Lathe Rebuild Drummond
Martin Newbold | 04/01/2017 16:46:57 |
415 forum posts 240 photos | I have started buying parts for my high speed lathe rpm for my Drumond. Since installing this i have had issues with a RUBBISH 3PH INVERTER AND RUBBISH MOTOR AND HAD NO REFUND FROM THE SUPPLIER FOR THE MOTOR WHICH HAS BEEN DESTROYED BEWARE WHO YOU PURCHASE THIS FROM. I have sicne settled on a single phase motor which runs too fast for high speed and have started buying parts to make this . I have purchased two additional pulleys a 4" and a 5" and some new bearings
I cannot seem to find a bearing guide so am going to make my own out of angle iron and tool steel. |
Martin Newbold | 05/01/2017 11:02:20 |
415 forum posts 240 photos | Hopefully some more bits will arrive soon. This will be much nicer that the lay shaft as will live under the lathe |
Muzzer | 05/01/2017 11:09:35 |
![]() 2904 forum posts 448 photos | Apart from the poor service from the supplier, what brand of VFD and motor were they? Sounds very frustrating so best avoided from what you say. |
Nicholas Farr | 05/01/2017 21:44:56 |
![]() 3988 forum posts 1799 photos | Posted by Martin Newbold on 04/01/2017 16:46:57:
I cannot seem to find a bearing guide so am going to make my own out of angle iron and tool steel. Hi Martin, I wouldn't go to the expense of tool steel, bright mild steel square should be perfectly OK or even square hollow section (Box) on this type of bearing and it can be stich welded to your angle iron or even tapped and screwed. Put one in each channel on the bearing housing, so that they slide easy without undue slop. There should be no contact between the outer edges of the channels of the housing and the frame. Regards Nick. |
Martin Newbold | 06/01/2017 10:22:52 |
415 forum posts 240 photos | Thanks Muszzer , Nicholas Yes very frustrating but wont make same mistake again buying inverter technology . The rails are looking harder to make than i thought through lack of materials i need a larger section than 25 x 15 . This is why I thought of tool steel I am presuming 25 x 25mm. I was going to use angle to make the box up and bolt rails to it with a long piece of threaded bar to pull it down it wont need much force as the weight of the motor is on a counter balance pulling on lower belt too. do you think its worth making it without threaded bar in first case. How do you manufacture a fast thread is it just a coarse one? Cheers Martin. |
Nicholas Farr | 07/01/2017 13:24:43 |
![]() 3988 forum posts 1799 photos | Posted by Martin Newbold on 06/01/2017 10:22:52:
Thanks Muszzer , Nicholas Yes very frustrating but wont make same mistake again buying inverter technology . The rails are looking harder to make than i thought through lack of materials i need a larger section than 25 x 15 . This is why I thought of tool steel I am presuming 25 x 25mm. I was going to use angle to make the box up and bolt rails to it with a long piece of threaded bar to pull it down it wont need much force as the weight of the motor is on a counter balance pulling on lower belt too. do you think its worth making it without threaded bar in first case. How do you manufacture a fast thread is it just a coarse one? Cheers Martin. Hi Martin, not understanding your ideas, but have a look at this **LINK** which is the general type of set up for these bearings, which are nearly always bespoke. Regards Nick. |
Bazyle | 07/01/2017 13:59:23 |
![]() 6956 forum posts 229 photos | I'm hoping that when you mention 'tool steel' you mean what we call mild steel as in ready to be machined drilled etc. Tool steel will be impossible to drill or cut as it is the stuff that has to be ground into..... tools. If you are needing sections of 25mm square then you probably should use tube. Solid is going to be heavy and expensive. |
Nick Hulme | 07/01/2017 17:43:39 |
750 forum posts 37 photos | Posted by Bazyle on 07/01/2017 13:59:23:
I make parts in 01 Tool Steel and D2 Tool Steel, I buy both in fairly free machining annealed states, they turn and mill very nicely. Once I've heat treated them they don't machine so well - Nick |
Bazyle | 07/01/2017 22:30:58 |
