Here is a list of all the postings Gone Away has made in our forums. Click on a thread name to jump to the thread.
Thread: Free Speech |
22/01/2013 01:15:20 |
For goodness sake guys can we please get back to model engineering discussions.
I don't see the point of this and similar statements. There are plenty of other ongoing threads on the site discussing model engineering. They didn't stop when this - additional - thread started (under "General Questions" ). So there isn't a question of "getting back". Anyone who is bothered by this particular thread can just ignore it and read those others. I'm sure many have. Nothing here impacts anyones ability to discuss "pure" model engineering in the appropriate forums. Edited By Sid Herbage on 22/01/2013 01:15:52 |
21/01/2013 18:32:06 |
Posted by Francis Sykes on 21/01/2013 17:47:46:
I think David should be given a break. 99% (okay, slight exaggeration) of the other forums in the world practice a no negative comments policy - legally there is room I believe for libel to be brought against the hosting site.
I would say gross exaggeration even among forums of this type and excluding Usenet. Many forums have a hands-off approach because of the perception that, as soon as the forum is moderated, the host thereby incurs some liability for what is said. Not to mention that a user who's post is removed might consider himself "damaged" by that removal in some circumstances. If the forum is clearly unmoderated and stated to be so, that responsibility lies with the poster. A grey area to be sure but murky enough for many to take a non-intervention stance. In the case of these forums, MHS's intervention/censorship history goes way back so they could not claim to be unmoderated and David might well have felt obliged to step in in this instance |
Thread: Milling Machines |
20/01/2013 01:55:25 |
Posted by NJH on 19/01/2013 11:39:59:
I don't recall any enquiiries about bog rolls though .............. do you have any recommendations in that area?
Get the widest and longest you can afford and/or have room for. Whatever you buy you'll find situations when you need it just that bit bigger. |
Thread: Which mag |
18/01/2013 23:16:05 |
Posted by wotsit on 18/01/2013 21:37:21: ME used to be published twice monthly earlier in its life, so now you are getting 1/4 of the content per magazine for a considerably greater cost. (I also did not renew subscriptions).
.... but it still is published twice a month (actually bi-weekly..... 26 times a year) But I agree MEW is a lot less interesting. I can still pick up one of the earlier copies and read it for days on end. These days .... well ... TWO interminable beginners series and a stepper-motor lathe series that's been going for a year and I can't believe that a significant proportion of subscribers is contemplating building it. Edited By Sid Herbage on 18/01/2013 23:20:19 |
16/01/2013 18:12:18 |
Posted by Terryd on 16/01/2013 09:53:00:
Both magazines are complimentary
..... it would be nice. |
15/01/2013 17:15:59 |
Posted by steve clark 2 on 15/01/2013 15:08:47:
By the way, I already have a dedicated pillar drill for drill bits/drilling. .... but one of the useful applications of a mill/drill is laying out an accurate pattern of holes using the x and Y movements. You will want to do some drilling on the mill. |
15/01/2013 14:31:23 |
Posted by steve clark 2 on 15/01/2013 12:30:01: The R8 is a type of collet yes? Again, is it the same situation with these? Which collet system is the best to go for? R8 is a mounting system for tooling in the mill (or other machine) spindle. It has a more obtuse taper then MT and therefore releases (much) more easily. It also has a keyway to prevent rotation. You can use R8 collets, and many people do, which will give you maximum height availability. Personally I use an ER (32 or 25) collet-holder in an R8 mounting. This loses a very little bit of height but gives you more diameter tolerance and is arguably quicker changing collets. Depending on just how small a machine you get, don't rule out using drill chucks. I have enough height to use a chuck in many cases and I have fitted some with 1/2" parallel arbors which slip into a collet very quickly. In any case you won't be able to conveniently hold a full range of drill bits in collets (especially R8 collets which have limited gripping range). |
15/01/2013 01:59:47 |
I'd give a lot of weight (pun?) to table size in your decision making. With these smaller machines, if you're using the mill for general purposes you will frequently find that the table or table-travel is just not quite big enough for the job you want to do. (Of course, the price goes up with table size). John (DMB) your choice of spindle is interesting. I agree with you as-written but a local vendor changed the spec on the small mill that I bought (after I had bought it) from MT2 up to MT3. When I asked why, they told me it was by popular demand because " there is more tooling available - to hobbyists - in MT3" . I disputed that and felt it was the other way round .... even in their own catalogue. The nice thing was, they also came up with an R8 conversion kit which I've much preferred to my MT2. |
