Here is a list of all the postings AdrianR has made in our forums. Click on a thread name to jump to the thread.
Thread: Websites for the Bored |
13/04/2020 13:00:14 |
I just discovered periscope films on YouTube
I always wondered how variable pitch propellers work, Well worth a watch
Thread: Brass or Bronze for boiler fittings |
11/04/2020 15:07:57 |
Hmm, that is what I thought. So from my usual suppliers I have a choice, Colphos 90, PB 102, SAE660 Which would be the best to use? Adrian |
11/04/2020 14:48:33 |
Hi, I am making Myfordsboy's 2.5" boiler. On the drawings is says use brass for the bushes. On the video he says use bronze. I am also thinking of making all the other fittings from brass. How much of an issue is it to use brass instead of bronze for boiler fittings, considering this will only be fired a few times.
Thanks Adrian |
Thread: End mill relief |
10/04/2020 14:17:09 |
I don't know the official answer, but why not just use the same angles as on the cutter.
A. |
Thread: Lockdown challenge? |
10/04/2020 12:22:03 |
As we have not had any rain recently in the UK we soon will need to water. That would make one hell of a lawn sprinkler. |
Thread: What am i going to make with this scrap |
10/04/2020 12:15:34 |
You could make a pair of coffee cups to match This Old Tony's Coffee Pot |
Thread: Recommended Lathe speed? |
09/04/2020 17:01:06 |
Before speeding up the old girl, As Mick B1 suggested, do try using some positive rake on a really sharp tool. |
Thread: Will cash become obsolete ? |
07/04/2020 08:55:43 |
As Ady1 eluded, yes cash will disappear as there is big money to be made. We will get it weather we want it or not due to the power of advertising convincing the masses. We will all end up paying for it, the 1% to 5% transaction fee comes ut of our pockets not the retailers. |
Thread: Overwhelmed! |
06/04/2020 16:25:35 |
Being a relative newby I would recommend the following;
After that just buy things as you need them. You also need to find what rocks your boat. Models, engines, tools? So find a few small projects to make. A tailstock die holder and a wobbler steam engine is a good start.
Adrian |
Thread: How to make a silver steel axle |
04/04/2020 18:46:34 |
The oil should be OK, it is Morris ISO 68 that I use on my lathe, no nasty yellow metal eating additives. The silver steel is from M-machine, it was what I was expecting, nice and shiny with a smooth ground finish. Not polished, more of a brushed look. This is what I am making **LINK** I drilled the bush at 5.8mm and reamed to 6mm, and it looked pretty good to me. So I dont think it was a bad finish in the bush. When I run the engine the oil goes black, just like using metal polish. That is why I was wondering if people polish the shaft before fitting, just to remove some of the sharp edges on the ground surface. Maybe I should stop being tight and by some bronze. Adrian
04/04/2020 17:35:51 |
Hi, In my wobbler engine is says to use a silver steel axle in either a brass or bronze bush. I did not have any bronze so used CZ121 brass but the bush seems to be wearing faster than I would expect. In about 1hr it has gone from a good fit to having noticeable (an audible) side play. The surface of the silver steel has a ground finish and I am wondering if it should be polished before use. Or is using brass really a bad idea. I am using SAE68 oil.
Thanks, Adrian
Thread: Meccano spring drive belt |
04/04/2020 09:00:28 |
Thanks Bill |
04/04/2020 08:12:28 |
Hi I am making a small wobbler and want to use a Meccano spring drive belt on it. I have just ordered the belt and it is 1.5mm dia, but I do not know what V to cut for it. The plastic round belts seem recommend 35 - 40 deg V. Does any one know what it should be for a metal belt or have one they could measure? Thanks Adrian Edited By AdrianR on 04/04/2020 08:12:42 |
Thread: Mystery Tool. |
03/04/2020 18:16:58 |
Ha! Snap! |
Thread: Help with finishing Wobbler engine |
03/04/2020 13:50:59 |
I am in the final stages building the same engine. Don't think mine will look so fancy, well done on the build. |
02/04/2020 12:49:54 |
Pure guess, it is to remove clock hands |
Thread: Source of Small Extension Springs |
02/04/2020 08:31:32 |
Those are fearfully small springs. Ever thought of making your own? |
Thread: Gear Cutting - Pressure angle. |
01/04/2020 18:00:03 |
From what I can see on helicron this method creates an approximation to the involute curve by cutting a number of facets on each tooth. The more teeth of the gear blank that engage with the cutter, the more facets and hence better approximation. A small gear would only have two or three facets, hence the running noise he mentions. You could probably improve small gears. If at the end of the full gear rotation, with the cutter engaged with the gear, unlock the indexer and move the cutter height. 1/2 tooth up, re -ut all teeth, 1/2 tooth down, re-cut teeth. That way you would cut more facets. Probably easier to make a set of involute cutters. I guess the edges of the facets would wear quickly so it may run OK after a while. I guess they would be ok for light duty and low speed gears. |
Thread: Virtualbox advice |
01/04/2020 16:52:28 |
I would say to get it running try and use NAT first. Check that Virtualbox is NATing/Bridging you wireless card and not the wired adaptor. Does your VM have any network devices? Does the network device have an IP address? If you do try using the ping cmd from a terminal shell to check you can reach your router. e.g. ping router_ip_address
I have not used VirtualBox, I use VMware Player, so cant help too much with the specifics.
Adrian |
Thread: Good reading from DYSON. |
30/03/2020 16:53:21 |
I had a DC01 with a lifetime guarantee, I'm still alive, it is not. It ended up needing regular major surgery. In the end I decided it was cheaper to buy a VAX instead of keep replacing the bits. The motor still runs, in fact it ended up being a blower for my sons furnace. Would be unfortunate if they offer a life time guarantee for the ventilators.
