Here is a list of all the postings Gary Wooding has made in our forums. Click on a thread name to jump to the thread.
Thread: Controls for milling machine |
23/08/2016 09:30:45 |
I fitted DRO and VFDs to my Centec - one for the spindle and one for the power feed. Both have forward/reverse/off switches. As John mentioned, the forward/reverse on the spindle is really good for tapping. I'd hate to go back to the single speed and direction days. |
Thread: WM16 Advice |
27/07/2016 10:11:56 |
Just to underline John's excellent posts. A friend of mine converted a WM16 to CNC. His first attempt was a disappointment 'cos he thought he could economise by using the original lead-screws and compensate with Mach3 adjustments. It didn't work so he purchased ball-screws and then found what John has said, there wasn't sufficient room to fit the ball-nut on the table. Luckily we have a mutual friend who has a Bridgeport, so an afternoon spent measuring and milling solved the problem. The conversion works very well and noise has never been an issue - but it is in a shed away from the house. |
Thread: Repairing iron pulley wheel damage |
14/07/2016 13:02:11 |
I just get a small grey circle containing a white rectangle. Latest updates of both Firefox and Win10. |
Thread: making bangles on lathe |
02/07/2016 13:55:34 |
A bangle bracelet is, typically, a solid band that slips over the hand onto the wrist. If she is going to use a lathe she's going to waste a lot of material and make lots of swarf. The usual way is to bend strip metal and solder or weld it closed. I've made lots of bangles out of precious metal (gold, silver, etc), all from strip. If she wants to use a lathe, then I would suggest a plastic, such as nylon or delrin. |
Thread: I think this is a scam |
02/07/2016 09:50:38 |
Is it possible that Willy is unaware that traction engine boilers are an integral part of the body? |
Thread: Tip for the week |
01/07/2016 09:47:11 |
Sort out the little black book that holds all your pass words , and remember to have it with you before you sit down with the iPad.
Better still - use a password manager KeePass is a good one, and its free. There are variants for Windows, Mac, and Android. Edited By JasonB on 01/07/2016 09:49:40 |
Thread: Parting with power cross feed |
30/06/2016 07:26:49 |
Ali is terrible stuff to part. It tends to build-up on the tip of the parting tool which then cannot cut any more - resulting in a bang. If you hand feed you will feel the point when this build-up happens and can stop in order to remove the build-up. Power feed just keeps on pushing, and you now know the result. |
Thread: How accurately can you machine? |
07/06/2016 12:55:07 |
I do work for the REMAP charity. Some years ago we had a big project (a very special wheelchair) that required several people for it's implementation. One of our members, a professed AutoCad expert, decided to do the drawings for us. He produced dimensions accurate to 0.0001" (there was no way we could work to that level). Some way through the actual build, one of the parts didn't fit - it was 1.0000" too big (but otherwise accurate to 1/10 thou). He had committed the cardinal sin of changing a dimension by hand, instead of redrawing the component so that AutoCad would dimension it. |
Thread: Meet Up at Doncaster! |
06/06/2016 09:34:24 |
I went on the Saturday; there was no problem with parking, but the same cannot be said about the admission queue. It appeared to be a single queue that stretched along the side parallel to the road. It wasn't until you got into the plaza that you could see the sign for advance ticket holders, but that was after unnecessarily queuing for some time with people wanting to buy tickets. The sign had been obscured by the queue when I initially walked up looking for the advanced admission door, so I went back to join the end of the only apparent queue.. I too thought the show was better than Harrogate, with some new models and more interesting exhibits. I found the TV-type information monitors somewhat confusing, leading to the initial assumption that stands being advertised could be found near the monitor showing the advert. I'm certainly going next year. |
Thread: DraftSight Free? |
