Here is a list of all the postings Ian S C has made in our forums. Click on a thread name to jump to the thread.
Thread: Hello from Somerset |
22/06/2019 12:05:25 |
Hi Chris, good to see another Stirling Engine fan, I'v built a number of them, but no kits or castings. Ian S C |
Thread: How to de-oil an oilstone? |
21/06/2019 12:21:46 |
A way of resurfacing a worn oil stone is to use a face mill in the vertical milling machine, use worn out tips in the face mill, keep the speed down. I think I spotted the idea in an old "Model Engineer" mag. Ian S C |
Thread: Boiler cross tube leak. |
21/06/2019 12:10:12 |
Soft soldering needs more cleaning to get is right. Ian S C |
Thread: Odd sized strong bar |
19/06/2019 12:43:44 |
Some of the 1/4" drives seem to be nearer to 6 mm, the sockets seem OK, just the drivers are a bit sloppy. Ian S C |
Thread: Model Engineers to Give Away |
19/06/2019 12:03:31 |
Thomasin, you can contact Barrie using the personal message system, you will find that at the line just under the message box, go to Barrie's message and click " Message Member". Ian S C Edited By Ian S C on 19/06/2019 12:05:54 |
18/06/2019 14:43:49 |
A case of you buy our strong arm, you buy our sockets. Ian S C |
Thread: Improving runout in a slitting saw |
18/06/2019 14:15:43 |
I was watching U tube the other day, the chap was using a slitting saw, he mentioned that all the saws tend to ching ching, but once he got cutting he upped the feed until he got continuous cutting sound. Ian S C Edited By Ian S C on 18/06/2019 14:16:22 |
Thread: Thomas from Hornby |
18/06/2019 14:08:49 |
I needed a 3 flute screw driver, so I ground the end of a worn out Philips screw driver, then with the Dremel tool ground in the 3 flutes, job done, now I'v got a screw driver that I'll probably never use again. Ian S C |
Thread: Horizontal mill cutter |
18/06/2019 14:02:27 |
Even my Rexon vertical milling machine has about 1.5 hp, and that at times feels underpowered, I would say 2 hp would be a starting point for a horizontal mill, maybe 2.5 hp if electronically controlled. Ian S C |
Thread: Model Turbines |
17/06/2019 16:10:42 |
A generator run on a small turbine, or any small power source would be pushing it to get to 50% efficiency, so there will be quite a difference between the electrical output and the brake HP measured with a Prony Brake, an interesting little experiment on it's own. Ian S C |
Thread: water supply |
17/06/2019 15:54:31 |
Ask the cricketers where the water comes from(World cup cricket at the moment in England and Wales). Ian S C |
Thread: Free cutting mild steel |
17/06/2019 15:44:59 |
I find no difficulty turning hot rolled "mild Steel"(no spec) with a fairly worn Box-Ford A using HSS or carbide tools. Ian S C |
Thread: Cheap Carbide Lathe Tools |
17/06/2019 15:36:36 |
For a handy source of tips for the like of small boring bars get hold of a worn out carbide tipped circular saw(one of those round things with teeth for cutting brown stuff), remove the remaining carbide teeth, these can then be brazed into a home made tool holder. Watch out the tips are ground alternately left and right. Sorry it does not show up too well. Ian S C Edited By Ian S C on 17/06/2019 15:37:49 |
Thread: Super Mini Lathe belt problem |
15/06/2019 12:57:04 |
My answer to quality complainers is if you can make for the same price at better quality why are you not doing it. Admittedly quite a bit of the price goes to the retailer in mark up. Ian S C |
Thread: Naerok 350 mill |
15/06/2019 12:39:54 |
If you put Naerok in the search window just above your name at the top of the page you will find a manual there that you can save or down load. I found it handy as I have the same mill although here in New Zealand it is called Rexon, still made in Korea. Ian S C |
Thread: spindle bearings |
15/06/2019 12:25:40 |
Just follow Ketan's advice, he knows bearings. Ian S C |
Thread: Reference books |
13/06/2019 11:29:50 |
I have a centre fold chart in the workshop, can't remember if it came from Model Engineer, or Model Engineer's Workshop. Ian S C |
Thread: Class 22 Diesel (next project) |
11/06/2019 14:27:00 |
Ron, I'd tend to use hard shim washers, similar to those found in electric motors, if I need them, and can't find what I want in the junk box I go to my bearing supplier who has all those sort of goodies. Some times there is a nylon/plastic washer between two steel washers. Ian S C |
Thread: Hello from Tyneside and micromilling turbine blades |
11/06/2019 13:23:38 |
Welcome Mike, yes we would love some pics, your contraption doesn't need to be beautiful to be photogenic. Ian S C |
Thread: Model aircraft pilots angry over drone laws |
09/06/2019 14:22:24 |
Members of model aircraft clubs pay a membership fee, and as members have training classes, and are schooled up on CAA regs covering their sport. There is quite a bit on "drones" in the Wings over New Zealand web site, I tghink it's in the NZ Civil aviation section. I know that there are some model aircraft in the Christchurch club that could in the wrong hands do major damage. Ian S C |
