Member postings for jason udall
Here is a list of all the postings jason udall has made in our forums. Click on a thread name to jump to the thread.
Thread: ME Shows
15/01/2012 17:52:18
shows?
Any clubs in West Dorset... I say west dorset 'cos dorset "seems" to be centered on Poole. Axminster is better for me
Thread: Drilling Vise improvements question
15/01/2012 17:38:40
no expert but my guess
jaws parrallel to each other and square to clamp screw all perp. to slide of jaws.
Check/ fixfirst then at least vise holds well.
Use angle blocks clamped to mill bed..then clamp vise to angle block. Thus under side can be trued.Square to jaws..so jaw face perp.
Then square off top to use as datum.
Thread: ME Shows
15/01/2012 17:26:54
only one major trade show..MACH..
NEC every ...FOUR years!
Thread: Loctite
15/01/2012 17:21:28
the hot / cold thing reminds me of how they put "inserts" in milling cutters these days...heat up holder drop in insert , allow to cool
15/01/2012 17:19:17
water is a very effective cement...used in machining gemstones...cheap ..wets surfaces well... no disposal probs..the liquid nitrogen used to instantly freese is a pain. Did build instant freese chuck once using peltlier heat pump took only ten seconds to chill can of pop too cold to drink from room temp
Thread: I knew it was coming...
13/01/2012 20:36:13
"some sort of ballon" google japaneese fire ballons... apparently 'discovery' of jetstream before anyone knew what it was... Also as to control / vision/ payload control for bomber...two words android phone.
Thread: Help!
05/11/2011 18:20:58
Re: "buzzing" in HI...in low machine wired in 'star' and in high wired in 'delta' this means machine uses the motor wiring differently in the two cases...fault might be in switch gear...may be one connection off in the delta mode.
