Member postings for Alan Jackson
Here is a list of all the postings Alan Jackson has made in our forums. Click on a thread name to jump to the thread.
Thread: Best grease for taper roller lathe spindle?
09/11/2021 16:48:36
I thank you all for your suggestions and have decided to use Silicon grease with Teflon. I seems to be a bit quieter when running so all is good.
Thank you
Alan
Thread: Alexander master Toolmaker Mill
09/11/2021 16:13:04
Very nice restoration Mark, it looks new
03/11/2021 17:38:23
I am about to regrease my Stepperhead lathe spindle just to check the bearings etc. At present the bearings are lubricated with moly grease, but I just wonder if there is a better choice.
Alan
Thread: Mc Donald Model tractor
28/10/2021 11:02:29
Fred,
Your whole tractor project is stunning in your execution and just simply brilliant. Wish you every success.
Alan
Edited By Alan Jackson on 28/10/2021 11:06:33
Thread: Parting off - front or rear
16/10/2021 11:03:19
I use this vertical parting tool on my Stepperhead lathe
https://www.youtube.com/watch?v=S8HvS13L7MU
and a rear mounted HSS parting tool on my Chipmaster
Both work well
Alan
Thread: Back to Imperial
18/09/2021 10:33:11
Just ask most people what is their height and weight to see how thoroughly they have adapted to the metric system.
I bet a pound to a penny they mostly reply in imperial. That's my two cents.
Alan
Thread: Purpose of screw on keyway
30/08/2021 16:40:17
I think the reason is that the end of the screw bears on a flat surface that can accept the slight gourging that the end of say an allen type grub screw will leave on the top surface of key. If the grub screw is oriented anywhere else it will score the shaft, making removal much more difficult.
Alan
Thread: Lathe improvements?
27/08/2021 09:31:58
Hi Niels
If you zoom up on the second photo you can see the screw heads in the chuck bore.
Alan
26/08/2021 18:29:02
Hi Niels,
Thank you for your kind comments. The screws are secured by locked screws that can be reached inside the bore.
Alan
26/08/2021 18:11:19
Hi Niels,
Re your narrow chuck, here is my own design narrow four jaw 6 inch chuck. The body thickness is 30mm. The jaws are guided by an oval gib that can be adjusted to eliminate slackness in the jaw guidance.
Alan
Slim bodyJaws extended
Thread: Looking for solution to incorrigibly jumpy needle roller bearings
17/08/2021 10:19:49
I have an older Stihl hedge cutter, electric motor driven. The con big ends have plain bearings (no needle rollers) It has been working hard for over 20 years and still carries on. the big ends and crankpins are slightly worn, it gets hot but still carries on, much like its operator.
Alan
Thread: Setting up rear parting tool properly
21/07/2021 17:55:05
This is much more rigid than the boat toolholder. The base block has a shallow slope enabling the cutting tool height to be adjusted.
Alan
Thread: Tool post height
09/07/2021 17:27:37
Posted by JasonB on 09/07/2021 11:22:31:
Alan, unless I'm missing something the holder still has no direct line of support under the tool and is over hanging from the toolpost which is the "disadvantage" people are talking about
Jason, You are quite correct but the cutting tool does not reach (cantilever) beyond the lower support so there is no moment created to make the topslide tend to flex or pivot. If I need a more solid toolpost I use a four way or triangular toolpost.
Alan
Edited By Alan Jackson on 09/07/2021 17:37:32
09/07/2021 10:32:12
MLA version QCTP with no overhang
Alan
Thread: Uncertainty of Measurement [Global Warming]
07/07/2021 10:39:22
If they made the vertical scale more realistic say max 4 degrees then the chart would show a much less steep rise. Just what you can do with manipulated charts and figures.
07/07/2021 10:30:21
I entirely agree with SOD and Martin Kyte that the QCTP fitted to a typical small model engineer's lathe suffers from inherant problems, lack of rigidity due to less than perfect fits between the many introduced contact surfaces and increased cantilevered overhang from the support point below. These to reasons alone contribute to more problems than are solved by a QCTP.
Alan
Thread: Motor drive - belt, gear or direct?
21/06/2021 10:07:30
This what I did
Alan
Thread: Fretting in Scunthorpe
21/06/2021 09:59:49
I bet the fuel tank is intact
Thread: Theoretical Taper due to tailstock height misalignment.
04/06/2021 09:40:07
Vertical misalignment will make a small error, but horizontal misalignment will make much more error simply because the cutting tool moves in a horizontal plane.
Thread: Joe's Rocket
22/05/2021 11:37:58
He is my grandson's latest creation. When he goes into my shed he likes to invent something, he is five years old and shaping up well as a future model engineer. After he left this creation, I took the liberty to glue it together, hope he approves my input when he sees it, otherwise I'm in big trouble.
Alan
