Here is a list of all the postings Baldric has made in our forums. Click on a thread name to jump to the thread.
Thread: How to cut tungsten carbide? |
16/07/2012 15:27:53 |
If these are for a planner I guess that owing to the speed these operate at you will need to ensure the lengths are identical otherwise the blades will be out of balance, which will cause problems. |
Thread: Tools |
09/07/2012 09:06:17 |
Posted by Charlie, on 05/07/2012 21:56:52: There where a number of long tapered drills,Cant imagine what they are for?, Could they be bridge reamers? **LINK** I have used them to align holes for riveting, but we are talking full size locomotives here. |
Thread: Meccano Model? |
01/06/2012 16:17:44 |
Is that a BBC film crew for Bang goes the theory? If so any idea when it will be on? |
Thread: Ball turning tools |
17/05/2012 16:04:22 |
Thanks for all the replies, it seems that one is not better than the other in a major way, almost it is a matter of personal preference. I will spend a bit more time pondering before doing anything. Baldric. |
16/05/2012 16:48:49 |
Thanks for the responses so far. I will be actually making a ball on the end of a rod for a steering joint, but can alos see it being usefull when making globe valves and other itmes that need to loo pretty. Mike, I can see why you ammended the tip holder, it looks very good. |
16/05/2012 13:25:24 |
I am going to need to turn some balls in the near future as will need to make or buy a tool to use on my lathe. As I see it there are 2 types:
Which is easier to use? Looking on youtude option 2 seems easier as once the the ball diameter is set it can be left and just use the cross slide to feed in to the work. Is one type more flexible than the other? If so why? FYI I have a Boxford so will be looking to use it on that. Baldric |
Thread: Surface table alternative? |
10/05/2012 09:04:01 |
It has been suggested to me that one of the granite type kitchen worktop savers (chopping board) you get in a supermarket for about £15 are ground flat, this has seemd to be true with the one I have. |
Thread: Increase in standard parcel postage rates |
03/05/2012 14:07:42 |
But some companies add it later because they sell direct and delivered. I tend to create an order and go as far as finding out the total price, using that as a comparison. Some firms will also add P&P once rather than adding it for each item, handy if ordering many items in one go. |
Thread: Carbide Tip Sises |
19/04/2012 13:02:27 |
I think there was an article recently in either ME or MEW that detailed the meaning of the codes for the tips, the first few items include the tip shape, clamping method and size, after that I think is material but that may be manufacturer dependant. In theory standard tips of the correct type should fit any tool holder, From my limited experience I have found that the easy way of seeing what tip a tool uses is seeing that suppliers part number. I also think that limiting the number of tip types you have makes sense. I have a couple of tools that use CCMT9 tips these are 100 degree diamond shaped, one of the tools uses the other 2 corners to get the most out of the tips. |
Thread: Getting a boiler tested |
13/04/2012 08:01:11 |
Do clubs appreciate people who only turn up for a boiler test or are they deemed as people taking advantage? I am asking this seriously as if that is the route I go down I don't want to upset people. I do note that there is the "model road steam vehicle society" for me they may be a better bet. Are there other groups around who club together to get several boilers tested in one go to share costs? As I said for me this is in the future so just hopeing for information at the moment. |
12/04/2012 13:28:04 |
Posted by Bazyle on 12/04/2012 12:55:08:
But understandably club inspectors do get a little miffed by people who only join to get a boiler inspected in order to sell it at a higher price. Bear in mind it takes 2 people an hour or so to do the test so they would hope for at least an equivalent input to club activities. I am no where near the boiler stage yet but it is because I would feel that I would be taking advantage of the free facility and not putting anything back in to a club that I may not join one, however I am not sure what I will do about the boiler inspections. If I had more time than a few hours on odd evenings during the week the matter may be differrent. What are the other real options open to someone who can't or doesn't want to join a club? Baldric PS it is because of this and not having room for a track that I decided to build a road vehicle. |
Thread: Warco minor mill/drill |
29/03/2012 16:49:18 |
if it is similar to the major then the black knob in the middle of the course feed is screw in to engage the fiine feed, out to disengage. |
Thread: What is this ? |
28/03/2012 13:11:56 |
Looking again not sure why it would have a dovetail on the bottom though unless is was modified for use on your mill. |
28/03/2012 12:53:49 |
It looks like the support from a shaper, these add additional support to the table, see here and here |
Thread: Tapered head / cylinder interface |
19/03/2012 09:44:40 |
I think you will find that the valve covers on standard GWR cylinder blocks are fitted like this, occasionally you do see a gasket but it is loose so does nothing! |
Thread: New website editor |
17/02/2012 09:49:23 |
Posted by Terryd on 17/02/2012 09:43:53:
Posted by clivel on 16/02/2012 19:41:18:
Quote no longer works for me using FireFox 10.01 on Windows 7................... But it works with FF11 on XP. perhaps Windows 7 is the culprit? Regards Terry It now works on Windows 7 with IE9, when I tried about an hour ago it didn't! |
Thread: WHITE METAL BEARINGS |
27/01/2012 08:11:34 |
In preservation I have used Summit Solder Products, they are part of another firm and i am not sure they use the name, but here is their website.
Thread: Finishing leaf springs |
05/01/2012 08:20:28 |
The drawing does state BDMS and in the model engineer article the author state something like "use bright drawn mild steel, with no further heat treatment, it has worked for me"
Would you recommend tempering then? I guess that will produce a slightly softer spring as any hardness due to working the material will be gone.
Baldric |
04/01/2012 08:20:32 |
Bob
Thanks for that I will try option 3, looking at another thread I will use a heat treatment oven I have access to as my home oven only goes to 250c.
Phil
The springs are working springs, they are quite hard but there is some spring in them, I guess they need to be harder than scale as they will need to take my weight.
Baldric
03/01/2012 14:55:11 |
I am making a 3" Foden and have just made the leave springs for the rear using BDMS as specified in the drawings. Before final riveting has anyone got suggestions on how to finish them? The options seem to be
1. Paint after finished
2. Chemical blacking
3. Heat and drop in oil
Should a grease be put between the leaves or just left with nothing between them?
Baldric. |
