Here is a list of all the postings ega has made in our forums. Click on a thread name to jump to the thread.
Thread: Help wanted in sourcing sewing machine motor capacitor |
03/10/2018 16:45:01 |
Brian Wood and Neil Wyatt: Many thanks for the instant replies. I had previously looked at both the RS and Farnell websites and had no joy. It may well be that a more savvy searcher would get a result. One problem is not knowing the function of the capacitor; normal motor capacitors are, of course, a good deal more bulky than the one in question. I did wonder about its precise function. My conclusion was based on the idea that these rather puny motors (60W in the present case) have to start under load. I will, however, as a temporary expedient, try to see whether the machine, including the speed control, will run without the capacitor. In the meantime, does any other knowledgeable member confirm Neil's suggestion? |
03/10/2018 16:09:20 |
After scanning the long list of topics I have opted for this one. I decided I should either scrap my old Jones VX561 domestic sewing machine or replace the motor, which appeared to have failed. However, dismantling the “three prong socket” into which the power lead is plugged revealed an apparently burnt out capacitor; the separately located motor seems itself to run OK when connected directly ie without the capacitor. I assume that the capacitor is either for starting and/or running the motor and nothing to do with the built-in machine light. The capacitor is marked "nichicon JAPAN" and is rated at 0.05 uF 250 VAC. Being situated inside the socket on the machine, it needs to be no larger than the existing at about 1" long by 1/2" diameter. I have tried in vain to locate a suitable replacement and am wondering whether the technology has moved on to the point where such capacitors are no longer available (my electrical knowledge is minimal). Can anyone suggest a source for a replacement, please? |
Thread: Super 7s and power cross feed |
26/09/2018 11:39:38 |
JohnF Glad to hear that your PCF S7 has served you so well. My own 60s non-PCF machine is on its second cross slide feedscrew and nut. I replaced both but I believe the thinking was that the relatively cheap die cast nuts could be changed without necessarily replacing the screw. |
Thread: Myford belts |
21/09/2018 12:07:36 |
Good advice on the lathes.co.uk website, in particular that some link belts may be difficult to move on and off the large sheave on the countershaft. |
Thread: A useful safety addition to the drill press |
30/08/2018 14:29:19 |
I bought my clamp rather than convert an existing one and found the standard ring nut slow and awkward to use. The problem was solved by making a quick nut; close inspection of the second picture will show the relief to the thread which allows instant tighteneing and loosening. |
Thread: Myford lathe headstock wick oiling ystem? |
26/03/2018 15:30:07 |
Posted by Martin Kyte on 26/03/2018 12:19:27:
You can replace the felt wick by removing the spindle. No idea why you would want to replace the spring, they don't really wear out. If you really must replace the spring you need to take the headstock off as can be see from Fig 27 here as you can see the bore for the spring is larger than the hole in the headstock bearing and the other end is underneath on the mating face with the bed. regards Martin This got my attention because although I recall replacing the felt wick when I re-built my S7 many years ago I could remember nothing about the spring and wondered whether I had inadvertently failed to replace it! However, I note from the manual that the spring is retained by a sealing plug beneath which is an O ring and my guess is that I left the spring, etc in place - commonsense suggests that the wick would have long since stopped working if the spring were absent. I agree that it seems unnecessary to renew the spring but as a matter of good practice the wick and O ring should no doubt be replaced when there is an opportunity to do so. Edited By ega on 26/03/2018 15:32:43 |
Thread: Drawing board v CAD |
25/03/2018 11:12:36 |
So far as I can see this is a genuinely new piece of software so it is understandable that it was written for current machines including, as it is cloud-based, mobile devices (this seems to imply that modern phones are 64 bit, too). Incidentally, there is a good deal of fascinating Autodesk history at fourmilab.ch but it predates Fusion. |
25/03/2018 10:19:42 |
As a Fusion 360 novice I should not be surprised to be corrected but I understand the current program is 64 bit only. |
Thread: Yet another what am I ! |
21/03/2018 15:54:24 |
Martin King 2: This looks very similar to my picture. Can you confirm that your tool has no maker's mark? I just wonder where Salaman got "Tectool" from. |
Thread: Shortening screws |
20/03/2018 12:51:55 |
Gordon W: Here is an alternative form which could be suitable for shop manufacture: The picture is from Ernest Joyce's Technique of Furniture Making. |
20/03/2018 12:26:11 |
Bob Lamb: Your second tool looks very like the "Tectool" shown in Salaman's Dictionary of Tools. The first part of the entry reads: "Tectool Fig 704 The trade name given to a modern grooving tool. Two narrow cutters are mounted on a stock and slope in opposite directions to suit the grain." Has anyone used one of these and is it "far less laborious"? |
20/03/2018 12:07:54 |
Gordon W: This is the sort of thing I had in mind: One for screws would no doubt be smaller and the cutting element HSS or, perhaps, TC. I prefer to perform this operation in the lathe using a suitable fixture but it is a time-consuming job. |
20/03/2018 11:46:43 |
Gordon W: There used to be a tool like the one you envisage for chamfering the ends of wooden dowels. I will try to find a picture. |
Thread: Myford Super 7 Lathe Instruction Manual |
07/03/2018 16:04:50 |
John Haine: You have reminded mo of one of my pet hates, namely, manuals which cover a range of machines. |
07/03/2018 14:11:02 |
I think it would pay new Myford to make all available manuals downloadable from their website. |
Thread: Fred Dibnah auction |
07/03/2018 12:21:40 |
colin wilkinson: Thanks for the link - my enjoyment was increased once I realised you can click twice on the rather murky photos to get a larger image. |
Thread: A recommended live center? |
05/03/2018 11:01:34 |
MichaelG: Thanks, as so often, for the definitive link. So far as I could see, however, the makers do not specify the type, etc of the "OEL" which should be used to lubricate. In the Centres PDF they say that most modern lathes are equipped with taper roller bearings (presumably, to the spindle). I know very little about modern machines and wonder how true the statement is today. |
05/03/2018 09:41:54 |
Gepy (Swiss) - good but expensive. |
Thread: New member |
04/03/2018 12:31:06 |
I believe the locals call Macclesfield "Macca" (not sure how they spell it). |
Thread: Help choosing a smartphone |
27/02/2018 18:15:16 |
Otley: Possibly too late to be of help but a point to bear in mind if you are getting an Android phone and plan to keep it for a year or so is that at some stage the manufacturer will stop providing Android updates. Google phones are sometimes recommended for the reason that the latest Android version will be available quickly but, of course, at some stage your hardware will not support the latest version. |
