Here is a list of all the postings peak4 has made in our forums. Click on a thread name to jump to the thread.
Thread: looking for a new bench drill |
22/11/2017 01:19:15 |
Are you anywhere near Wiltshire, you could save a serious amount of money if you have the time. For-Sale post on here
Bill |
Thread: Myford Correct Oils |
22/11/2017 01:06:57 |
Posted by Neil Wyatt on 21/11/2017 19:17:10:
Posted by Gordon W on 21/11/2017 14:00:02:
I'm sure I've posted this before- be careful of chainsaw chain oil' some are enviromentally friendly and degrade quickly. Good for the planet but not so for the lathe. I was going to say that I understand your comment; However I've been using a plain old fashioned mineral chainsaw oil, rather than one of the newer biodegradable rapeseed oil chainsaw lubricants. Maybe I should have made that clearer. I save the vegetable oils for cooking, though I understand Castrol R smells good in a lawnmower.
Bill |
21/11/2017 13:26:15 |
Posted by Clive Foster on 21/11/2017 10:30:59:
.................... One impressive property of ISO 68 is the way it strings between the backgears. They run quieter to than with ISO 32. AS ever YMMD. Clive. Try chainsaw oil if you want "stringiness". It also wipes off the hands easier than motorcycle (or forklift) aerosol chain lube.
Bill |
Thread: Engineers level |
20/11/2017 23:44:27 |
Ian J, if you find it's not sensitive enough, you could try these folks **LINK** I'm almost certain they are the ones I visited when I was looking for some round bubble levels for photographic use; tripod indicator. Couldn't have been more helpful, with drawers and drawers full of assorted vials.
Bill |
Thread: Damaged Back Gear on Malcar 41/2" Lathe |
17/11/2017 23:17:44 |
Posted by Brian Wood on 17/11/2017 09:16:46:
Hello again Andy, Thinking a little more about finding a gear for your lathe, be careful if you approach people like HPC in Chesterfield. to supply a new one New gears these days by HPC and others will almost certainly be made to the modern 20 degree pressure angle whereas your damaged gear is almost certainly made to the earlier 14.5 degree angle and while they will mesh, it will not be a happy mix. Regards Brian No experience of these myself, but Tony has a comment on his web site requesting any owners get in touch with him, presumably so he can add more machine details to his database.
If they have internal splines, then bore out the new gears to a larger ID, and turn the teeth off the old ones. Pin and Loctite the two parts together and re-fit.
Bill |
Thread: Myford Cabinet Feet |
17/11/2017 10:42:36 |
I'm using something similar to these on my Warco copy in the new workshop **LINK** which allow for the uneven concrete floor. Beware, the Myford is a bit top heavy, with a tendency towards the rear. I've only used adjustable feet in the short term, as I'm not sure where the lathe will finally be sited when its bigger cousin arrives. In the other workshop in Sheffield, my original genuine Myford is rawlbolted to the floor with appropriate shims. My Dore Westbury mill is on an angle iron cabinet, with a couple of further horizontal lengths of angle iron at floor level. These carry 4 heavy duty castors, with another set of these adjustable feet outboard of them. It means I can move the mill round, and then wind down the feet for stability.
Bill |
Thread: Sketch/Drawing holder |
16/11/2017 22:32:38 |
Posted by Clive Foster on 16/11/2017 20:47:59:
I use a lot of those wallets. Just printed out my own personal copy of the Range Rover P38 RAVE electronic manual. No full spectrum printed manuals about and its so nice to have greasy finger proof versions. About a 3 ft shelf full of binders. Working on the parts book now. Clive. Edited By Clive Foster on 16/11/2017 20:48:13 I though one mainly needed the electrical section for one of those (along with instructions for renewing the heater O rings) |
16/11/2017 11:11:29 |
Don't have a photo handy, but what is essentially an anglepoise lamp arm, but with the light replaced by a clipboard with a sliding ruler. One of these, but not at that price, look for office clearances Bill Edited By peak4 on 16/11/2017 11:18:14 |
Thread: Spec or Manual for Colchester Bantam 2000 (New model) |
15/11/2017 21:20:07 |
Posted by Absolute Beginner on 14/11/2017 00:33:45:
Hi Bill, Yes I would love to see what you might go for. I have four or five perhaps possible options on the table at the moment. Gary Well I didn't get it so the search continues; it was a Willson Slant bed, with no discernible wear anywhere. Bill |
Thread: New member with a Mellor lathe. |
14/11/2017 21:22:23 |
Hello and welcome, Does the last photo on This Page assist any?
Bill |
14/11/2017 00:39:05 |
I also have my eye on a short gap bed M300, for rather less than you're looking at, but apparently in good nick, though I've not seen it yet. Bill |
14/11/2017 00:25:26 |
I guess some of it will come down to if you meed the extra centre height on the M300 and/or a gap bed.