27/05/2016 07:33:03 |
And don't forget Autodesk's Fusion 360. It's a fully parametric 3D CAD system with animation, rendering, and built-in CAM processor (the same one that Solidworks charges an arm and a leg for). Best of all, remarkably, for hobbyists, students, and small businesses (<100k/yr), its absolutely free. |
Thread: Question on gas bottles |
26/05/2016 15:26:39 |
Posted by Muzzer on 25/05/2016 20:41:10:
Talking of gas, what's the best option for argon and argon mix these days in the UK? IIRC, the cartel that is BOC, Air Liquide and Air Products (who owns who these days?) have the market pretty well stitched up, so you have to hire their bottles at industrial prices - either that or pay through the nose for hobby-sized bottles from one of the smaller outfits. I see that Air Liquide do "rent free" small bottles but presumably at hellish prices with filthy big deposits. In Canada / US you can buy your own bottles or acquire one for a modest deposit and just nip along to get them refilled as and when. Much simpler and cheaper. Murray Hi Murray, I've been using Ray Nash for pure argon - I had to buy a bottle from him, which he refills when required. Very fast and cost effective service. I just place the empty bottle in the wooden box he supplied and send it off. I'm just a satisfied customer. He can be contacted at: Green Lane Cottage, Coombe, St.Austell, Cornwall, PL26 7LP. Tel: 01726 882615, email: [email protected]
Thread: Best Apps and Software for the Workshop? |
19/05/2016 09:58:25 |
Posted by john carruthers on 27/04/2016 08:09:07:
Mr. Munday's 'Model Engineering Utilities' gets a lot of use.. I downloaded it but the install to the default C:\Programs folder failed due to insufficient authorisation. I then tried installing to my own folder, which seemed to work, but then Windows Defender removed it because it detected malware. At this point I gave up. I'm using Win10. |
Thread: program for simple drawing |
18/05/2016 17:01:57 |
Hi Niko I've sent you a PM. |
Thread: Windows 10 forced upgrade |
18/05/2016 10:50:31 |
I've heard that starting some time in July the Win10 upgrades will incur a charge of something like £90, so if you are considering upgrading then a free forced upgrade could be a mixed blessing. |
18/05/2016 10:37:27 |
If this is a one-off drawing, and you really have no intention of using a program to create any other drawings, then post a hand-drawn picture of what you want and I (or anybody else) will be able to draw it with a program. On the other hand, if you think you would like to use a drawing program in the future, then devote several days in learning one - it will be time well spent. |
Thread: Antiques Roadshow |
29/03/2016 12:13:16 |
It an early 20thC model of a mid 19thC machine shop containing a lathe, shaper, drill, grinder etc, all working from overhead belting driven by a working steam engine. |
Thread: Windows 10 - A Warning |
29/03/2016 12:01:00 |
I don't have Sky, so I'm probably way off beam, but I thought that it had a built-in catchup facility that needed a broadband connection. WRT the original post, 2GB is a ridiculously small amount nowadays, so does the basic Sky package really have that limit, or is it an old limit that could be raised on request? How does it cope with catchup? |
Thread: Tom Senior help/advice |
10/03/2016 12:31:51 |
I have a Centec 2B mill that came with 3ph motors running from a rotary converter, which was rather noisy and cumbersome. I changed the motors to delta and added Mitsubishi VFDs. I mostly leave the gears in the mid range and vary speed with the VFDs. Almost instant reverse is a bonus. I even do tapping under power by slowing the spindle right down and reversing every few revs to break the swarf. Haven't broken any taps yet (touch wood and cross fingers). |
Thread: Miss Britain III |
10/03/2016 12:14:55 |
Posted by KWIL on 09/03/2016 12:21:00:
Gary, Firefox and Win10 x64 works for me. Hmmm, I had a Win10 upgrade and reboot last night, and upgraded Firefox to the latest level (45.0) and still get a blank area instead of a video. |
09/03/2016 07:10:14 |
I just get a blank area where, I suppose, the video should appear. I'm using Firefox under Win10 x64. |
