Member postings for mechman48
Here is a list of all the postings mechman48 has made in our forums. Click on a thread name to jump to the thread.
Thread: Chinese End Mill Grinders
17/03/2021 15:39:09
Posted by Howard Lewis on 17/03/2021 13:09:05:
John Stevenson sharpened some end mills, at a show, for me, in a matter of minutes.
Didn't stop me being careless.
Just wish that I could justify the cost of such a useful machine!
+1.. me too ! last Harrogate exhibition.
George
Thread: Two or three axis DRO
16/03/2021 14:01:33
Why not attach it at the top of your mill head, then you have the readout directly in front of you & away from swarf/oil/ ingress, the magnets should hold it securely enough & the cable is long enough?.
George.
12/03/2021 14:05:58
I have done the similar adaptation for my lathe tailstock & cross slide readings; work just fine for the cost of these, apart from buying Neodymininimuummmm magnets thinking.
George.
Thread: Flat bottomed hole with a boring bar - technique?
12/03/2021 13:55:02
Posted by Martin Kyte on 12/03/2021 13:36:09:
If all I want is a drilled hole (not to bored accuracy) I just grind a drill bit square across the tip. Drill with a conventional drill to size and then use the modified drill to square the hole off. (If doing this on a drill press freehand it's helpfull to have the modified drill part way down the hold before switching on)
regards Martin
Make sure you have the drill vice fastened securely as the modified drill bit WILL grab & try to throw your vice across the workshop due to no chisel point on the tip.
12/03/2021 13:49:02
Phil, your link works fine. exactly what I was asking about.
George
12/03/2021 12:37:30
I'm putting one of these LCD DRO's on my Xmas list, Has anyone fitted one of these & are they better/worse than digital readout. Looking on youtube these have a graphical display for its functions so you can see where the cutter/drill is rather than setting to zero & inputting digital figures.
George
Edited By JasonB on 12/03/2021 20:01:53
Thread: Low cost swarf guard/dovetalk protectors for Mini Mill?
11/03/2021 11:32:35
I normally wear slippers in the house but I use a pair of 'Crocs' to go to the garage/man cave then I swap them for a pair of safety trainers, I also put on a pair of cargo pants over my 'joggers' plus donning a warehouse / lab coat with the sleeves rolled up. as for the swarf issue my soluton was to use a piece of formed acrylic to use as a guard..
Guard mods #4
Guard mods #5
..Yes, I've already had the 'fish tank' comments, but it does the job.
George.
Thread: What Did You Do Today 2021
07/03/2021 19:03:00
Started on my next project; Scotch yoke engine designed by Bob Middleton..
George.
Thread: The Workshop Progress Thread 2021
07/03/2021 18:55:48
Made a start on my next project; Scotch yoke engine designed by Bob Middleton..
George.
06/03/2021 12:47:30
Hi Jim
What scale is your figure?
George.
Thread: ER Collet choices
05/03/2021 18:53:50
I have a WM16 mill ( 2012 ) & use a ER25 collet set in it. I also have a MT4 collet holder for the headstock of my WM250 V-F lathe, I have both Stevenson square & hex collet blocks, I'm one of those 'nice to have it 'guys; & have the hex block semi permanently mounted in my 3 jaw chuck, does all I need it to.
George.
Thread: Brazing silver steel: any caveats/recommendations?
04/03/2021 12:15:11
Dependent on dia' ensure that the ends have a suitable chamfer to enable good filling of joint, e.g. vee or 'J' joint, as in stick welding. In the past I've also used Duncans method, plus using epoxy resin, two part metal filler, whatever is to hand that will give a strong enoigh joint. Where needs must I s'pose.
George.
Thread: water level sensor
04/03/2021 12:05:20
Posted by duncan webster on 03/03/2021 22:23:00:
Posted by Grizzly bear on 03/03/2021 18:22:36:
Duncan,
Would a solid float work, sitting on top of the water?
Good luck, Bear..
That would be neat, but what would I make it from bearing in mind it will be 4mm diameter or less.
The simplest method works best, have a look at...
4mm Diameter Solid Delrin Polyoxymethylene (POM) / Celcon Plastic Balls Simply Bearings Ltd..
work on the acronym 'KISS' . Sometimes projects are over engineered where 'simples is as simples does' to closely paraphrase a line from a well known movie.
George.
Thread: Home Made Rear Toolpost Issue
02/03/2021 16:39:19
It was made to the drawing supplied with kit & as I recall it was 7*. It may not look it on the pic but it was propped up at the rear so there's probably some parallax error in there... thinking.
George.
02/03/2021 14:48:53
I made mine from the Hemmingway kit; one side has an angled slot , but I found that this created too much overhang & altering it moved the centre height out of position so I used the horizontal slotted side with a different holder which allows me to alter the over hang without losing centre height..
Part assembly
Main parts
Leaving the centre height as shown produces too much over hang..
Assembled tool holder
George.
27/02/2021 19:21:04
Yesterday & today. Have had a lot of back lash on my WM16 mill fine feed worm drive since day one ( 2012 ) but lived with it since. I decided to sort it as best with out removing the whole worm drive; it measured up at nearly 1.2 mm before the drive engaged ,yeah I know more than excessive. I made up a brass washer to take up as much slack as I figured .041" ~ 1 mm & fitted that, back lash is now down to ~ .4 mm so decided to leave it at that... for now!
Also decided to remake the cover for my X drive motor from a near colour match 3mm plastic sheet; heat gun bent to shape, replaced a PWM with a new unit that has a on-off-on switch & fitted a numbered dial, looks much better than the original stainless steel version, Original pics in album 'X' drive..
Fine feed washer...
Only small stuff but off the Tduit list.
George.
Thread: Quality kit supplies in the UK?
27/02/2021 17:56:43
Stuart Models are ideal.
George
Thread: Rod glands
27/02/2021 12:31:54
Posted by John Bramwell on 27/02/2021 09:43:56:
That sounds do-able. What about the stuff that looks like horse hair? Good for threaded maleable iron but might expand too much and impead the shaft.
Do you mean plumbers hemp; usually used in conjunction with ' Boss white' sealant, IIRC more for cast iron or galvanized fittings.
Thread: Dickson holder storage
24/02/2021 11:39:56
Here's my solution..
Just a slot in shelf bracket screwed horizontally to the back shelf.
George.
Thread: How to hold work for drilling on an ML7 using tailstock pad
24/02/2021 11:32:26
Bo'sun...'Just wish they did one with larger stock holding capacity up to around 30mm dia'.
Could you possibly machine the 'V' to accommodate your larger size 24 - 30 mm is a 3 mm face cut ea. side of the vee ? looking at the Arc page it looks as though there's just enough material left on ea face to do it.
George.
