Member postings for George Fleetwood
Here is a list of all the postings George Fleetwood has made in our forums. Click on a thread name to jump to the thread.
Thread: Warco GH600
12/02/2022 13:22:49
Hi Ian Thank you for your reply PM sent
22/01/2022 10:59:54
I have just purchased a Warco GH600 Can anyone give me some advice on what to use for a base is it OK to use the cabinets existing holes with machine levelling feet.
Thanks in advance George
22/01/2022 10:06:00
Posted by IRT on 11/08/2019 14:47:36:
Hi Ian
How did you get on with the machine castors are you still using the them or did you find there was to much movement. Thanks George
A bit of an update in the casters: The lathe is now in the final position with feet wound down.
I have adjusted the feet to remove twist using a cheap Engineer's level.
If I push the lathe backward, there is a very slight wobble on the rubber feet - probably to be expected.
It is very little movement, and the lathe appears to return to no twist when I stop pushing.
I will evaluate over the coming weeks if this has a noticeable effect in use.
