Here is a list of all the postings MK_Chris has made in our forums. Click on a thread name to jump to the thread.
Thread: Load reactors for VFDs |
17/10/2021 11:47:56 |
Andrew T. Not a direct answer but a reminder of your previous post. Title :- Earth Leakage on a 3 phase Motor : post date 31/12/2020. Includes my experience with a 3 phase sine filter supplied with my VFD All is still working well (fingers now firmly crossed). Chris. |
Thread: How Many People Does it Take to Change a Lightbulb on the Forum? |
18/02/2021 17:03:40 |
101 Programmers gave up after they realised it was Hardware and not Software. Chris.
Thread: Earth Leakage on a 3 phase Motor |
03/01/2021 19:14:56 |
Hello again Andrew Tinsley.
Initial test set up. The black box is 180H x 120W x 65D (Maplin). Has tapered sides so the unit is sat on a Vero board with two tapered bits of wood under. The cables pass through holes in the front cover. The inverter shows the underside with the output cable not connected (T1 T2 T3 on the right). Not shown is the connected Control Pendant and the 3 phase socket. Accepts either the lathe or the drill. Chris.
03/01/2021 15:07:12 |
Equivalent problem. I had acquired a Pultra 1590 lathe and a Meddings Pacera drill. Both circa 1950. Both had damaged / missing parts. Both being sent for scrap. Motors are the original 3 Phase units and had not run for at least 40 years. The Pultra has the Mardrive unit and the Meddings a Brook motor. Taking advice I had both motors tested then bought a Drives Direct unit with a Sine Wave Filter (transformer). Avoiding winding insulation failure was given as the reason for the filter. Wanting to stay as original as possible my wallet suffered larger damage than I had hoped. Both motors run well after nearly 6 years: but a heart attack and advancing years has left me with limited progress. Chris.
Thread: A Certain Age |
07/12/2020 12:44:03 |
Howard. There is always the teenage version : if we can remember ! "If you're not here after what I am here after then you'll be here after I've gone !" But what on earth was it that I was after ? Chris.
Thread: Plans for updating the archaic forum? |
10/11/2020 23:18:22 |
Sorry Lee : but I am with the above majority, I too prefer the simplicity. Chris.
Edited By MK_Chris on 10/11/2020 23:20:48 |
Thread: Trunch Trojan |
30/10/2020 11:59:18 |
Congratulations Arthur and add a +1 for Rik Shaw's comment. Extracted from Neil's post announcing the : 2020 Stevenson Trophy Competition. A first attempt posted in the Miscellaneous Models section of the Forum deserves full encouragement. Chris.
Thread: Grumpy old men |
12/10/2020 14:41:57 |
Not a mention of the dreaded and irritating Background Music on the Radio (Wireless ?), the TV (abbreviation with no explanation ?) or YouTube. Thinking about “I'm well or I'm good”. I prefer the “never ask an older person how they are”. Chris.
Thread: Dead blow mallet |
03/09/2020 15:00:21 |
For an alternative approach look at MEW No. 63, Page 12. Chris
Thread: New Moderators |
01/09/2020 10:36:35 |
Excellent recruitment in my opinion. What's not to like ? I see no problem with the “Who moderates a Moderator” question. Dave and Mike. Welcome and enjoy. Chris.
Thread: How to stop scam phone calls for good? |
26/08/2020 23:14:22 |
+1 for Zan. My answering machine message is "Hello, this is Chris. If I do not recognise your number then I wait for the answer machine. Please speak after the tone". A lot of callers hang up immediately, although the last part of an automated message usually gets recorded. The genuine callers identify themselves so it works OK for me. Chris.
Thread: Milton Keynes newbie! |
05/06/2020 11:21:28 |
A belated welcome Steven - from a local in Bletchley. As implied many times : this is the essential and friendly forum for all. Get started by adopting the old knitting guide line of "Knit one, purl one, drop one". If the first attempt is a "drop one" then that is usual practice. A scrap bin is an essential source of future material so don't be afraid to add to it - by accident of course. Just keep on enjoying. It really is good fun. Chris.
Thread: Quick change tool post |
29/04/2020 18:01:38 |
Example of Lantern tool post with height adjustment. The thread is the Buttress type at 13 TPI. The collar is free to turn but a piece of masking tape or similar with a thin permanent marker line on it can be used for location. Part of recovery project that is slow progress not helped by age and a heart attack. So it still looks rather rough. Chris.
Thread: Phillips vs Pozidrive and portable drills |
06/07/2019 11:06:57 |
Here is my “take” / understanding of the difference between Phillips and Pozidrive. The angle built in to a Phillips head is designed to “cam out” when the torque limit is reached. Hence no shearing of the head due to over tightening. The results can be a bit variable and depend on the pressure exerted on the driver. Production tools such as air guns, battery tools etc. came with torque adjustment. The tool and not the operator provides the required torque limit. Hence the Pozidrive variation with a different head design was introduced. It retained the quick location of a driver with the pointed target system and the four extra notches added helped with visual identification. Battery drills almost always have a torque slipping clutch system built in behind the chuck. Usually marked 1 to something and ending with a No slip drill setting. I rarely see anyone use the torque settings on a battery drill : and have met a number of DIY'ers who did not know the purpose of the dial. Now hoping for more accurate detail from the many knowledgeable on this forum. Chris.
Thread: Snap rings for the new year |
01/01/2019 12:06:53 |
I viewed the message on a small screen and close up. All I saw was was the rings. So : AAEEHNPPRWYY That should be the translated message sorted for you.
Thread: Metal Bandsaw - quality? |
07/01/2018 18:00:08 |
@ Michael. +1 from me for my 782XL saw, and for the supplier, and also for “the wish that I had bought earlier”. I also bought the vertical table accessory - the main use so far. Being able to lift it and move it about for convenience was also a plus. Happy with the blade as supplied. Until I talked to the supplier I had not realised that the 782XL was a hand feed machine: not auto. When it comes to any significant purchase my long held philosophy is :- I have never regretted my extravagances but I have often regretted my economies. So yet one more for the “no regrets” column. Chris. Edited By MK_Chris on 07/01/2018 18:01:40 |
Thread: How on earth do they calculate electricity and gas bills... |
22/12/2017 23:09:16 |
Neil. Referring to your opening observation re. Direct Debits. Have a look at Bristol Energy. They have reviewed my DD's more than once a year : reducing or increasing as appropriate. They also offer the option to pay in full each month. Providing a monthly reading gave me a zero balance each month. I reverted to DD because the pay in full system is only manual at present. The option to pay in full by variable DD is described as "we do hope to be able to offer variable DD ". All the options are down to Customer choice and I intend to revert to full pay by variable DD when the option is made available. This will put my energy bills in line with my credit card as a "full payer". Usual caveat: I post this only as a satisfied customer. MK_Chris. |
