Member postings for Gary Wooding
Here is a list of all the postings Gary Wooding has made in our forums. Click on a thread name to jump to the thread.
Thread: Need some decent windmills and slot drills
08/06/2014 07:29:56
Wallace,
will you give permission for it to be published in my club's newsletter?
Gary
Thread: Eutectic Boiler Soldering
30/05/2014 08:04:09
I've done lots of silver soldering and yes, its basically fairly straightforward. But I strongly advise you to get lots of experience before tackling a boiler.
Boilers are large lumps of copper which require correspondingly large amounts of heat for a successful job. Somebody at your club must have done one at some time, so talk to them. Have a look at the equipment they used and try it out. Start small and progress upwards; copper and silver solder are expensive these days and, despite it being basically simple, the sheer quantity of heat required can be very intimidating. Its normal practise to use two torches: a large one for getting the whole thing nearly up to temperature, and a small one for locally heating the joints to melt the solder.
I'm sure you can do it, but gain some experience on simpler things first.
Thread: SWEET PEA
30/05/2014 07:40:50
Coincidentally I have the following for **sale**
Thread: Machining Bevel Gears
04/05/2014 13:44:09
Humble pie tastes horrible - arghh.
I decided to try it out with a CAD program. The following *LINK* illustrates that randomly spaced pinions cannot be fitted between two racks.
Gary
04/05/2014 11:41:12
What you say is true only if it's a requirement that the pinions have the same orientation, but I don't see why that is a requirement. Equally spaced, yes, but why same orientation? All gears are based on rolling cylinders or cones, the teeth are simply to guarantee no slipping. Where does the equal orientation come in? No matter what the orientation of the pinions happen to be, the second gear is bound to mate properly.
The point I was trying to make with the rack is that the two racks will mate with the pinions no matter how they are spaced. Random or equi-spacing has no effect on the mating.
Gary
04/05/2014 10:18:10
I found the MEW article "Design and CNC Machining of Straight Tooth Bevel Gears" very interesting, but one statement defeated me.
On page 14 the author states...
"This particular differential has 3 pinions equi-spaced around the gear. It is important that the number of teeth on the gear is divisible by three, with no remainder. Otherwise the three pinions will not sit equally spaced around the gear, each in the same orientation, and will not therefore mate with the second gear wheel."
I agree that the number of gear teeth has to be an integral multiple of three in order for the pinions to have the same orientation. But why do they need to have the same orientation? The second gear will mate whatever the orientation of the pinions.
If you image straightening the gears to make two racks, then it is clear that they will mate with any number of equal sized pinions, whatever their spacing. Or have I missed something?
Gary
Thread: Variable speed motor.
28/04/2014 08:05:27
Posted by Godfrey King on 24/01/2014 21:56:15:
I have been told that there is a problem with the cheaper ie £100 inverters with lack of torque and limited speed range and that you will still have to do some belt changing, is this right?
VFDs are not torque multipliers. They don't work like gears, where halving the speed doubles the torque. In essence, a VFD driven motor will give constant torque at speeds at and below its rated speed (ie. its speed at 50hz in UK), and constant power at speeds above. This means that power is proportional to speed up to the rated speed, and then remains constant up to maximum speed.
There are VFDs that purport to give increased torque at slow speeds, but I don't think its significant (can anybody supply more information?)
I've fitted cheap VFDs (around £50-£70) to 3 mills, 3 lathes and a bench drill, all of them will work up to 120hz - that means that a 1425rpm motor will spin at 3420rpm.
I seldom change the gears or belts on my machines; I use the VFDs instead, but there are occasions when I need the extra torque that only gearing can provide.
Gary
Thread: Which indexable thread cutting tools and chuck to buy?
18/04/2014 16:06:43
The real problem with HSS bits for threading, is the grinding and shaping to the correct angles. Take a look at the article "Really Simple Threading Tools" in MEW issue 159, page 44. It describes simple holders for internal and external threading, together with a very simple and easy method of grinding correct angles with a normal grinding wheel.
