Member postings for Garry Coles
Here is a list of all the postings Garry Coles has made in our forums. Click on a thread name to jump to the thread.
Thread: Governor drive belt
10/12/2020 11:52:27
Hi, What material do people use for the governor drive belt. My pulleys are 1/4 in wide. At the moment I am looking at a flat shoe lace, but joining the ends is proving to be a bit awkward.
Garry
Thread: Surface milling
13/11/2020 10:06:27
Okay Jason, I hadn't thought of it that way, perhaps I should go back to using the 4 inserts again.
13/11/2020 09:41:52
Hi,
I thought I would mention about a cost saving exercise that I have done.
I have a 50mm dia surface face milling tool which has 4 carbide inserts. These inserts (APMT 1604) are quite expensive (£ 3.50-4.50) each so I experimented with using only 2 of them in apposing positions for balance. It seems to do the milling job the same as with 4 inserts but with a little bit more noise and using a slower feed rate. The finished surface is about the same. I can't see a reason not to do this as a fly cutter has only 1 cutting tool.
Hope this tip is of use of use someone.
Garry
Thread: De-magnetising
24/10/2020 08:48:18
Thanks Brian. Have looked at some online and yes they are quite pricey.
24/10/2020 08:05:51
Hi. I've got a lot of tools, like spanners & tooling bits etc that are picking up swarf all the time. Very annoying having to wipe them down all the time. Is there a way to de-magnetise them or do I have to put up with it.
Is there anybody that can give me some advice please.
Garry
Thread: Key steel
11/10/2020 10:57:08
Thanks for that info Nick. The keyways are in the axle for the my 2in scale D & NY traction engine. I would have thought the load would not be that great.
11/10/2020 10:43:39
Hi, I would like to know if key steel is any different to BMS. The reason I ask is I'm cutting some 3/16 keyways in a axle and I have got some 3/16 x 3/16 BMS in stock.
Thanks.
Garry in sunny Jersey.
Thread: Locktite
24/08/2020 10:00:48
Thanks for that, That's the number I was thinking about using, I just wanted confirmation.
24/08/2020 09:43:58
Good morning all. I'm going to be fabricating the crankshaft for my 2in D & NY traction engine and was wondering which loctite to use. I've got 290 and 603 on the shelf, but is there a better one for this job. Also if you say to use another number what sort of fit should the parts be for that number.
Thanks Garry
Thread: cylinder liner press
29/07/2020 11:54:20
Thanks both of you. I'm going to go along with the hot & cold idea. That does away with over stressing of the parts while pressing them together at room temp.
Garry
29/07/2020 07:46:11
Hi, A question on the press fit size of the cylinder liner into the cylinder block on my 2in scale D & NY traction engine. I've bored out the cylinder block and am now turning down the cylinder liner. Both are cast iron. The bore size is 1 5/8. (1.625" I've worked out the press fit size for the liner as being just over 1 & half thou .001625" using .001" per 1in is this the right size please, or have I miss calculated. Thanks
Thread: 4BA or 5BA
23/07/2020 22:19:12
Well in the end I think I will stick to using the steel studs I have already. Thanks everyone.
23/07/2020 19:54:33
Thanks everyone for your replies. I've already made up some 4BA steel studs but I wanted to use PB to get away from the corrosion of steel to the studs. I was going to use Stainless steel in the beginning, but some one said that's a no go for copper boilers!
23/07/2020 16:18:33
OOPS ! I got the sizes back to front. I meant to say that the drawings say 4BA and I can only find PB in 1/8 5BA size.
23/07/2020 14:14:39
Hi, I'm building the 2in scale D & NY Traction Engine and I want to make the cylinder studs, which the drawings state are 5BA that go into the boiler barrel in phospher bronze. But I can only find PB in 4BA size. Will this one size smaller be OK. There are in total 24 studs.
Garry
Thread: Safety valve spring length
25/06/2020 13:37:47
Hi. I am now making the safety valves for my 2 in D & NY traction engine. The springs on the drawing state 22 SWG .125" I.D. & .181" O.D. but does not give the free length. The working boiler pressure is 85 psi. The plunger overall length is 3/4 in and with the adjusting centre screwed down to the approx position, there is a gap of about 1/2 in for the spring. I think I could trial & error when the boiler is in steam, but I need a starting point. Can anyone help me please.
Garry
Thread: Copper tube bending
09/06/2020 06:38:27
The size of the copper tube is 3/8 x 21 g and the bends are like the one in JasonBs picture. I now know I can use lead thanks to Hopper. Cheers
08/06/2020 22:21:22
Well, thanks for all the comments, but i'm not any the wiser about using lead!frown
08/06/2020 19:11:15
Hi, I need to put some bends in copper tube for the exhaust pipe from the cylinder to the chimney on my Traction engine. And I don't want it to collapse. I was wondering if lead is melted and poured down the tube, this will work the same as cerrobend (woods metal). I know I can buy Cerrobend on line, but living in Jersey the postage gets a bit silly. And I have plenty of lead in stock.
Garry
Thread: Cylinder end covers
13/05/2020 06:53:25
Thanks everyone for your replies. I will now make the end covers out of cast iron as suggested.
Garry