![]() 6956 forum posts 229 photos | Ah yes , I'm being an old fashioned model engineer only using tools steel to refer to HSS. The varieties available to MEs is now rather wider than the ground flat Kennions stocked. |
Nick Hulme | 07/01/2017 22:47:00 |
750 forum posts 37 photos | It's just not that simple - http://www.buffaloprecision.com/data_sheets/dsm2hs.htm - Nick |
Martin Newbold | 08/01/2017 13:17:52 |
415 forum posts 240 photos | More parts arrived . Thanks Nick for the datasheet |
Martin Newbold | 09/01/2017 17:33:54 |
415 forum posts 240 photos | Managed to get my 3/4" shaft made so it was .747" to take bearings and pulleys today. Its starting to take shape I am still shoppig for 1m of 15mm x15mm for tracks to run this on |
Martin Newbold | 09/01/2017 17:37:42 |
415 forum posts 240 photos | Posted by Bazyle on 07/01/2017 13:59:23:
I'm hoping that when you mention 'tool steel' you mean what we call mild steel as in ready to be machined drilled etc. Tool steel will be impossible to drill or cut as it is the stuff that has to be ground into..... tools. If you are needing sections of 25mm square then you probably should use tube. Solid is going to be heavy and expensive. Sorry the technical drawings were not good the runners need to be 15mm square so not quite so heavy as will be quite short but will try to get 1m |
Martin Newbold | 09/01/2017 17:44:11 |
415 forum posts 240 photos | Posted by Nicholas Farr on 07/01/2017 13:24:43:
Thanks Muszzer , Nicholas Yes very frustrating but wont make same mistake again buying inverter technology . The rails are looking harder to make than i thought through lack of materials i need a larger section than 25 x 15 . This is why I thought of tool steel I am presuming 25 x 25mm. I was going to use angle to make the box up and bolt rails to it with a long piece of threaded bar to pull it down it wont need much force as the weight of the motor is on a counter balance pulling on lower belt too. do you think its worth making it without threaded bar in first case. How do you manufacture a fast thread is it just a coarse one? Cheers Martin. Hi Martin, not understanding your ideas, but have a look at this **LINK** which is the general type of set up for these bearings, which are nearly always bespoke. Regards Nick. Hi Nick am going to make a box out of angle to put my rail in similar to this one but with differant ends as mine needs to hang from under the lathe surface on a bracket i made up.
I am unsure if I wil need to construct lower threaded piece as gravity and the weight of my motor will pull this downward. but will make boxes up with this in mind. It might be that the pull wil be so much that the screws will have to go on it to keep it balanced Edited By Martin Newbold on 09/01/2017 17:46:24 |
Martin Newbold | 09/01/2017 19:41:51 |
415 forum posts 240 photos | First try at rough placement |
Martin Newbold | 06/02/2017 19:23:22 |
415 forum posts 240 photos | Got a bit further |
Martin Newbold | 07/02/2017 17:42:30 |
415 forum posts 240 photos | Well i drilled bars and re-ground one which was sticking |
Martin Newbold | 15/02/2017 16:11:07 |
415 forum posts 240 photos | Well I had to buy new angle as the B&Q angle iron lol now mild steel was not regular or a right angle inside and out. This mean all the work i had done was rubbish. I have purchased proper angle from a wholesale stock dealer and have got back to were i was . I have decided to use 3/4 gate eyes for the winding mechanism and have some on order . I still have to drill top plate for old mounting bearing holes and have a dry run with it cramped up before both are welded. |
Martin Newbold | 15/02/2017 17:10:04 |
415 forum posts 240 photos | I made the securing pieces to bolt under top and roughly cramped together to see if it all slides .
Neil Wyatt | 16/02/2017 14:20:49 |
![]() 19226 forum posts 749 photos 86 articles | Posted by Martin Newbold on 15/02/2017 16:11:07:
Well I had to buy new angle as the B&Q angle iron lol now mild steel was not regular or a right angle inside and out. B&Q angle iron is perfectly good as angle iron. Rolled angle iron isn't a precision product, up to 100mm leg length it can be up to 1mm out of square either way. |
