Member postings for Trevor Drabble
Here is a list of all the postings Trevor Drabble has made in our forums. Click on a thread name to jump to the thread.
Thread: New chainsaw
03/11/2012 23:46:16
John,
Can spot 3 problems straight away ! One is that the wing nut is at the back rather than the front where it should be , and also, assuming one is right handed, starting will be almost impossible , because the pull cord is on the wrong side of the handle ! And finally, the pitch of the teeth is far too coarse for normal use, which may explain why it was bargain. Assume they had run out of finer pitch versions ?
Trevor.
Thread: Myford Super 7
30/10/2012 00:02:31
Once again, many thanks gentlemen for all your inputs. The reason for the request is that I am in the process of negotiating the puchase of a S7with 3 phase motor of 1979 from my former employer, and needed to know what cost to start the amatisation from. I believe the machine is worth more than scrap value but significantly less than one sees similar 34 year old machines advertised for.
Trevor.
27/10/2012 00:37:56
John and HTH,
Thank you very much , these are excellent pieces of information, are most helpful and have helped me enormously with my small problem.
Once again, many thanks,
Trevor.
26/10/2012 11:13:47
Appreciate this may sound a strange request, but has anybody any idea how much a new S7 cost in 1979 please?
Many Thanks
Thread: Milling internal rectangles?
30/09/2012 22:03:25
Bill, Would like to offer the following suggestion. Since you dont especially need square internal corners, simply get rid of them. Fill the steam chest with an interference fit block of hardwood. Then carefully approach from above with a small diameter slot drill, with its centre directly over each corner point in turn. The block may then be removed since its function was to reduce the side stresses on the slot drill. Continue with the machining of the 4 sides of the chest as normal. You will then have an undercut in each corner which will allow the valve to fully enter the corner without interference.
Have drawn a simple sketch to explain. Not computor literate, so cannot get it onto these pages. If you supply me with your details, I will try and email direct, should you so desire.
Trevor.
Thread: Cutting oil
10/09/2012 00:13:02
Keith,
If you live any where near South Yorkshire, no problem in supplying your reasonable requirements free from me, but would apprecaite a donation to charity.
Trevor.
Thread: JB Weld
06/09/2012 09:54:36
Mick,
I have some CI sticks available for welding CI with Oxy-Acetylene. If you can find anyone local to you to do the work, then would post to you. I have used them to weld a 6" bench vice and they have worked well for a number of years. Please be aware though, the process is "heat hungry". I pre-heated extensively and then needed a No25 nozzle to do the actual weld. Afterwards the assembly was then put into a bin full of sand to slow the cooling process. In addition,please note that in such a stressful application, even Nickel rods require careful application if ultimate cracking is to be avoided. As an alternative, in some magazines such as Vintage Spirit and Old Glory I have seen adverts for companies who specialise in CI welding. Perhaps this would be a more viable option? Also, have you tried asking JB for their advice on this application? Hope this helps.
Trevor.
Thread: Drill chuck keys?
10/08/2012 00:29:32
Bill,
Unable to post picture. Please supply email address so that I may supply.
Many Thanks
Trevor
Correction, I now find it is actually attached. Hope it helps.
Edited By Trevor Drabble on 10/08/2012 00:30:47
04/08/2012 23:58:37
Bill,
The only readily available information I know of relating to chucks and their keys, is that shown within 2 tables of a Cromwell Tools catalogue ( page 750 of 2010 issue). There are no technical details, only correlations between Jacobs/Rohm chucks and various chuck keys, the model numbers of which I assume are universal within the trade. If you feel it would help, I can take a snap and email it to you.
Trevor
Thread: #3-48 on Elmers drawings - is this a standard pitch M3 die.
25/06/2012 00:11:48
Chris,
I believe you will find that this is a USA standard thread, a No3 x 48TPI UNC. As Engine Builder says, it would normally have a basic major dia of 0.0990, so 3/32 rod at 0.0938 is theoretically a little undersized, but you should get away with it. Tracey Tools ( no connection ) do a range of suitable UNC taps and split dies, with the carbon versions costing very little. For your information, die nuts are not meant for creating threads since they cannot be adjusted like a split die for fit, have less hook on the teeth as well as thicker legs. For these reasons, they are intended for cleaning worn or damaged threads only.
