Here is a list of all the postings Dennis R has made in our forums. Click on a thread name to jump to the thread.
Thread: Electronic Lead Screw Project |
26/11/2020 21:07:28 |
A quick update. Finally got a very good thread 3/8" x 16tpi ( thread picked because had a nut and die ), by leaving the half nuts engaged but using the VFD reverse function rather than reverse on the control box. Thanks again for the tip Alan So will leave for now, more experimentation if time allows. Dennis |
Thread: Calling all Startrite Mercury drill owners - opinion on noise |
25/11/2020 22:37:46 |
Just checked my floor standing model, pullies 9mm at top and belt fills groove, belt is a Picador Z995. Belt has been in service for at least 20 years and no problems. Dennis |
23/11/2020 21:59:27 |
Thankyou for the replies and suggestions, over the next few days will check everything that I can and report back hopefully reporting a success. Thanks again Dennis |
22/11/2020 23:30:58 |
The half nuts were left engaged and the lathe reversed after backing off the cut. Dennis |
22/11/2020 22:45:07 |
Problem with ELS Having set up my hardware on the lathe using a stepper/servo motor and driver CL57Y , the motor encoder resolution being 1000 and the motor to leadscrew drive being 1:2 ratio. Decided to test the set up whilst all the electrical side was still on the bench, with a light cut on scrap went through most of the thread TPIs and feed rates and all seemed well. However on attempting to cut a 20 tpi thread it turned out very rough and difficult to see exactly why, so cleaned up end of bar, blackened with permanent marker, changed to 8tpi, put on 0.003" cut and got a perfect first pass, but on second pass with same 0.003" cut was approx 1/16" away and on subsequent cuts filled the bar end. Even tried changing software back to version 1.1 made no difference. See photos
Thanks Dennis |
Thread: Live Steam Brevete Stork Leg Loco renovation |
23/10/2020 20:55:29 |
Hi Alan Threads 1.2mm (0.047" ) o/d are 13 BA size. Dennis Edited By Dennis R on 23/10/2020 20:56:16 |
Thread: Engineering Sights on Google Streetview |
03/10/2020 23:21:33 |
Steam engine in Darwen Lancashire with India Mill Chimney in the background https://www.google.com/maps/@53.69148,-2.4664448,3a,75y,90h,89.99t/data=!3m6!1e1!3m4!1sS7KmM1IyAV5I9NwqaMfCgg!2e0!7i13312!8i6656 Dennis |
Thread: Clarkson autolock help |
28/04/2020 23:55:11 |
Go to this site for instructions on Clarkson Autolock chucks. Dennis |
Thread: Startrite Mercury drill |
21/04/2020 22:54:54 |
My old Startrite floor standing machine, serial number 73698 has a 5/8" x 14 BSF thread, confirmed with thread gauge. |
Thread: Websites for the Bored |
25/03/2020 22:37:29 |
As a volunteer at the Bolton Steam Museum I can thoroughly recommend this site https://nmes.org/ , with its large collection of mill engines and ancillaries. Dennis |
Thread: Silvers soldering |
24/02/2020 19:24:05 |
Tipp-ex rapid double pack is on offer at £2.99 in W H Smiths today, seems very good value. Dennis |
21/01/2020 20:11:48 |
Dias I made top hat buttons with slightly domed heads from a small piece of hard plastic found in my scrap box, they were all made circular. Where Clough42 has triangular buttons mine are a larger diameter, a bit fiddly to do, just make one and try for size then adjust as necessary. Dennis |
23/12/2019 22:11:11 |
Mine was due anywhere between Jan 2 and Feb 12, but arrived early on Dec 18, very fast service. Dennis |
Thread: Castings, creating a datum before milling |
21/12/2019 18:05:58 |
Garry There was a series by Stan Bray in Model Engineer under the heading of Bray's Bench starting in Vol 176 No 4009 in 1996 about building "Tina" from the castings from GLR Kennions together with a follow on of building the boiler. Harold Hall also did part of the engine in one of his series in MEW, I think on using a milling attachment he had made. Dennis |
06/12/2019 23:04:29 |
Came across this example of an all in one package for a Nema 34 with driver and power supply, do you think this is a good deal and would be OK for an ML7? Dennis https://www.ebay.co.uk/itm/8-5Nm-NEMA34-Stepper-Motor-Driver-Power-Supply-Closed-Loop-8-5N-m-Hybrid-Drive/223770601237?_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D1%26asc%3D61046%26meid%3D273350ecaba14a628828b44ff26609cb%26pid%3D100005%26rk%3D1%26rkt%3D12%26sd%3D283094369235%26itm%3D223770601237%26pmt%3D1%26noa%3D0%26pg%3D2047675&_trksid=p2047675.c100005.m1851 Edited By Dennis R on 06/12/2019 23:07:34 |
Thread: Back saw for cutting steel and brass? |
27/11/2019 22:56:16 |
http://www.morgancarbon.com/pl/files/morgancarbon-pl/martindale-motor-repair-hand-tools.pdf Dennis
Thread: Interface PCB for the ELS project |
06/11/2019 00:01:34 |
Hi Phil, Would like a PCB and component set please when they become available. Many thanks |
Thread: mystery tool |
11/09/2019 23:52:58 |
They are valve seat cutters, the tapered threaded part screws into different size valve holes inorder to make it more adaptable. Dennis Beaten to it! Edited By Dennis R on 11/09/2019 23:54:02 |
Thread: Metal Cutting Power Saw |
11/03/2019 22:26:25 |
Hi Try this for the Aldi bandsaw mod https://www.youtube.com/watch?v=s0cLgifKeFY Dennis |
Thread: Another gas engine question, sorry! |
04/02/2019 23:02:05 |
Alan Usually there is a hole in the side of the piston above the little end, so that oil can drip through from the cylinder. Dennis |
