Member postings for Michael Gilligan
Here is a list of all the postings Michael Gilligan has made in our forums. Click on a thread name to jump to the thread.
Thread: Boring Smallish Hole
21/06/2012 22:32:09
Given that the original post was about opening-up the bore in a pulley ... from 10mm drilled, to 11mm bored ... that does seem irrelevant.
21/06/2012 11:34:55
Martin,
No ... the hole-boring version doesn't cut at all on the sides, only on the front [rather like a counterbore]
The tool is a "running fit" in the the finished hole, which is why it's self-aligning.
... The D is just over half the diameter of the tool; which puts the long edge above centre.
20/06/2012 23:23:44
Martin,
I should have been more specific; because there are two different tools both commonly known as a D-Bit. One, as you say, acts like a reamer ... The other has no rake or clearance on the side, and it cuts only on the front. [i.e. it is somewhere between a Drill and a Boring Tool]
Sometimes known as a Cannon Drill; once started, it is self-aligning and is particularly good for deep holes.
... There is a lengthy discussion about the differences, on this thread.
20/06/2012 22:20:39
[on this forum] I am sure that someone will correct me if I am wrong ...
Surely the "right" tool for the job is a D-bit. This is the ultimate incarnation of a boring bar with "the biggest possible diameter, and the smallest possible tool-tip protrusion"
The end-mills and slot-drills, suggested earlier, work in a similar way; but with a reduced core diameter.
Thread: Jung Rotary Microtome
20/06/2012 18:23:30
The good folks at Leica came up trumps.
Model 1130, completed 31-March-1966
... and they have sent me a PDF copy of the original [German] instruction booklet.
Amazing support!
Thread: Mini Mill belt drive conversion
17/06/2012 09:42:28
Posted by Ian S C on 02/04/2012 12:31:39:
If you r going to use other than a V belt, or round, a poly V belt would be much better than a toothed belt. There was a number of years ago a series in ME on the convesion of a mill to poly V belt, this allowed extra speeds to be fitted in the same space as the origional V pullies. There is also a mod for Myford lathes, also giving extra speeds. Longer belt life, and quieter, smoother running. Ian S C
I've just skimmed through this thread, and agree wholeheartedly with Ian S C
Poly Vee belts are amazingly efficient; being very flexible [in bending] but non-stretch. They are widely used in drives as vatious as Car Alternators and Tumble Driers ... a splendid piece of Production Engineering.
Perhaps the best bit is that Pulleys are very easy to make in the home workshop:
Grind the profile for a single Vee on the end of a HSS Parting Tool blank.
Mount the Tool dead square in the Lathe , just as you would for parting-off. Then plunge cut to the correct depth ... Retract ... Move by the "Pitch" of the Poly ... and repeat as many times as you need.
A positive Depth-Stop is a great help, and you need to take care getting the Pitch right, but it really is that easy; and the required cuts are not deep.
Use a hard Aluminium Alloy for the Pulleys and the tool should stay sharp.
Thread: Moore & Wright disaster
16/06/2012 22:36:01
Neil,
Yes the acid can cause the crack to propogate, and the process seems to escalate exponentially.
The mechanism is known as Stress Corrosion, and you will find an excellent article on Wikipedia.
... Sorry for your Loss.
15/06/2012 13:58:27
Clive,
Thanks for that advice ... I will give it a try.
15/06/2012 10:02:08
Ray,
Good to hear from you.
Yes, I have a keen amateur interest in Microscopy, and intend to use the Microtome. I have been looking for somthing like this one for a while now.
I am especially interested to try the 3D imaging technique, whereby a "stack" of sections are individually photographed and the specimen reconstructed digitally ... rather like MRI scanning, but destructive!
... I will send you a Personal Message later today
Sorry about the missing photo in my original posting; it worked when I posted it, but the link from this forum is now broken. ... The link posted later should work OK.
15/06/2012 08:47:46
For anyone curious about the subject ...
This is a superb document by "American Optical", explaining the principles.
Thread: Log in time
15/06/2012 08:39:56
I think you will find that is to do with the Cookies ...
To comply with recent EU legislation; the site requests your explicit permission to use Cookies.
If you have not given that permission, then "Remember Me" is not an option.
14/06/2012 13:10:42
Thanks Bob
That looks a very useful site.
14/06/2012 12:17:20
Hello Bob,
Note: I just tried to post a reply using the iPad, but the site's new "Cookie Monster" logged me out.
So ... let's try again, on the Mac:
That's the first problem I'm afraid ... The Recyclab website only shows theirs as "RM", which I presume just stands for "Rotary Microtome".
The "Jung" is the original version of what became "Reichert Jung" and then "Leitz Reichert Jung".
... Various model numbers, but they all appear to be variations on the theme.
... I understand that the later ones use PTFE sliders in place of hand-scraped cast iron [presumably in the name of "Product Improvement"]
Theirs is Serial No. 27307 and mine is 26531
Grateful for any info you can provide
14/06/2012 09:18:12
Not as yet ... since I am not a member of the Yahoo! groups.
Thanks for the suggestion though.
13/06/2012 22:54:21
I have just bought a Jung Rotary Microtome, on ebay.
Similar to this:
Image borrowed from  http://www.recyclab.com/
It's a long-shot, but ...Does anyone have an instruction manual, or preferably a service manual, that they could share as PDF.
Many thanks
Edited By Michael Gilligan on 13/06/2012 23:03:14
Thread: Digital Issues
01/06/2012 09:08:44
Out of curiousity, I have just tried this on the iPad
Simply changing the preference "button" did not have any immediate effect.
I needed to Log Out of the site, then sign back in, before the change took effect.
Hope that helps
Thread: identification
27/05/2012 22:27:54
" ... something very close to a m6 thread ..."
Forgive me if I'm stating the obvious: That would presumably be 0BA.
27/05/2012 13:16:44
With the better pictures ... I agree that it does look more like a press for setting eyelets, or press-studs, into fabric or leather.
A handy device, easily adaptable.
26/05/2012 22:59:08
Ziggar,
It looks very much like the tool for press-fitting the plastic "glasses" to watches.
... If so, it would normally come with a set of dished brass "holders" and a set of rubber "pushers".
Put "watch glass press" into Google, and you will see what I mean.
Edited By Michael Gilligan on 26/05/2012 23:07:30
Thread: Unknown Machine ?
04/05/2012 09:34:31
I can't identify it ... but it certainly looks a useful piece of kit !
