Here is a list of all the postings Emgee has made in our forums. Click on a thread name to jump to the thread.
Thread: dore westbury mk2 |
27/02/2016 13:16:49 |
Like Ian I found the design belt system the weak point of the machine, IMO conversion to Vee belt would be a big improvement when milling or drilling above 1/4". I only built the head which was installed in the overarm sockets of an old Taylor Horizontal only mill, mine had an MT3 spindle and I did run the geared head but only to check it ran OK, a bit noisy but valuable speeds for some work. Emgee |
Thread: Appraising an electric motor |
26/02/2016 21:58:02 |
Not the ideal physical size for a motor, most people these days go for 3 phase with VFD for speed control, your motor reminds me of 1 my father had on a circular saw, it was under the bench and nearly always partly covered with sawdust. I think you may just about get your money back. Emgee |
Thread: DIY lap and tapered reamer |
24/02/2016 08:59:09 |
Hi Jason In the engine build article when using the cylinder lap you say the lathe is running "slowly", can you please advise the spindle rpm ? Emgee |
Thread: Ackworthie Tapping Head |
21/02/2016 23:15:01 |
Bill Straight tapers but only short, parallel part between about 1/4" long, both tapers OD as per the parallel part. Emgee |
21/02/2016 21:51:36 |
Hi Bill From memory I think the collets were double angle with a short parallel part between and a tubular extension from the back, the end part is slightly larger diameter and a sliding fit to the spindle bore. If you check the inside of the closing nut you should see the angled closer, the other angle is on the inside of the threaded nose. The collets are slit in 4 places. Emgee
Thread: MK2 Bantam manual |
18/02/2016 12:02:28 |
John The following is Yahoo Groups Colchester Group page address, manual and spare parts list in the Files section all in pretty big pdf format. This is different to the hobby forum mentioned but has info re Bantam. Emgee |
Thread: Marking out / drilling holes in precisley the correct place ! |
18/02/2016 09:19:33 |
Hi Danny M Can you please post a picture of the "Centre Cam" tool ? Emgee |
Thread: Bridgeport Circuit Questions |
17/02/2016 22:39:11 |
Hi Norm I don't have a transwave unit but a similar type and run the pilot motor in parallel, the pilot runs continuosly when there is power output from the inverter, there is no load on the pilot motor. Emgee |
17/02/2016 21:55:30 |
Hi Darren, check your PM Inbox on the top of page. Emgee |
17/02/2016 15:51:41 |
Hi Norm Have you checked if there's an overload tripped ? Emgee |
Thread: end mill holder |
16/02/2016 12:39:23 |
Hi John The end mill holder will most likely retain the cutter by a screw locating on the flat ground on the cutter, this type are called 'throwaway' cutters and are usually much lower cost. The collet will of course grip the complete shank diameter for the collet length. In both cases you will only be able to grip the 1 size of shank, however some cutters are available on a std shank size with different cutting diameters. Emgee |
Thread: Steel? |
15/02/2016 20:33:41 |
stevetee Where does the link take you to ? Emgee |
Thread: Milling - Turning Axis Wheels the Wrong Way |
15/02/2016 20:31:08 |
You could try fitting travel stops on all axis so your table movements will be restricted to the part you want to machine, same applies to the rotary table, stops can be fitted to prevent overtravel. Emgee Edited By Emgee on 15/02/2016 20:31:45 |
Thread: Modifying outer bearing races |
12/02/2016 10:31:26 |
Hi Neil A lot of work for a small increase but that's what competition is about, did you mean Profi engine but made a typo ? Emgee |
Thread: High temp. thread locker |
11/02/2016 14:39:39 |
Hi Tim The answer to c) is 5BA as posted. Although a,b and d are relevant for a complete specification of the required product, John has asked if Loctite make a high temp thread locker. Like Jason I use Loctite 648 which I believe is good to 180/200 C, perhaps a search would find something better. Emgee |
Thread: Vacuum Cleaner Recommendations |
10/02/2016 09:48:40 |
I have already voted for Henry but I'm amazed at the very low cost of some modern equivalents, don't remember exactly what I paid for the Henry but £80 comes to mind and that was yonks ago. Looking at the spec of these machines they all seem suitable for mixed use in the workshop. Like many things nowadays more choice and lower prices all benefit the ME. Emgee |
09/02/2016 19:55:44 |
Another vote for Henry. Emgee |
Thread: Emco Compact 5 Motor Problem |
02/02/2016 22:06:51 |
DrDave Good news you have it running, what output power is the new motor ? Emgee |
Thread: The Workshop Progress Thread (2016) |
31/01/2016 22:54:58 |
Hi Will I have the same set-up and found like you the foot didn't return, I added a light spring between the elephants foot and the top plate, the gauge always returns now to the same reading. It won't solve the coolant issue though but if you fit an 'O' ring in the top plate bore above the stem gripping point it would provide a seal against coolant, you may then need a little stronger spring. Emgee |
Thread: cnc lathe spindle speed control problem |
30/01/2016 17:01:21 |
John What value do you suggest for C1 and C2 please ? Emgee
