articles | Though looking at Ketan's photos it looks a longer motor, more the size of the next one down the list which is 76mm long compared with the mount @56.4mm sq so could be the 1.35Kn even though the label says it's 56mm long Edited By JasonB on 30/01/2022 20:09:34 |
Adam Stevenson | 30/01/2022 21:04:43 |
35 forum posts 1 photos | The KX3 has 3+1 with 3 higher powered drivers and the KX1 has 4 like the 1 in the KX3 lower powered drivers. The fact Mike has adjusted the gib is where to start, remember these KX machines are not able to use a spanner to overcome a misadjustment. Also before swapping drivers about check that the connectors are nipped up, avoid over tigening them as that can strip the thead. "The Mk1 motor has an in-built torque adjustment device called the Mk1 brain cell" so just because it works by hand cannot mean it is fine. Edited By Adam Stevenson on 30/01/2022 21:14:19 |
mick | 31/01/2022 12:26:14 |
John Haine | 31/01/2022 12:35:38 |
5563 forum posts 322 photos | Does the slide run free with the ball screw installed and "back drive" (i.e. push the slide and the screw rotates)? But it sounds like something is misaligned when you couple the motor up. Dismantle, clean and re-lube the Oldham coupling? |
Ketan Swali | 31/01/2022 13:29:47 |
1481 forum posts 149 photos | Oldham couplings (not flexi-couplings) are designed to deal with mis-alignment, and do not introduce any stress on the motor or the ball screw. Usually they do not need lubrication. There is an acetyl disc in between the couplers. Difficult to figure out what mechanical issue is causing the bind. Ketan at ARC. |
JasonB | 31/01/2022 13:34:45 |
![]() 25215 forum posts 3105 photos 1 articles | Hardly seems like 15 months ago I was posting about making a flywheel pattern here. Well I've just seen a photo of the fruits of my labours. 20kg of iron and 15" dia |
John Haine | 31/01/2022 13:38:46 |
5563 forum posts 322 photos | Posted by Ketan Swali on 31/01/2022 13:29:47:
Oldham couplings (not flexi-couplings) are designed to deal with mis-alignment, and do not introduce any stress on the motor or the ball screw. Usually they do not need lubrication. There is an acetyl disc in between the couplers. Difficult to figure out what mechanical issue is causing the bind. Ketan at ARC. Agreed, but that relies on them being free. I was just hypothesising that if the motor wasn't quite lined up and the coupler binding it could push the screw out of alignment. |
Ketan Swali | 31/01/2022 14:48:02 |
1481 forum posts 149 photos | Posted by JasonB on 31/01/2022 13:34:45:
Hardly seems like 15 months ago I was posting about making a flywheel pattern here. Well I've just seen a photo of the fruits of my labours. 20kg of iron and 15" dia Looks good and clean. |
Ketan Swali | 31/01/2022 14:52:31 |
1481 forum posts 149 photos | Posted by John Haine on 31/01/2022 13:38:46:
Oldham couplings (not flexi-couplings) are designed to deal with mis-alignment, and do not introduce any stress on the motor or the ball screw. Usually they do not need lubrication. There is an acetyl disc in between the couplers. Difficult to figure out what mechanical issue is causing the bind. Ketan at ARC. Agreed, but that relies on them being free. I was just hypothesising that if the motor wasn't quite lined up and the coupler binding it could push the screw out of alignment. I think I understand and agree. It may be possible that the acetyl disc could have worn over time, and or it maybe catching. Also, when the stepper motor was disconnected from the ball screw and if was free running okay without being coupled to the screw, how easy was it to stop it by hand? Ketan at ARC |
mick | 31/01/2022 16:43:15 |
421 forum posts 49 photos | Hi. John. With the stepper removed the slide does move with hand pressure but not as freely as when the ball screw isn't connected to the slide, I can however move the slide quite freely with just finger and thumb by rotating the square on the ball screw which would suggest that the gib is correctly adjusted. With the stepper reconnected there's no jog just a slight jerking movement. Everything should be in line as the ball screw mounts are doweled to the ends of the slide and no matter where ever the gib is situated the rear dovetail will align the slide. |
John Haine | 31/01/2022 17:21:36 |
5563 forum posts 322 photos | Well it sounds like it's the motor or driver then. Do you have a multi-meter? If you made a careful note of the connections to the driver, then disconnected the motor leads and made resistance measurements, it should reveal if there's a motor problem. It's the bottom 6 connections on my second picture above, assuming that the steppers have 6 wires which they seem to have from Ketan's photos. If you could measure the resistances and post them it would be very helpful. Note that they will be very low, it's continuity we are looking for. So the A+ to A- resistance should be low, likewise B+ to B-. There should be an even lower resistance from A to AC; and B to BC. Any of the A connections should have infinite resistance to any of the B connections. Edited By John Haine on 31/01/2022 17:27:43 |
