Here is a list of all the postings Ady1 has made in our forums. Click on a thread name to jump to the thread.
Thread: The crumbly concrete problem |
02/09/2023 17:33:17 |
The stuff they cobbled together and poured in the war still seems to be fine, lots of gun emplacements and storage huts still around The stuff Adolf poured into all his dastardly engineering seems to almost indestructible... Only in Britain could we get soluble concrete... I think the Grenfell disaster may have saved us from a repeat performance with everything going up now being made of brick again instead of those panel things |
02/09/2023 14:23:22 |
We all know about this from the UK news so I thought I would see if our (your) combined knowledge could save the day for crumbling Britain I noticed that the concrete allows water ingress which can make the bars rusty and cause issues So does this not mean you can drill a hole and pump a hardening agent right into the porous structure and give it a new lease of life? (They've only had 50 years to figure it out ) Edited By Ady1 on 02/09/2023 14:27:31 |
Thread: Levelling my lathe - a build log |
02/09/2023 13:41:23 |
Great move. You will think you're bonkers at first but if you're doing a lot of stuff... Once you chop it up you will have saved yourself an absolute fortune in materials I use the blue spot stainless discs, find the cheapest source and buy 100 of them For critical straight cuts put the plate into a big vice and move the disc along the top of the vice jaws Well done you If you've got a 200+ amp stick welder then all sorts of other options become available Edited By Ady1 on 02/09/2023 14:06:55 |
Thread: Assembly diagrams - how are they done? |
02/09/2023 11:13:11 |
I only use old Windows stuff, and ONLY the Pro versions Win7 64bit and 8.1 64 bit run most stuff fine and the "update" process can be disabled Never used an antivirus either, in 20+ years You can download the software anywhere, the bit you must get a hold of is the key Nowadays I would just get an old laptop with it preloaded from the bay etc Edited By Ady1 on 02/09/2023 11:22:54 |
31/08/2023 14:53:37 |
I had a squirrel with Alibre Atom and it's a bit fiddly but you can use the basic drawing function for a viewing angle, the notes bit for numbering and lines, then save as a PDF Then use a PDF editor to put in the key list
Thread: Beavermill Mk2 - HELP - Missing Small Gear |
31/08/2023 11:04:15 |
Might help |
Thread: LBSC Netta |
31/08/2023 09:57:29 |
These will get you started if you're waiting for bits |
Thread: Proxxon CNC Mill |
29/08/2023 17:25:57 |
Posted by David-Clark 1 on 29/08/2023 16:02:09:
Still, passes the time and keeps my mind active.. I got Alibre when I had covid at xmas for something to do. Best thing ever once you suss them out... and unlike the real world all your parts fit perfectly every time! |
Thread: Brazing & corrosion |
28/08/2023 13:10:35 |
Posted by Kiwi Bloke on 28/08/2023 11:00:49:
With hindsight, I should probably have used chains of short weld runs, say 1" long, like the original MIG welds.
A perfect job for flux cored wire welding. short tack welds. Vary your amps as you change task Edited By Ady1 on 28/08/2023 13:11:05 |
Thread: Sewing machine motor |
28/08/2023 10:01:42 |
I got a vevor brushless 750w one and first impressions are very good Push of a button gives you reverse I tested it on my Drummond M through the countershaft for half a day which takes a bit of grunt There's one being used at the end of this thread Edited By Ady1 on 28/08/2023 10:19:31 |
Thread: Charcoal |
28/08/2023 09:55:46 |
Was Anthracite not "the good stuff" for model steam |
Thread: Improving hobby-grade Servos |
27/08/2023 19:32:33 |
Not a prob. We all thrash stuff out from different angles in here which makes this place so interesting The build in itself is an impressive feat, and then there's all that extra technical amazingness (edit: I was really hoping someone had created an easy multi axis software solution for hobbyists) Edited By Ady1 on 27/08/2023 19:49:08 |
27/08/2023 18:08:35 |
I've had another squirrel and it's amazing work on multiple levels but there's no information on what he did for the CAM work and the G-code It's a 6-axis job which really is next level stuff but I have no clue how he actually made it move about, unless it was maybe perhaps a python routine All the stl files and freecad files appear to be build files for the project, 3D printing etc So it looks like it could be a robot that can do fabby stuff, but it will only ever be doing one fabby thing unless you have serious programming skills Edited By Ady1 on 27/08/2023 18:24:46 |
27/08/2023 13:07:00 |
We can pretty much all of us bodgers put widgets and wires together to do stuff with varying levels of competency and experience but once you get beyond the 3-axis zone you suddenly find your paths for a control solution rapidly narrow into very few choices 4 -axis CAM and the control systems to use them are thin on the ground for a hobbyist Suddenly the choices go down and the $$'s start going rapidly upwards Edited By Ady1 on 27/08/2023 13:13:10 |
27/08/2023 12:50:35 |
The big achievement is with the software doing multi-axis control, I think mach 4 does more than 3 axes as standard but there doesn't seem to be a lot of choice around for a hobbyist atm (crossed post) I would be far more interested in his software approach because it's yielding pretty impressive results Edited By Ady1 on 27/08/2023 12:54:13 |
27/08/2023 12:35:55 |
It's 4 or 5 axis but has the same issues The big achievement is with the software doing multi-axis control, I think mach 4 does more than 3 axes as standard but there doesn't seem to be a lot of choice around for a hobbyist atm Edited By Ady1 on 27/08/2023 12:50:12 |
27/08/2023 09:19:42 |
As with the previous thread on the pico the big breakthrough will come with a DRO system independent of the motion system, which means self-compensation for mechanical error (just like with us) My hobby router with nema17s will easily do 0.1mm again and again and again... until it gets wear and tear The stage after self compensation is giving it the ability to "see" the object with a 3D scanner |
Thread: Replacement motor for Lathe |
26/08/2023 22:40:27 |
The newer motor is fine Your main challenge will be sorting out the lathe, use a slack belt to start with until you get some familiarity Edited By Ady1 on 26/08/2023 22:43:08 |
Thread: How come Windows XP can use Bing … |
26/08/2023 09:17:42 |
Must be to do with the MS set up system using trusted proprietary software so no permissions required |
Thread: A combinatorial problem. |
26/08/2023 00:32:52 |
combinations and permutations Edited By Ady1 on 26/08/2023 00:33:55 |
