Member postings for ega
Here is a list of all the postings ega has made in our forums. Click on a thread name to jump to the thread.
Thread: Quorn Tool and Cutter grinder
06/05/2023 11:04:28
My rocking lever is tapped 5/16" x 32 TPI as per DHC's book.
Can you elaborate?
Thread: Saving Money in the Workshop
06/05/2023 10:59:18
The leather on my mill came from my father's briefcase!
Thread: Chinese capstan mini-lathe
04/05/2023 22:42:49
Posted by noel shelley on 04/05/2023 14:10:07:
EGA, Coast Hopper to be precise ! Are you on its route ? Noel.
Sadly, no - just a lover of the big sky county.
04/05/2023 13:59:18
Posted by Hopper on 04/05/2023 12:21:52:...Been living up to my name and hopping around on one foot after a bit of minor surgery. Glad I did not sign up for anything major.
In North Norfolk, UK, the Hopper is the bus service that runs along the coast.
Thread: Small table saw
04/05/2023 13:55:53
The width of the wheels will be governed by the blade width but there is a potential complication: the crown will normally cause the band to ride in the middle of the tire but there is a school of thought which holds that the teeth should project.
My vintage 6" x 4" bandsaw wheels have a flange at the back and the blade rides directly on the flat cast iron wheels.
Thread: Manu , un petit Francais!
01/05/2023 14:29:50
Chef de cuisine - et chef de gare?
Thread: Vertex VTA13-3 tapping head
29/04/2023 16:40:56
My Vertex tapping chuck in operation:
I find it very useful.
Thread: Small Lathe T(r)ek - The Next Generation.
29/04/2023 14:38:11
Posted by JasonB on 29/04/2023 14:31:43:
Poolewood used to do wood lathes like that, think they have stopped doing them that way now
That is the one I had in mind; I wonder why the idea never caught on.
The lathe allowed a bowl to "embrace" the spindle nose end of the motor.
29/04/2023 14:23:37
Posted by Chuck Taper on 29/04/2023 12:42:03:
Whilst we are fantasising how about integrating the motor and spindle. Make the spindle the shaft of the motor. Yes loads of issues etc... but...
It would at least eliminate the current motor-belt-pully noise-vibration-irritation complex.
Regards.
Frank C.
I think that a woodworking lathe has been made this way.
Thread: Lathe cutting tool height
22/04/2023 11:26:42
Posted by Georgineer on 22/04/2023 11:11:11:...
It reminds me a bit of the endless discussions in cycling magazines about why there is a left-hand thread on the left-hand pedal (I think I've remembered it the correct way round) with all sorts of theories proposed, contradicted, refuted and argued over. The real answer is that our forebears found that if they used a right-hand thread, the pedal would unscrew itself and fall off.
And for the same reason you need a long spanner to remove either pedal which will have self-tightened in use.
20/04/2023 23:06:09
If you make your own bandsaw wheels it may be important to balance them.
I use the Evolution Rage saw blade for thin metals in both my portable circular and radial arm saws; in either case, the saw is mechanically guided but advanced, with great care, by hand; this is made possible by the chip-limiting form of the teeth.
Thread: My Ford Super 7 Countershaft Balance
19/04/2023 17:46:42
Is it possible, please, to correct the thread title so that it can more easily be found in future?
Thread: Infrastructure Engineering
10/04/2023 11:23:05
Is that the third or the first reichenwagen?
Thread: Myford Metric Lathe Leadscrew
10/04/2023 11:21:04
That lack of lube may have been due to the use of grease rather than oil.
Thread: ChatGPT incoming
10/04/2023 11:17:57
ChatGPT seems like a potentially useful tool.
I looked in vain on Wikipedia for the Cheltenham classification for library books but ChatGPT came up with an informative. albeit bland, "lecturette".
Thread: Fash?
31/03/2023 14:47:02
As I said, the "rough edge" meaning is old. OED gives various examples of its use accessed free, in my case, via my membership of the local library - worth a look if you can do the same or have your own subscription.
Thread: The secret life of components S3 By Tim Hunkin
31/03/2023 11:05:32
I think the OP meant it rather than "them".
TH is entertaining and informative.
Thread: Fash?
31/03/2023 11:01:29
OED has the old meaning of "A rough edge or ridge left on nails, cast bullets, etc. "
Thread: New guy from Norway, planning a Bonelle grinder
30/03/2023 11:29:02
Posted by Fulmen on 29/03/2023 21:05:32:
@ Richard Millington: Have you ever regretted the choice or felt that a cast iron base would have made any real difference?
The front bar, presumably of steel, slides in the base so that aluminium may not be ideal.
Thread: BBC photo series - Machinery
26/03/2023 15:02:37
Yes, it reminded me of an episode of Dad's Army when the platoon get in the harvest.