Gary
Thread: Total newbe
06/04/2014 19:09:57
Posted by Bazyle on 06/04/2014 18:52:31:Note that most older 3 phase motors are not dual voltage. You therefore need a more expensive 440v output inverter not the more regular 240 ones you can use when the motor is switched to delta. People will tell you that you can find the star point in an old motor and rewire it for delta but in old motors that point is burried in fragile insulation so digging kills the motor.
No it doesn't. I've done two and they're going strong 6 years later.
Gary
Thread: Imperial fractions on drawings.
06/04/2014 17:53:31
Posted by MICHAEL WILLIAMS on 03/04/2014 19:27:05:
Errors are certainly still possible but the general experience is that most errors get spotted 'pictorially'- without having to consider dimension details at all in some cases .
Hard to actually prove but as far as I am concerned design using a 3D CAD solid model is intrinsically more sound and less error prone than using 2D multiple flat view methods .
Basically true, but errors can still occur.
A few years ago, I was a member of a small team who had to design and build a special wheelchair. One member, who was very experienced with Autocad, accepted the job of creating the drawings. We should have heeded the warning signals when the first drawings appeared with dimensions in 1/10000", but we continued until one day we got a drawing where two important parts simply wouldn't fit. A dimension was exactly 1" out, to 1/10000"!. He had committed the cardinal sin of modifying a part without updating the dimensions.
Gary
Edited By Gary Wooding on 06/04/2014 17:55:00
Thread: Wire stripper repair or bin?
05/04/2014 14:32:35
I've repaired a few unsolderable things in the past by sewing them with 0.5mm stainless steel wire.
I use super glue to hold the parts together, drill small holes to take the wire, then use the wire to stitch it together. After the wire is pulled tight I then smother it in super glue. It works pretty well - not pretty, but serviceable.
Gary
Thread: Quick Acting Knob Question
05/04/2014 13:00:33
I've created a PDF of the section of the article that tells how I made the tilt nuts **HERE**
I hope this answers your query.
Gary
Edited By Gary Wooding on 05/04/2014 13:01:23
03/04/2014 08:35:13
If anybody is interested, some years ago I constructed a conversion chart for members of my ME club. It's in the form of a 2-page PDF that can be downloaded from...
It has the decimal and metric values of all Imperial fractions in 1/64"s up to 1", and tapping drill sizes for the common threads.
The tapping drill sizes were calculated with a 65% engagement for diameters up to about 3/8" or 9.5mm, and 75% for larger.
You can print it any size you like - I keep laminated A6 double sided versions near my computer desk and in the workshop.
Thread: end mill speeds
30/03/2014 14:33:49
You might find this useful. There is also an Android version.
Thread: Lathe facing convex or concave
25/03/2014 08:15:04
This explains it.
Gary
25/03/2014 07:41:20
Edited By Gary Wooding on 25/03/2014 07:56:48
Edited By Gary Wooding on 25/03/2014 07:57:57
24/03/2014 15:53:46
Posted by Nobby on 24/03/2014 10:18:53:
HI Niko & Guys
If you faced a large Diameter using cross slide . and it faced a slight angle . running a dti across the face using
the same cross slide. surly it would follow the same path ie zero . ?
Nobby
Quite so, if you only went to the centre; but if you went right across the face, the DTI would register twice the error when you reached the other side.
Gary
22/03/2014 12:23:16
There is no argument about the requirement for a lathe to face perfectly flat. The real question is, given that perfection can never really be obtained, is it best to deviate slightly by turning concave or convex? My vote is concave.
Gary
Thread: Browsing Photo Albums
21/03/2014 09:33:13
Thank you.
Thread: Column Alignment with Tilting Head Type Mills
21/03/2014 09:30:17
It seems to me that your problem is illustrated in diagram A below. Your DTI method will align the spindle with the column, as in B. Then, by normal the tramming method, you will tilt the column until the spindle is vertical, as in C.
Not knowing the mill, I don't know how you will tilt the column, but the method is sound.
tramcol.jpgGary
