Member postings for ega
Here is a list of all the postings ega has made in our forums. Click on a thread name to jump to the thread.
Thread: Cast iron welding electrodes
29/10/2019 09:45:28
Some special rods do better at 80 volts. Heating the work might also help, as might peening the weld as it cools.
Thread: Packed Boring Bars
24/10/2019 14:19:43
Posted by Brian Wood on 24/10/2019 10:52:40:
ega,
I saw only coolant pouring out of the chuck, not chips. I did also wonder if the timber " cushion" was being shaped by the cut edge of the hole being bored as the bar was powered down into the hole. They were described as sacrificial so I assume new ones, roughly shaped, were fitted for each tube being bored.
Clearly the lathe in use had a long bed; it was rather frustrating not to get a view of the holding arrangement on the saddle end of the boring bar. The process did leave a nice looking finish ready for honing to size.
Thank you Clive for the link, it was interesting and a process I have not seen before
Regards Brian
Brian
Thanks for your comments on my post. There certainly was coolant but at times I struggled to see where the large chips being produced were going. The video did indeed make clear that the timber cushion was cut to size by the sharp edge of the bore.
Plus one for your comment about the holding arrangement. The secondary steady reminded me of the bushing steadies favoured by Martin Cleeve.
23/10/2019 17:00:47
Posted by Clive Foster on 23/10/2019 14:26:08:
"mutant golf club" style tool
What GHT likened to Harry Lauder's walking stick!
Thanks for the link. Those prepared timber blanks look like oak or ash; presumably turned and then split in two. I wonder how this method would work in a blind hole; in the video the chips seemed to be exiting at the chuck.
Thread: Not really an engineer from NW England
23/10/2019 11:15:44
Allen
Might you post some photos of your woodturning tools and accessories (an interest of my own)?
Did you ever meet the other half of Duplex?
Thread: Internet searching
17/10/2019 11:13:20
Posted by Kiwi Bloke on 17/10/2019 08:38:47:
Michael, just be careful with Google - all your searches are stored, linked to your identity, as part of Google's 'big data' initiative. You have been probably been recorded as searching for a male model...
A good reason for using DuckDuckGo although it seems US-centric and sometimes doesn't find things Google can.
Thread: Free software and human nature
17/10/2019 11:09:19
I am a very satisfied user of a free, simple notes app called Rdex. Amongst other things, it helps me keep track of workshop equipment on PC and Android phone. Here is the link to to the author's website:
http://pnewman.com/rdex/rdex-windows.htm
In this kind of situation, apart from thanking the provider and giving "feedback", I "pay forward" ie, try to do something for someone else.
Thread: Anyone know about buying freehold to a house in the north
16/10/2019 16:39:07
I assume the property is in the north of England and that there are no intervening leaseholds ie it's just a case of your long lease and the freehold.
The first thing to do is to read the terms of the lease carefully and then decide whether buying in the freehold would be advantageous.
If the property is registered then the transfer of the freehold is straightforward.
Thread: Reilang oil cans
13/10/2019 11:18:56
Posted by KWIL on 12/10/2019 09:48:07:
I use more than one spec of oil so have many Reilang oilers including lock on fitting for hydraulic type nipple. Best kit around.
I have a Reilang with a flexible connector for hydraulic nipple which worked well until I managed to break the lever when trying to get oil into a stubborn nipple.
I would be interested to know the model of Reilang you are using for this purpose.
Thread: Telescopic bore gauges
09/10/2019 16:28:24
Posted by not done it yet on 17/04/2019 09:56:27:
Emgee,
What do you refer to as a ‘digital vernier’? Is it an analogue digital instrument?smiley
This misnomer is unfortunately too well-established to be suppressed.
Thread: Myford Super 7 Top Slide Base - Alternatives?
09/10/2019 11:26:06
PS I notice that Graham Meek offered "bias" as an alternative, too.
I hope he can be persuaded to write up his adaptation.
