Member postings for Brian Oldford
Here is a list of all the postings Brian Oldford has made in our forums. Click on a thread name to jump to the thread.
Thread: Heat shrink tape -how to use
07/06/2015 08:34:07
Posted by andrew winks on 06/06/2015 22:41:52:
Sounds like a good idea Brian, I had almost given up it. But with the addition of heat, wouldn't the PVC tape unravel?
I'll experiment anyway.
"Self Amalg" doesn't need heat to 'do what it says on the tin'. It'll bond into a homogenous boot at ambient temperature over a period of a few days so long as the pressure is applied by a complete PVC tape over-wrap. (That's the important bit).
It takes a little longer if it is colder but I've used it in a former life outdoors in winter in the UK and it worked. I was told it had a "shelf life" but I've used some that I've had for years and it still works OK.
If you want a waterproof seal around a cable remove the minute longitudinal extrusion marks by circumferentially abrading the surface.
06/06/2015 22:10:35
Going back to the self amalgamating tape. During my training I was taught to overlay the "self-amalg" with firmly bound self adhesive PVC tape. The application of pressure ensuring a complete and swift amalgamation to form a homogenous rubber "boot". Once fully amalgamated the PVC tape could be removed or may peel off on its own if exposed to sunlight.
Thread: Fitting Super 7 headstock rear bearings
06/06/2015 22:01:09
Although I've never had a problem I'm about to check and adjust the spindle bearings on my Mk1 S7. Can someone advise the procedure and confirm whether I need 1 or 2 "C" spanners to make any adjustment that might be necessary?
Thread: increasing the bending stiffness of steel pipe or tube?
06/06/2015 18:50:11
Try a bit of KISS if possible and use a larger diameter tube.
Thread: Plastic material for making casting patterns
05/06/2015 07:40:26
Polystyrene is frequently used as a sacrificial pattern material. Useful for large-ish one-offs. OK for CI but other processes need to be added if casting steel or other materials where the carbon content must be controlled.
Sikablock (and similar from other vendors) is just such a polyurethane material. It's available in a huge range of densities. The lightest has similar mechanical properties to Oasis that used by flower arrangers. The densest could be used to drive nails in with.
05/06/2015 07:25:00
Are you thinking of Sikablock? It's available from the likes of http://www.johnburn.co.uk/
I use it from time to time in my professional capacity.
Thread: Small engineering tasks
04/06/2015 21:28:57
I'm fairly sure you'd find someone to help you out if they are reasonably local but you give no indication of where you are.
Thread: Electrical question re transformers
04/06/2015 18:55:08
I did a slightly similar thing using PC SMPSUs. The only thing I added was to ensure the frame of the PSUs were isolated from any metallic chassis and add inverse "flywheel" diodes to the OP of each PSU to ensure easy start-up.
Thread: Three Phase Motor Wiring Identification
31/05/2015 20:26:09
Posted by John Haine on 31/05/2015 18:42:15:
There is absolutely no reason to check the polarity! As long as the windings are connected in a delta the motor will rotate one way or the other. If it's wrong just swap two of the wires round.
But also importantly identifying the winding ends correctly as described gives the flexibility to connect star if required at a later date,
Edited By Brian Oldford on 31/05/2015 20:27:27
Thread: Press drill malfunctioning motor
31/05/2015 15:40:51
Posted by colin hawes on 30/05/2015 21:52:17:
The capacitor on these motors appears to have too low a peak voltage rating for reliability. Colin
According to the silk screening the original C should be sufficient voltage rating for UK single phase. If of far eastern origin perhaps the figure of 450v may be more optimism than fact.
Thread: Myford ML7 Restoration of Sorts
26/05/2015 20:28:40
Sorry to drift OT but may be relevant.
My clunker of a Mk1 S7 has shocking rotational play on the tailstock barrel. If anyone knows of a easy (inexpensive) fix please let me know.
26/05/2015 07:27:44
Great photo-story. Please keep us updated of what was found. The good, the bad and the ugly. I was a little surprised you painted the rear seating face for a (quite rare) taper turning attachment. Perhaps you don't envisage doing long tapers.
Good stuff.
Thread: balata flat belt
18/05/2015 21:23:08
Are there any multi-V/poly-V belt experts here?
Thread: David Urwick's original Metalmaster
18/05/2015 21:20:02
Posted by daveb on 04/10/2014 01:52:32:
Mike, It would be nice to see a brand new machine but interest would probably be a bit limited due to the present day cost of castings, a smaller outlay would buy a ready-to-go imported lathe.
Neil, I wonder if there would be any interest in a quarter size model.
John, I have not seen a Labormill in the flesh but it seems to be a good deal bigger than the Impetus. It looks like a very useful machine.
Ady1, Thanks for that! I had not seen it before. Did you notice the tailstock has a handwheel?
Daveb
Perhaps a half size might be a better compromise between utility and affordability. Looking at the drawings I don't think the patterns and cores are overly complex but the low speed prime mover might be the stumbling block. Any thoughts?
Edited By Brian Oldford on 18/05/2015 21:21:26
Thread: A mystery tool
18/05/2015 18:02:48
Without wishing to take the discussion too far off topic I think it must be said that whilst many of us aspire to own a chest full of Lie Nielsen tools we simply do not have deep enough pockets and have to make do with the less expensive yet serviceable items.
Thread: Model engineering software programme
18/05/2015 08:20:10
Posted by Bowber on 17/05/2015 21:37:45:
All my computers are 64bit W7 or W8 and I've no problems running any modernish programs. I have some really old ones that woun't run but that's not a 32/64bit problem, they just don't run on later versions of windows.
Steve
Try installing a Linux distro such as Mint then try running those old apps on WINE.
Thread: A cheap source of DC motors?
17/05/2015 16:59:59
I think even 1/4hp may be a bit OTT for an Adept . Have you considered a sewing machine motor along with its usual foot control?
http://www.ebay.co.uk/itm/YDK-SEWING-MACHINE-MOTOR-AND-FOOT-CONTROL-PEDAL-LEAD-NEW-SINGER-BROTHER-NEWHOME-/350714545662?pt=LH_DefaultDomain_3&hash=item51a83745fe
f'rinstance
Thread: foundry castings
16/05/2015 21:58:37
As a broad generalisation for the small volumes model engineers want the greatest cost is in the pattern. That cost being predominantly labour and very little material. If you start to add complex coring the costs can sky-rocket.
Thread: Sizing Round PU Drive Belt
16/05/2015 20:35:25
Another supplier may be found here http://www.ebay.co.uk/itm/231541878757?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
16/05/2015 09:23:04
Good luck in your enterprise. There's few foundries left wanting to work in "penny numbers" even in the West Midlands. In consideration of the high cost of carriage of castings, where will you be based? And; what metals will you be working in? Air-set and/or green sand?