Bill p.s. I was going by this comment; In the last years of production only Bantams with an increased centre height (6.5 inches) and a top speed of 2000 rpm were offered - but these machines should not be confused with the completely different Mk. 3 Bantam, which Colchester called the "Bantam 2000" - and which was actually a Harrison M250 Edited By peak4 on 14/11/2017 00:28:19 Edited By peak4 on 14/11/2017 00:28:56 |
14/11/2017 00:11:15 |
Gary, if you have a looks at Tony's Website, it suggests that its more or less the same as a Harrison M250 Bill |
Thread: Lathe unwanted taper |
12/11/2017 10:48:45 |
Posted by Steve Withnell on 12/11/2017 10:24:17:
Bit of a tangent - when I was a kid 10 or 11, Grandad asked me if I had a testube I didn't want. I gave him one to make a level - he knocked a hole in the end of the tube and fastened it to a long length of hose pipe. By filling the pipe at one end until water appeared in the test tube he could establish a level over a long distance. Steve
For folks who've never used a water level; I've just had a new garage built over in Buxton and made one of these myself to check various levels as the building progressed. The builder himself hadn't seen one since his apprenticeship and the guys working for him hadn't come across one at all. In my case I used a spare gallon plastic container with a brass fitting near the base to accept a long length of 5mm bore plastic pipe. This leads to a 2' length of 2x1" timber, with a spare steel rule attached. I then plugged the plastic pipe into a length of translucent CO2 line from a mig welder, clipped that to the steel ruler, and terminated the lot with an old motorbike petrol tap. ( I added another one at the container outlet.) The container can then be stood at any convenient place in the garage at about the level you need to measure. Note that the container stays put, and you wander round with the ruler and pipe marking the walls accordingly. To make the fluid more visible, the commercial ones seem to add a bit of flourescein to the water. Don't forget to open both petrol cocks and the lid of the container. A friend of mine didn't quite think it through and used a borrowed one of these water levels to set the RSJ when he was building his garage. He used the container at one end and the tube at the other, leaving the cap on the bottle. the end result was a lean to one side of about a full course of bricks after he'd cast the two concrete padstones for the beam. |
12/11/2017 10:29:48 |
A friend of mine recently bought the WM290 complete with makers cabinet. A rigid cast iron plinth, it certainly isn't. I loaned him my big crowbars and precision level, along with some basic instructions of what needed achieving. He has his own DTI. We has a play for a couple of hours together and I retired back home. The following day he went out and bought something to bolt it to the concrete floor of the garage. The base of each of the two pillars on the stand has 4 mounting holes, so with careful shimming and the level, plus 8 Rawlstud anchors in the concrete floor, he was able to get both pillars level and vertical. Thus the lathe itself then has a rigid mount at both ends, independent of each other and firmly fixed to the floor, to allow differential shimming of the lathe mounting holes if required. It was remarkable how just adding a single thin shim to just one of the 8 mounting studs under the cabinet changed the readings on the DTI. I think it took him the best part of a day to drill the floor for the 8 anchors and shim it all up to get the cabinet bang on level. Bill |
12/11/2017 10:13:51 |
Posted by ChrisB on 12/11/2017 07:05:07:
Thanks Bill for the detailed explanation, the Wm280 comes with 6 mounting bolts, 4 on the H/S side 2 on the T/S, will give it another go this morning...thinking about it, I used a 12mm "precision" steel bar which was fairly long, dont recall how much it extended out of the chuck, but must have been 500mm or so. Could it have slightly bowed under its weight? I've not done any calculations but at only 12mm, I'd have thought it would sag a little bit, plus a bit more due to the pressure of the DTI tip. With 4 mounting bolts on the headstock, I'd have thought it possible to fix it down pretty rigidly, such that the two at the tailstock end could drag that end down a bit with respect to the, now rigidly mounted, headstock. |
12/11/2017 00:20:24 |
Posted by not done it yet on 11/11/2017 23:14:27:
If you have a boring head .... Simple little gems like that make rreading these posts worthwhile! Locked safely away until needed - unless I forget it!
I originally thought I'd come up with something novel, then subsequently read that it's been a dodge for donkey's years.