09/10/2019 11:19:26
MichaelG:
Thanks for the link which I will pursue. In the meantime, as a patent buff, you may be interested in the three point arrangement of the Tormek work rest which I hope is clear from my photo:
The wedging action is such that when the black knurled clamp screw is loosened the rest retains its position but is readily removed.
I would accept "urge" to describe the action of the clamp here; in other situations, "bias" might be appropriate.
08/10/2019 15:37:53
MichaelG:
You are correct; I assume the reason is to achieve a greater wedging effect.
The design is something of a compromise and I think the "lowly" version has the advantage of better clamping.
Edited By ega on 08/10/2019 15:38:41
08/10/2019 14:50:52
Posted by Hillclimber on 08/10/2019 14:07:00:
Posted by Adrian 2 on 26/06/2019 10:24:20:
I wonder why it has cracked ? Are the thrust pads present and correctly installed in their respective holes? They are handed and easy to fit incorrectly.
Adrian.
Reopening this old thread, I finally realised the significance of Adrian's comment about the thrust pads being handed. Yesterday I was scanning a parts list and found that the right and left pads have different part numbers. Today I was cleaning and adjusting my cross slide.
I had noted that despite my caution in nipping up the pads on the topslide, there were new, uncomfortable marks where why former topslide base casting had broken (like Nicholas's). So I pulled out the pads and sat them on the casting, where they also looked uncomfortable - flipping them around, they looked more naturally poised.
It is difficult to describe the geometry of the respective surfaces, and I have no idea how to tell the pads apart visually. But knowing that they are different, and checking for natural 'poise', I'm hoping this is the solution...
Cheers, Colin
I have found it possible to tell one from the other by feel. They could be marked in some way. Of course, none of this will be easy if the wrong-way-round pads can't be removed from their bores!
BTW, isn't the Gibraltar toolpost secured in the same way and therefore rotatable, too? (Your earlier post refers).
Thread: Creating Heat for Hardening
08/10/2019 10:55:41
Don't forget the magnet test.
Thread: Grinding wheel 'washers'
07/10/2019 23:44:35
Unless your flanges are rustproof I suggest you make the blotters from something that won't harbour moisture.
Thread: Dore Westbury Boring/ Facing Head instructions?
07/10/2019 14:43:23
In the earlier photos there was no cutter in place so for the purpose of the photos below I have just picked one out at random and installed it. The bar and cutter are entirely straightforward and made to GHT's words and music.
BTW, I am not sure that ETW had anything to do with this; the DW mill was, of course, a development of ETW's work and something of an ME milestone.
Thread: Evolution of a 4 Tool Turret
06/10/2019 22:45:58
Posted by Graham Meek on 06/10/2019 20:35:12:
Yet these turrets worked faultlessly for many thousands of operations, maybe millions?
No wonder GHT called them "splendid"!
Thread: Any geologists out there?
06/10/2019 17:30:03
Posted by Robin Graham on 06/10/2019 00:51:30:
Last week I took a recuperative break in Lyme Regis. Well known for it's unusual geology of course. Wandering on the beach I came across stuff like this:
I forgot to put a ruler next to it, but for scale the biggest hole is about 15mm.The 'stone' is quite soft and may be compressed mud - but how were the holes formed? Googling has so far failed me.
Robin
Have they finished "stabilising" the town?
Thread: Saw doctor
06/10/2019 17:28:00
Axminster Power Tools sell some fancy dovetail saws and might help you.
I agree that it would be useful to know if any saw doctors survive. I used to sharpen and set my own but, like you, am not now confident of doing so.
I now tend to reach for a Japanese pull-saw whose blade can, of course, be replaced when blunt.
Edited By ega on 06/10/2019 17:28:25
06/10/2019 17:20:16
Thanks for the helpful photos of the advancing bracket. The GHT mods can be seen here:
and here:
He was perhaps a little hard on the Dore design and, justifiably, proud of his own precision boring head. Arnold Throp's idea was to produce a slide that could be made without milling facilities and the kit came with the bronze casting already screw-cut for the lathe spindle.
