BC Prof | 16/05/2021 11:40:00 |
182 forum posts 1 photos | I used Warco headstock oil. It's nothing special but I had some form my time with a 280V. Fill plug for the gearbox is on the RHS level with the lead screw . Fill the Headstock via the big plate screwed to the top . I used a 4l container of oil .
Brian . |
Anthony John | 05/07/2021 14:12:23 |
1 forum posts | Hi, I noted a while ago somone had drafted a procedure for fixing the oil leaks for the GH600, i had a few small leaks which i wasnt to bothered about, but after a period of no use over winter i opened the cabinet drawer to find it full of oil and no oil showing on the leadscrew gearbox, i would dearly like to haave a copy of this procedure so i can try and fix the leaks on the GH600, thanks in advance. |
Triumphboy | 18/12/2021 14:56:17 |
![]() 23 forum posts 4 photos | Posted by Anthony John on 05/07/2021 14:12:23:
Hi, I noted a while ago somone had drafted a procedure for fixing the oil leaks for the GH600, i had a few small leaks which i wasnt to bothered about, but after a period of no use over winter i opened the cabinet drawer to find it full of oil and no oil showing on the leadscrew gearbox, i would dearly like to haave a copy of this procedure so i can try and fix the leaks on the GH600, thanks in advance. Hello Anthony. I've only just seen your post. Do you want the documentation I put together for the leak on the front apron? If so, PM me and I'll send it to you. Cheers
George Fleetwood | 22/01/2022 10:06:00 |
3 forum posts | Posted by IRT on 11/08/2019 14:47:36: How did you get on with the machine castors are you still using the them or did you find there was to much movement. Thanks George A bit of an update in the casters: The lathe is now in the final position with feet wound down. I have adjusted the feet to remove twist using a cheap Engineer's level. If I push the lathe backward, there is a very slight wobble on the rubber feet - probably to be expected. It is very little movement, and the lathe appears to return to no twist when I stop pushing. I will evaluate over the coming weeks if this has a noticeable effect in use.
George Fleetwood | 22/01/2022 10:59:54 |
3 forum posts | I have just purchased a Warco GH600 Can anyone give me some advice on what to use for a base is it OK to use the cabinets existing holes with machine levelling feet. Thanks in advance George |
Howard Lewis | 23/01/2022 10:38:08 |
7227 forum posts 21 photos | There is a possibility that a sheet metal cabinet will less strong than the lathe bed and resist removing twist from the bed. It might be better to site the cabinet and then to concentrate work on removing twist around the Tailstock feet. I tried removing twist by jacking the bench on which my BL12-24 (BH 600 lookalike ) lathe sat, and found that it made no difference, other than raising the benchwork at one end. Howard |
IRT | 04/02/2022 22:47:42 |
151 forum posts 44 photos | Hi George, Sorry - Only just read your post and seen your PM. PM response sent with more detail, but in brief, I am still using the casters and have no intention of removing them.
George Fleetwood | 12/02/2022 13:22:49 |
3 forum posts | Hi Ian Thank you for your reply PM sent |