Regarding an M3 thread, this would normally have a basic major dia. of 3 mm ( 0.1181), thus making it unsuitable in this application.
Also, as stated, whilst there is no 3/32" ME thread, there is a 3/32" BSW x 48 TPI thread, which co-incidently has a basic major dia. of 0.0938, ie exactly the same as your rod, and again Tracey Tools have these available for relatively low cost.
I hope you will find the above info of interest.
Trevor.
Thread: Myford ML7 Trileva two speed
24/06/2012 19:57:19
Robin,
If I may add a little to this discussion, like Coalburner my theory is very rusty, but in essence, he is quite correct in that in a single phase motor the speed is determined by the number of poles, assuming the frequency stays constant, the theory being n=f divided by p. ie it is inversely proportional to the number of poles, and the number of poles in use at any one time is achieved by varying the 4 coil connections so as to achieve either 2 or 4 poles as required.Since my computor skils are virtually non-existant, I will try to describe from memory the theoretical connections in words. If you draw a square with a single coil on each side, and starting from the top of the square work in a clokwise direction, notating them as A,B,C and D. If you connect live between A-B and neutral between C-D this should give you 2 poles. If you then change the live connection to between A-D, with the neutral between B-C, then this should give you 4 poles. These 2 arrangements should result in the same flow through B and D on each occassion, and the flow A and C being reversed on the second occassion. I believe this is why you have the 4 wires + earth on your installation. These switching arrangements are perfectly feasible with a propriatory multi-pole switch such as theDewhurst you already have. In the interests of safety, I would suggest you also check this information with a better authority than I, such as a motor or switch manufacturer as well a local electrician/re-wind company who should be well versed in motor installations. In addtion, please ensure that the completed installation is fully tested by a suitably qualified person and that you receive the appropriate test documentation, it will be money well spent. If any of the foregoing are not available to you, then would suggest you investigate alternative solutions
I hope you will find the above of some use.
Trevor
Thread: Myford VM Milling Machine
20/05/2012 18:10:27
David,
No disrespect intended, but are you sure the machine is a VMB? I have a VMB and to the best of my knowledge, Warco have not, and in fact still do not offer their version of this machine. My understanding is that it was only availble from Myford. I believe you actually mean one of the other VM .... variants which they do indeed sell.
Chris,
Can supply a copy of my VMB manual if you still need one.
Thread: lathe belt
04/12/2010 23:07:06
   As a Myford user, I have so far found this thread extremely interesting and enlightening..........
Thread: Valve gear - looking for a good introduction
08/06/2010 22:19:13
Clive,if you are interested, I have a second-hand ex-library copy of Model Locomotive Valve Gears by
Martin Evans available for sale for which I am looking for £10 + p&p at cost.
It is in good general condition. Pics and contact details can be supplied if required.
Thread: New Machining In The Home Workshop Special
30/05/2010 00:37:26
  Yesterday I also received a similar email from MHS within a few hours of ordering my copy, which surprised me somewhat considering the publication date. Another instance of MHS outstanding efficiency, or maybe crossed wires somewhere ?
Thread: Harrogate show
26/05/2010 20:44:13
   I believe the company was from York, and in front of either the South Road Steam or Maxitrack stand.Maybe either of these companies could help, or maybe the show organiser, Lou Rex, who may have listed them in the show guide ? Feel sure I collected a card from their stand, buy afraid I cannot find it at the moment. Ah, the pleasures of getting old!!
Thread: How to drill hardened and ground steel
17/05/2010 23:55:54
John, Have just read your entry and the subsequent notes with interest. Have you considered whether it would it not be better to produce a new shouldered post threaded to suit the top slide and necked down to suit your new QC tool post ? If, for whatever reason you are unable to do this, how much is a new post from Myford, which you could subsequently turn down to suit ?
Thread: Marking out fluid
05/05/2010 22:56:10
Eric, if you feel it would be of assisstance, I am prepared to obtain a small container  to supply you with maybe 50mL of  marking out fluid, and I would be able to deliver it to you at Harrogate on Sunday if that is acceptable.
