Here is a list of all the postings Pierre EHLY has made in our forums. Click on a thread name to jump to the thread.
Thread: Unimat 3 belt sizes |
09/03/2011 15:06:56 |
John,
Hopping this help
Message http://groups.yahoo.com/group/unimat3/message/2951
29-sep-2010
Just an FYI-This may have been posted before, but I have figured out what size o-rings work well for my Unimat 3.
The Motor belt is a MSC 09263344 a size 334 Buna N O-Ring - 25 pack is $6.77
The large drive belt is MSC 09263393 a size 339 Buna N o-ring - 25 pack is $7.50
The power feed belt is MSC 09262239 a size 232 Buna N o-ring - 50 pack is $5.71
I hope that this helps someone.
Keith (keith.violette)
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Unimat SL
Large drive belt #340 (85,1mm ID x 5,3mm)
Small drive belt #332 (59,7mm ID x 5,3mm)
Increasing or decreasing one "O-ring" number
( #340 => #341) decrease belt tension
( #332 => #331) increase belt tension
pierre |
Thread: Easy Myford Oil Pump Seal |
04/03/2011 12:49:03 |
Hi,
I use 50cm of clear plastic tubing (windscreen-wash) forced over
the oil nipple & the oil can
You can see the oil flushing through the tube.
Otherwise Guy Lautard published (ME16jan1981) a small sketch
for nylon/plastic ran adapter
have a sunny WE
pierre
Thread: Gear cutters |
17/08/2010 08:47:19 |
john,
Have you an version for 14°1/2 PA ?
pierre
Thread: Hobbymat MD65 needs assistance to start |
31/05/2010 08:36:48 |
Hi gents, The links for :
Hobbymat MD65 Lathe manual (french) with WDM & IPC http://www.megaupload.com/?d=4MWOWBEP
Hobbymat BFE65 Milling Head manual (french) with WDM & IPC http://www.megaupload.com/?d=P4UYQ2AX
brgds pierre |
Thread: How do I demagnetise tools and parts of machines |
07/05/2010 18:25:13 |
Hi David,
For tools demagnetisation use an magnetic field generated by an AC current.
Use the stator (fixed part) of an old AC (240Vac) motor. Connect a light bulb
(40 to 75w) in serie with the field winding an power it up with 240v.
Pass slowly the tool in the stator, thats all.
IMPORTANT:
Isolate all connections (240v may be lethal) & connect all metallics part to ground
Watch also the T° rise of the stator
For machine part , built a fixture to move the stator over the affected zone
2 or 3 time (distance varie with the power )
Select a bulb that give you the half of the normal motor current
pm
