Member postings for Michael Gilligan
Here is a list of all the postings Michael Gilligan has made in our forums. Click on a thread name to jump to the thread.
Thread: microscope info required
05/09/2023 14:03:42
Looks like a good acquisition yes
… if I understand your question correctly, the diaphragms should be aligned on the same optical axis.
That said; people do like playing around with offset lighting !!
A photo or two of the set-up would help.
Edited By Michael Gilligan on 05/09/2023 14:06:45
Thread: An unexpected weight
05/09/2023 13:15:16
I have three bags of these pears, each containing Qty.4
Although I have not weighed them, all twelve pears look ‘reasonably’ interchangeable
This bag has the marking 1:3 but the others are marked 1:4
… I know not what that means
05/09/2023 11:35:22
Posted by JasonB on 05/09/2023 11:23:23:
Michael may be pass some more time by contemplating why they give the nutritional value of a typical pear weighing 133g
Presumably because they are Tesco
…. and possibly so that they can claim their pears are bigger than typical
05/09/2023 09:24:51
I will photograph the plastic bag later !
Sorry … I thought I had been sufficiently explicit about what was, and was not, stated thereon.
05/09/2023 08:48:36
Fair comments, both yes
But the weight is explicitly stated [not an ‘average’ or ‘approx’ in sight]
they also give a size range of 58/68mm and note that ‘This pack contains a minimum of 4 pears’
It just seems strange and is engineering-ish, as befits the Tea Room
05/09/2023 08:00:53
[ For the sake of our Moderators … please keep this technical ! ]
I recently bought some Conference Pears from Tesco
These are imported from Belgium and the standard pack weighs 610g
… The obvious question being … Why ?
I’m sure we are all familiar with ‘Metric’ weights of 454g and 227g but I cannot see anything special about 610
Thread: turning a large diameter
05/09/2023 06:55:16
Posted by Jeff Dayman on 05/09/2023 03:46:51:
Suggest providing a fully dimensioned sketch with critical parameters and finishes if you want sensible suggestions. Ground finish on a part that is formed metal seems contradictory. " 2" wide x 1/2" thick " describes 2 dimensions - at least three dimensions are needed to describe even the simplest 3D objects.
Just for clarity, Jeff … he actually wrote: about 2" long by 1/2" wide
no mention of thickness
Edited By Michael Gilligan on 05/09/2023 06:55:59
Thread: The crumbly concrete problem
05/09/2023 04:24:20
Posted by MadMike on 04/09/2023 23:16:38:
[…] and for some unexplained reason and without advising or consulting me somebody has edited my comments out!!!!! Censorship? Really?
It happensThe first An earlier thread on this topic, in which I posted a link to the [technical] Loughborough reporting was “disappeared” entirely.
[edited to correct my unproven supposition]
Edited By Michael Gilligan on 05/09/2023 04:38:27
Thread: Isochronous knife edge suspension?
05/09/2023 04:09:13
I give up
Thread: Optical Alignment Device
05/09/2023 04:07:44
You have not misunderstood, Ian
… this the optical equivalent of ‘tramming’
Edited By Michael Gilligan on 05/09/2023 04:16:27
04/09/2023 20:21:55
There is more detail about it here:**LINK**
https://opg.optica.org/boe/fulltext.cfm?uri=boe-9-8-3624&id=395204
04/09/2023 18:07:44
Posted by duncan webster on 04/09/2023 17:55:35:
[…] the curve at thr top of the pendulum should be radius L/2 […]
Agreed, Duncan … that’s the very essence of it.
There’s a difference between ‘a cycloid’ and ‘the appropriate cycloid’
Thread: The centre of a well known supermarket
04/09/2023 17:33:47
Another useful item [if you happen to need one] is a ‘water level’ complete with 15m of tube for £4.99
04/09/2023 17:28:43
Posted by david bennett 8 on 04/09/2023 17:14:24:
To clarify my view. The concept is really very simple.
[…] Note that this applies to a roller of any radius. […]
.…. and therefore, to a roller of zero radius [i.e. an hypothetical knife-edge]
dont know
Thread: What are they?
04/09/2023 17:16:00
But do you have any suggestion what they might be ?
04/09/2023 16:57:22
Looks like they could be part of a centrifugal clutch mechanism
04/09/2023 16:55:03
Posted by david bennett 8 on 04/09/2023 14:38:52:
[…] I an coming to the conclusion that roller size doesn't matter. […]
In which case, everything I have written so far is wasted effort
Please ignore me
04/09/2023 06:58:46
Good morning, Dave
For the sake of your sanity, [and mine] … I will try once more, in bite-size steps:
  1. Galileo told the world that the pendulum was isochronous … this [the story goes] being based on his personal observation of either a large thurible, or a lamp, in Pisa cathedral … the timing of which he checked with his pulse [!]
  2. This was over-simplistic
  3. Huygens put things right; by demonstrating that a simple pendulum was not isochronous, but that it could be made so by forcing it into cycloidal motion.
  4. Please note that the hypothetical ‘simple pendulum’ comprises a massless and infinitely flexible ‘string’ hanging from a rigid support, and carrying a heavy bob of zero physical dimensions. [Reality is, of course, a little different]
  5. Huygens’ clock used a verge escapement, which nicely suits the large angle of pendulum swing.
  6. As horology developed, the anchor escapement and the dead-beat escapement superseded the verge, and the pendulum became a rod and bob, suspended on a ‘spring’ of shim.
  7. This arrangement is not intrinsically isochronous, but can be considered so at the small angles of swing which suited the new escapements.
  8. Further attempts to improve isochronism, by introducing cycloidal cheeks proved futile, because they could only act on the suspension spring … and that made appropriate dimensioning impractical … The problems far-outweighed any improvement.
  9. Fedchenko saved the day with his astonishing spring arrangement, but that’s another story.
  10. Your proposed roller arrangement, as the support for a rodded pendulum, cannot possibly mimic Huygens’ purist analysis …
I can only suggest that you work-through the clear instructions provided by Huygens, to get a ‘feel’ for the geometry.
04/09/2023 04:22:19
You make a good point about ‘the media: Alan …
Jeremy Hunt gave a calm and measured performance when interviewed by Laura Kuenssberg yesterday morning, but then the reporting by the Independent last evening sensationalised it.
03/09/2023 21:30:03
Posted by david bennett 8 on 03/09/2023 21:20:19:
Knife edge - refers to the as yet uncut sharp V's on the edge of the coins which will be replaced by all steel replacements. I did say this was a quick and dirty first try.
dave8
But that’s surely on an axis rotated 90° from what is normally considered a knife-edge suspension dont know
… sorry, I’m too confused to think it through
Edited By Michael Gilligan on 03/09/2023 21:32:40
