Here is a list of all the postings Robert Dodds has made in our forums. Click on a thread name to jump to the thread.
Thread: Conjunction of Moon and Jupiter |
11/04/2013 21:22:58 |
For you moon watchers out there I was sent this link to a full moon over Wellington NZ. **LINK** I was impressed by it anyway. Bob D |
Thread: Do Dogs read Model Engineer? |
18/03/2013 22:16:15 |
Neil, Your tail of woe reminded me of Ken Whiston of New Mills. He was an active member of Stockport MES and used to advertise in ME in the seventies and eighties "Have you seen my cat?" was the headline Lots of bargain bags of surplus bits at very reasonable prices. I'm still working from his bag of self tapping screws and there's lots of washers still to go too. Don't rely on 201 for a Proxxon cat. It's not purfect
Bob D |
Thread: Photograph of Wolf Cub drill wanted |
16/03/2013 22:40:44 |
Neil, What do they mean when they say "converted to electric"? I thought they started life as electric drills. I think I prefer the electric cornet, although I don't think it will play mp3s!
Bob D |
12/03/2013 20:59:26 |
David, Is this the model you're looking for? Bought about 1950 to construct an angle iron and asbestos sheet garage for Dad's first post war car! Still a good runner (drill not the car) with an allen key locking 1/4" chuck, it usually has a flap wheel fitted and is at the ready. Bob D
Thread: Model Engineers' Workshop Issue 201 - A Preview. |
01/03/2013 10:05:17 |
Kwil, Thanks for that tip. You can always learn something useful on this site, even if it has little to do with engineering in its wider form. Bob D |
28/02/2013 22:47:31 |
Well, I found it, but do you really want comments when the print on the two topics shown is SO small. And thats on a 19" desktop so what its like to read on your laptop heaven only knows. It's another case where the ads are making the page smaller. PS. Is there any chutney in the Mango?. I can't open pg 8. Bob D |
Thread: Something a little different from the day to day ME |
12/02/2013 12:35:28 |
Cornish Jack,
I don't think they had invented the Magnetic base / drill spindle idea when that photo was taken and I wouldn't fancy doing it with a B&D pistol drill! Bob D |
Thread: Tapered keyway |
12/02/2013 11:32:27 |
Well described Nick, but Key Steel is a bit special. There was a a thread on here last July, "Properties of Key Steel" which gives an account of the steel grade that is designated as Key Steel. It's medium carbon En 8, for the added strength but still easily worked so that you can properly fit it to the hub and shaft. I recall the slotter operator clamping down the hub onto two "tapered parallels" to set the hub at the appropriate angle to match the taper in the hub keyslot. Regards Bob D |
Thread: Very Small Drill |
06/02/2013 13:52:57 |
John A, If at all possible drill your cross holes before threading the rod/bolt. You'll get far fewer drill dig ins or breakages that way round. If you have to drill into a threaded bar at least file a little flat where the hole will be to help get it started but beware the break out on the other side. Bob D |
Thread: Buying way bellows !! |
29/01/2013 16:49:21 |
Darren, If you need to go for a custom made you might look at http://www.beakbane.co.uk They do many different styles, one I used in the past was from a dip plastic coating. For 1offs the moulding former may make it expensive so one of their standard ones would be more cost effective if you can get one to suit. Bob D |
Thread: Where can I get very small (2.5mm) precision shim washers |
24/01/2013 22:33:37 |
Ian,
Have you considered nylon shims? http://www.rapidonline.com/Mechanical-Fastenings-Fixings/M3-Plain-Nylon-Washer-Pack-100-33-5064
They do 3x8 which can be put on a 3mm mandrel, tightened up and skimmed down to your 5mm O/D Bob D |
Thread: Free Speech |
18/01/2013 21:58:25 |
Don't blame Carol Kirkwood, she tells it like it is!
The Beeb's Breakfast told me more though, It was all tabletop railways, plastic helicopters and R/C trucks- not a machine tool in sight. Bob D |
Thread: Springs |
13/01/2013 20:43:53 |
PhilH,
You might get what you want from the assortment boxes at Screwfix and Maplin's have an assortment of compression and tension at £2.99 for 150 but the web detail is too small to make out sizes Bob D |
Thread: spiders |
08/01/2013 23:21:20 |
Hi,
Is it fact or an OWT that spiders will cluster around mains voltage cables? I've got one of those catchers. Its great as a guillotine for cutting spiders toe nails off when you rotate the thing round to capture the blighters. Bob D |
Thread: Rivet sets & snaps |
08/01/2013 16:42:21 |
Home use, Springbok put some pics of his and phone details to Arrand on this forum under "Rivet Set Dimensions" just 12 months back. Bob D |
Thread: Drawing Standards |
21/12/2012 23:06:01 |
Without politicising this debate, was it not the EITB ( Engineering Industry Training Board ) who some years ago instituted regular reports from firms regarding the "on the job training" they were providing as a means of firms evading the Training Board Levy and so give rise to the rank of Training Provider. Meanwhile, I do hope it stops raining soon and we can all get back to cutting metal but heres wishing all a Merry christmas Bob D
Edited By Robert Dodds on 21/12/2012 23:07:31 |
Thread: Screw thread handbook |
20/12/2012 09:41:54 |
I got a copy of The Presto book a few years ago and agree it is very useful. It seems to be downloadable as a pdf. and is called Counsellor. It is on http://www.presto-tools.co.uk/counsellor.pdf. A call to their office might get you a hard copy. Bob D |
Thread: Unusual thread |
18/12/2012 13:09:00 |
Merlin,
Do you think that the name Oliver is another Cockney slang based on Oliver Twist?. BobD |
18/12/2012 12:13:23 |
Merlin, I'm no expert in church metalwork and furniture but I did spot this archive with catalogues of church equipment. Two are UK names, albeit old catalogues and you might find your candle stick illustrated amongst them. http://archive.org/details/churchartinmetal00armo
Our "sponsor " is Brasso which gets into every nook and cranny but does not get polished out every time and then builds up a yellowly green scale in the recesses. Another source of info would be your Diocese Architects office. They should keep up to date catalogues of suppliers Bob D |
17/12/2012 22:55:58 |
Merlin, Being split dies it would be an easy matter to take 5/16 whit (18 TPI) and produce home made taps in carbon steel to near 1/4 dia x 18tpi (perfectly capable of tapping into brass) and then using the same dies, a little tighter, to thread the tie rods. Soft iron nuts would be similarly made with a carbon steel tap. There was no sophisticated measurement or concern about British standards let alone Metric or American. Parts were required to "fit" and interchangeability was low on the priority list and the candlesticks .bear witness to the fact that they can stand the test of time OK. The 50s/60s was an interesting time to enter an Engineering career, fortunate to be trained in modern methods but still able to see the traditional approach in the peripheral industries and then grafting onto that skills from both a toolmaker father and smithy grandfather. PS SHMBO is unhappy to think your church brasses only get an annual treatment . There is a weekly rota for polishing in our church! A bit OTT to my mind. Bob D |
