Member postings for vintagengineer
Here is a list of all the postings vintagengineer has made in our forums. Click on a thread name to jump to the thread.
Thread: Guy Martin - WW1 Tank - Channel 4
23/11/2017 20:33:41
Battleship guns used to have bigger rounds as the barrels wore down.
Thread: Not an industrial injury, but...
20/11/2017 22:33:39
A properly laid hedge is impenetrable to almost any animal!
20/11/2017 01:25:00
I don't have that problem. The last time I needed stitches in my hand they had a hell of a job getting the needle through my skin!!surprise
Thread: A model engineer gone wrong?
19/11/2017 10:34:24
Try looking on Amazon and the web! I am stunned by the amount of chemicals you can buy and get posted to your home address!
Posted by Martin Dowing on 19/11/2017 10:18:13:
Already those with interests in chemistry have huge difficulties with purchasing simple chemicals even if these are *not* listed as drugs or explosives, or their precursors. So for example nearly all solvents are "toxics".
Thread: In praise of Oldtimers
17/11/2017 21:06:43
Anything can be done if you throw enough money at it!
I always give customers 3 prices, normal price, price if they want yesterday and a price if they are not in a hurry!devil
Thread: Acetylene regulator / propane
17/11/2017 08:42:21
Propane regulators have a service pressure of 25 bar!
16/11/2017 20:48:01
Thread: Twisted lathe bed - Portass Model S
15/11/2017 08:16:06
As suggested, I would bolt it down, preferably to a large section box section. It will pull down over that length.
Thread: Identification Please, anyone!
13/11/2017 21:10:14
It looks very much like a Deckel rotary table for a Deckel milling machine. Will also fit an Alexander mill. Are you selling it ?
The number stamped on it will match the number of the mill it came from.
Thread: Metalworking files - Guidance required please
11/11/2017 19:54:40
You need to watch ebay. I managed to buy some boxes of Stubbs files for my workshop!
Thread: Chronos silver steel, water or oil quench?
11/11/2017 10:53:46
I did my apprenticeship in South African Sugar Mill and the blacksmith shop had a huge tank of pure whale oil for hardening purposes.
Bit hard to get hold of nowadays!
Posted by Rik Shaw on 11/11/2017 09:59:02:
The preferred method way back was to quench in water that had a layer of sperm whale oil floating on top.
Rik
Thread: The true cost of Diesel?
07/11/2017 12:22:14
Being cynical I think the car manufacturers are behind the push for electric cars.
07/11/2017 09:02:57
Image may contain: car and outdoor
06/11/2017 21:33:26
Air contains 78% nitrogen so why NOx so bad?
Posted by Mark Rand on 06/11/2017 19:44:21:
It should be noted that a hydrogen fueled IC engine can produce NOx just as well as a fossil fueled one... Hydrogen is also an expensive energy source at this time, being produced from fossil fuels.
Edited By Mark Rand on 06/11/2017 19:45:35
06/11/2017 16:41:48
So can IC engines, but electric cars only use zero power at standstill if you switch them off! They still use power for heating/cooling, radio and lights.
Posted by not done it yet on 06/11/2017 16:11:33:
Steamdave,
You might have forgotten that leccy cars can use zero power at standstill. If they can charge at 20kW while traveling at 70mph, I'm sure they can charge at 10mph, or even stationary.
Do think before being so negative!
06/11/2017 15:30:05
Both petrol and diesel engines will run a number of alternative fuels. Diesels were designed to run on peanut oil and will run on virtually any oil including used engine oil. Petrol engines will run on any combustible gas and liquids, including alcohol and hydrogen. When it runs on hydrogen it has no exhaust gas other than steam.
Thread: Spurious Accuracy
06/11/2017 09:07:43
I once had to make a large bronze bush for a Bugatti gearbox, the customer supplied the Ali gearbox casing. When the customer got it all back, he phoned me up to say the bush wouldn't fit!
When I got to his workshop the temperature was about 5C! Put the gearbox in front of a fan heater for 1/2 hour and the slide in nicely!
05/11/2017 09:26:20
I was commissioned to make a gear change selector linkage for an Edwardian racing car. The plan was to base it on a Bugatti design. Basically it was a shaft sliding inside a tube which slide inside another tube all bolted to the chassis.
It worked really well on the bench, smooth as silk with nice close tolerances. Totally failed on the car. So managed to strip down a Bugatti one and found it was as sloppy as hell with 1/16th clearances.
Taught me that you can be too accurate!
Thread: Bitcoin crashes...
04/11/2017 11:14:55
Having dealt in shares for the last 30 years, I would have bailed out a long time ago. Nothing increases in value that quickly without heading for a major crash!
Thread: Measuring Tolerances
04/11/2017 11:04:51
There is never a daft question, just daft answers!smiley
Posted by Neil Wyatt on 03/11/2017 13:40:30:
Ahem, let's assume that someone signing themselves 'Absolute Beginner' is unlikely to be familiar with meanings of all the terms we use and help them learn.
There are no daft questions if you don't know the answers.