The Clarkson T&C Grinder was near the lathe, and I have a flexible drive shaft with a drill chuck on the end. Bill Edited By peak4 on 12/11/2017 00:22:16 |
12/11/2017 00:11:02 |
Posted by Neil Wyatt on 11/11/2017 23:07:30:
If you skim the two collars at the same setting, but reversing the bar between the two skims) you can get them very close in size. I take the 0.0003" difference with a pinch of salt as I don't believe I can really measure to a tenth whatever my micrometer claims: That's pretty much what I was describing Neil, but with a longer projection on the left hand end, so it can be held in a chuck for the initial setup of any required twist in the bed. Since then I've found a 2 morse extension bar, but unlike most seen on the net these days, it is nicely ground all over. Ex military from Anchor Surplus in Nottingham years ago. I can get more "tenths" DTI deflection by gently leaning on the lathe than the bodged "test bar" idnicates. |
11/11/2017 22:48:58 |
Part 2
You can use the bar between centres with a dial gauge on the saddle, whenever you have need to offset the tailstock in the future and want to return it to the correct alignment. If you have a boring head consider making a centre to fit one of the holes in it, put the boring head in the tailstock and use the diameter screw of the boring head to offset the home made centre; that way tyou don't need to disturb the tailstock offset, and you have a nice screw adjustment to set the amount of taper you're turning. Also, now you've made the test bar, set up a DTI on the bed/saddle running on the right hand collar. Slacken the tailstock bed clamp, and the barrel clamp slightly and wind out the tailstock barrel, pushing the tailstock casting itself off to the right hand end. If you observe the DTI whilst winding the handle, is should give you an idea if the tailstock barrel is projecting in line with the bed.
In some ways, the Myford setup is slightly easier as there are only 4 bolts, so there is less chance of "bending" the bed. Passing through the lathe foot is a thinner stud which goes though the afore mentioned hollow bolt and is retained in the cabinet. Good luck Bill p.s. there is an argument which suggests that the test bar should be a thick walled pipe, as it would deflect less under its own weight, but I can't imagine it would make much difference in the sizes of our "hobby" lathes, and also you would lose the advantage of being able to use it between centres to set the tailstock. Edited By peak4 on 11/11/2017 23:03:04 Edited By peak4 on 11/11/2017 23:03:49 |
11/11/2017 22:45:52 |
Chris, Firstly I should stress that I'm not a trained engineer, well I am, but in telephony not mechanical. Everything I've learned has been self taught, so read anything I write with an appropriate pinch of salt. I'd suggest that the reason you've struggled with the vertical alignment is to do with rigidity of the workbench and lack of mass in the headstock, plus it would only really work for lathes with 6 or more mounting bolts, 4 at the headstock and 2 at the tailstock on a very rigid bench. I think you understand the principal of putting a twist in the bed to make it turn parallel with a chuck mounted workpiece. The vertical alignment would require the whole of the bed bending a tiny amount with respect to the centre of rotation of the headstock spindle, and I can't imagine that this should be required in a lathe of this size. The caveat to that is, have you actually put a bend in the bed whilst adjusting the twist in it. If so, don't worry as I'm sure it will be within the elastic limit of the cast iron. That is, in the ideal world, if all four bolts at the headstock are firmly fastened and cannot move at all in relation to the ground, then everything about the headstock is fixed and all adjustments at the tailstock end are in relation to it. "Levelling the lathe" (with a capital L) refers not just to getting it level from headstock to tailstock, indeed, that is the least important, though obviously it should be as "level" as possible. The main one is fore and aft, which should be the same at both ends of the bed, hence the "twisting" scenario to make it so. I think you should be able to see that, if the headstock casting is truly immovable, then if the tailstock bolts were pulling that end into the bench as the wood squashes, the the bed would deflect downwards at that end. Obviously a similar scenario if you put a couple of washers under the tail end of the bed before tightening down the headstock, then the tail end of the bed would deflect upwards, with respect to the headstock. I'm assuming that since you have neither a calibrated test bar or precision level, you will need to sort it out by turning and measuring. I'd suggest making sure that in your case the "level" between head and tailstock in neutral, and that any differential shimming only adds a twisting, rather than a bending moment as well, in order to keep the vertical alignment correct.
Here's the way I set up my Myford, which may or may not be approved of by the many apprentice trained engineers on here. Take a decent length of steel bar, similar to what you've been using and maybe a foot or so long, clean one end and mount in the chuck. thin down the middle section of the bar by a couple of mm or so, similarly the far end as well; no need for accuracy. The intention being, that you well be left with two collars standing proud of the main bar as far apart as the length of bar will allow. (make sure you leave enough room at the right hand end beyond the collar to allow a drive dog to be fitted later.) Measure them with a micrometer, ideally a "tenths" one - mine are all imperial. If they aren't exactly the same diameter, which is most likely, this should tell you which way you need to apply a twist to the bed. Only now can you turn your attention to the tailstock. Centre drill both ends of the bar. Either fit, and check, a centre in the headstock taper, or chuck a bit of steel in the 3 jaw and turn a taper on the end to make a centre which you know is true - it must be you've just made it. Fit a drive dog and turn the bar between centres; with your nice sharp tool, again with the finest of cuts true up and measure the two collars. Keep minimal projection on the tailstock barrel during the operation.This will tell you whether the tailstock needs to move towards or away from the front of the lathe. Once you have the tailstock correct, true up the end of the bar that you held in the chuck prevously, as it will now be slightly out compared to the centre drillings. You now have a lathe that's reasonably well set up, and a re-useable test bar as well, so keep it in a padded box with some rust resistant paper. OK so it's not as good as a calibrated precision ground bar, but if you could afford one, you'd have already bought it. Bill Part 2 to follow
