Member postings for Michael Cox 1
Here is a list of all the postings Michael Cox 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Gear wheels
04/12/2009 13:45:48
You could try:
I have not bought gears from them yet but I can say that the service on other items I have bought has been excellent.
Thread: HELP Wanted! Cutting Metal - But By What Means?
01/12/2009 08:13:10
Hi Chris,
I cannot comment on the motorised hacksaw because I have no experience of them.
I have an Axminster 4 x 6 bandsaw that cost around £105  2 years ago. It is very good and copes with all my cutting needs. I do use the saw in the vertical mode but would recommend that you throw away the flimsy saw table supplied and make sometig more solid. However, this saw is big with a footprint of about 1200 x 600. It is quiet in use and it does not make much mess at all.
Before buying the bandsaw I used an old, cheap mitre saw fitted with a 9" metal cutting abrasive disc to convert it to a chopsaw. This is extremely moisy and grit and dust go everywhere. You cannot use it anywhere near machine tools such as a lathe. In addition it is a fire hazard. Hot sparks shoot out a considerable distance. Definitely for outside use only. The abrasive discs do not last long.
I also have a 4 1/2" angle grinder with a stand. Both came from Aldi /Lidl and cost only a few £s. I use this with Norton thin metal cutting discs for cutting hardened steel but the maximum size of material that can be cut it limited to circa 1" thickness. As above it is noisy, dirty and a fire hazard.
Thread: Which Cutter Grinder?
19/11/2009 11:16:15
Amadeal (www.amadeal.co.uk) are offering a simple jig, similar to that designed by Harold Hall, for £120. Look in the section called "other machinery".
Thread: Cleaning up corroded dials
18/11/2009 18:58:43
Ferric chloride will etch steel, Frank. It is a standard etch used in the metallographic examination of steels. On badly polished samples it will reveal the lines caused by the initial grinding the steel on wet/dry paper even though the polished surface is quite plane. It was this latter observation that prompted my original comment.
18/11/2009 10:40:18
I dont know whether this would work but you could try etching the cleaned up surface with ferric chloride solution (this is easily obtainable from Maplin as it is used for etching printed circuit boards).
It is likely that the etch would attack areas of stressed metal faster and the most highly stressed areas will be those around where the graduations were scribed when the dial was made.
Thread: Hints and tips
12/11/2009 17:33:49
Hi Niloch,
I agree that the Geometer and Artificer articles are very interesting.
I cannot help with your problem with the Griptru chuck but perhaps the following helps in respect of your other questions.
To set up a piece running true in a 4 jaw I use the procedure given on www.littlemachineshop.com . This works for me.
In Tubal Cain's engine I suspect that the flywheel is supply as a casting. This is gripped with the inside jaws of a 4 jaw and then spun slowly. Then approach the wheel rim slowly with a piece of chalk. The point furthest from the centre then gets chalked. Adjust the chuck to move this point closer to the centre. Repeat this procedure until the whole of the rim is chalked. This procedure is good for castings because they are so rough that a normal DTI would flicker all over the place.
Thread: Boiler making hearth
07/11/2009 16:14:44
I always use aerated concrete blocks (thermalite or celcon). These have great insulating properties and they are very cheap and they certainly easily withstand brazing temperatues. Any builders merchant stocks them as do Wickes. A few broken pieces of block are good to pack around the parts to be heated.
Thread: Clarke CL300 Speed control
04/11/2009 22:30:38
I have had my CL300 lathe for 5 years and have only had one problem that was due to the switch attached to the speed control board failing.  The failure was a purely mechanical problem with the switch. Unfortunately the failure lead to the mosfets and diodes. I ended up buying a new controller board from Clarke as well as the replacement pot.
Other than that I have had a few jam ups causing the fuse to blow but this has lead to no damage to the circuit board.
Thread: Screw Cutting Dog Clutch
16/10/2009 18:51:31
Hi tony,
Have a look at www.gadgetbuilder.com. There is a description of a dog cluch fitted to a minilathe.
Thread: Rear mounting parting-off tools
15/10/2009 22:32:32
David, I agree with your analysis why rear toolposts are better for parting. Your drawing is excellent.
Thread: Mini Lathe and Milling Machines
15/10/2009 14:18:22
Try looking on www.arceurotrade.co.uk . They have the 7x 14 asian minilathe and various milling machines.
Also look at www.amadeal.co.uk. Their machines are very competitively priced and will even supply the 7 x 14 complete with a 4 inch chuck rather than the normal 3 inch.
I have had dealings with both companies and service from both is excellent.
13/10/2009 13:13:32
Interesting comment David and I have seen the same mentioned before. However, I cannot see that the fact that the cross slide lifts up into the dovetail is any more rigid than when the cross slide is pushed down onto the solid surface under the cross-slide.
The main reason why a rear toolpost is more effective is, in my opinion, that it is less rigid and in the event of a "dig in" the toolpost can deflect upwards and backwards to release the dig in.
With  a front mounted toolpost, in the event of a dig in, the tool is dragged round under the workpiece and it is jambed between the the workpice and the cross-slide causing it to dig in further.
Thread: Case Hardening
09/10/2009 16:27:59
Hi Peter,
The use of coaldust is not recommended. It has a high sulphur content that will adversely affect the case hardening. Fine powdered charcoal will work ok especially if mixed with sodium bicarbonate (baking soda). A 90% charcoal dust with 10 % sodium bicarbonate works well for pack carbonising.
09/10/2009 16:22:32
Hi Tony,
There are two main advantages to a rear mounted parting off tool. Firstly, with a conventional front mounted tool, if it digs in the tool tends to go under the work piece and is wedged between the workpiece and the topslide because the lathe is very rigid and this tends to make it dig in deeper. If the same happens on a tool mounted in a rear toolpost then the tool tends to ride up on top of the toolpost and the toolpost is deflected away and hence the tool tends to "undig" itself.
The second advantage of the rear mounted toolpost is that the chips tend to fall away rather than collect in the parting groove so there is much less likelihood of the tool jamming in the slot due to chips wedging between the tool  and the groove.
If you have a flange mounted chuck and can reverse the drive then the same result can be had by mounting a parting tool upside down on the front side of the lathe. If the chuck is mounted on a screwed mandril nose piece this cannot be done because the chuck will tend to unscrew.
I have fitted a rear toolpost to my Asian minilathe and the difference in parting performance is amazing.
Thread: Diamomd tool holder
05/10/2009 15:11:50
In view of current interest in this subject and also the article in issue 156 MEW I thought others might be interested in yet another design of tangential toolholder.
This photo shows the completed toolholder mounted in the lathe:
It is easy to see the 12 degree inclination of the tool in the forward direction in this photo.
The next photo shows the end of the toolholder shank:
This shows that the shank is trapezoidal and this inclines the tool 12 degrees from the vertical towards the head stock. The next photo also illustrates this point somewhat more clearly:
The advantage of this mode of construction is that the whole tool is made from a piece of 1/4" plate. It is only necessary to mill the slot for the tool at 12 degrees and then file or mill the shank to have the 12 degree trapezium angle. These are very straightforward operations and the whole tool can be made in 3 hours.
I hope this is of interest.