Thread: Ad link broken? |
15/01/2013 01:41:56 |
Posted by Versaboss on 14/01/2013 23:36:59:
Just saw that the problem only exists when I choose 'open in new tab'. Same for me. When I open in new tab, Firefox simply opens the original window in the new tab. If I do the same in IE (which I don't habitually use), it opens the original window in a new tab plus the vendor's page in a new window. Bummer really because I typically open such links in a new tab by clicking on them with the middle mouse button - it's quite automatic now. |
Thread: Drilling Glass (was 'general questions') |
07/01/2013 01:10:41 |
Posted by Jeff Dayman on 07/01/2013 00:22:00:
Significant down pressure is used on the drills, over ten PSI at the drill tip I think
Are you sure that's the right number Jeff? I think we use considerably more than that in everyday drilling. According to my math (suspect at best these days) a 5mm hole has a cross-sectional area of about 0.03 sq.in. That would amount to an axial force of ~ 5 oz .... not a lot. According to Tubal Cain ("Drills Taps & Dies" ) typical axial load an a 3/16 drill drilling mild steel in a drill press would be ~50 lb Edited By Sid Herbage on 07/01/2013 01:11:24 |
Thread: DROs for an X2 |
01/01/2013 18:08:31 |
Ah, thanks guys - I didn't appreciate that. Edited By Sid Herbage on 01/01/2013 18:08:49 |
01/01/2013 17:29:52 |
Bob, am I right in thinking that, in the z-axis, you have a scale on the coarse feed but not the fine?
Thread: Stephensons Rocket |
31/12/2012 15:32:11 |
Not a "design" per se but there is a book, if you can find a copy, called "The Engineering and History of Rocket: a survey report" which is truly excellent and contains detailed drawings constructed from measurements made on the machine in the Science Museum. Plus a lot of background information. I feel sure you could construct a decent model of any of a number of the phases that Rocket went through during its development. Even my 8 year old great nephew, during a brief sortie away from his iPod, pronounced it "so kewl" ..... high praise indeed! Edit: I got mine from Camden, I think, but they don't seem to list it now so it may be out of print. Amazon UK list some "used, like new" copies starting at £12.45 with V2.80 shipping .... a real bargoon IMO Edited By Sid Herbage on 31/12/2012 15:38:37 |
Thread: Alibre 11.2 |
30/12/2012 19:14:18 |
Posted by Terryd on 29/12/2012 16:01:54:
I also believe that the licence is non transferrable - can you confirm that also. Of course this is not the case with free Open Source software.
What the EULA used to say in most cases was that the the licence (more often "license" ) could not be transferred without the express permission of the software supplier - not unreasonable since otherwise how would they keep up with who is the current licence holder? And generally they would readily agree if asked. I sold a spare Autocad licence that way and similarly obtained a Photoshop licence. It's probably to the software vendor's benefit to have a licence transferred (with potential income from subsequent upgrades) rather than have it languish. I haven't read a EULA in years (does anyone?) so I don't know what the actual wording is these days. In any event, if I had any licence to sell I'd certainly go back to the sofware source and ask. I remember Microsoft's first product offering (8-bit BASIC for the Altair on punched-tape) which came with the agreement that the user simply licenced the software rather than owning it (and moreover wasn't allowed to modify it except in certain limited areas **). Such an agreement was standard in business applications but caused an initial furour among home users. ** It was necessary to modify input/output coding in those days to suit the way your particular machine was configured. You were also allowed to make a new punched-tape copy with your changes. |
Thread: Bandsaw Choice |
29/12/2012 01:45:08 |
Well, Canada actually but close enough. I know you can get Starret blades in the UK and I know that they catalogue these so I assumed they'd be available but obviously you would know better than I. |
29/12/2012 00:49:50 |
Posted by Kevin Fenrich on 28/12/2012 23:37:45:
I think I may buy one and make a table like you and Sid have made ,could I be a real pain and ask if you have a link for the Milwaukee portaband blade ,thanks in advance Kev It's a standard blade size made by a number of manufacturers. Starret also makes one. They should be available at any decent supplier of bandsaw blades. Just be sure to throw out the crappy blade that comes with it (once you've used it to check out your installation) and fit a decent bi-metal blade. |
28/12/2012 21:41:18 |
Posted by Andyf on 28/12/2012 14:20:53: Like Sid, I made a stand, but attaching a pivot wasn't easy because when the thing positioned so the blade cuts vertically downward, none of the surfaces of the frame are vertical or horizontal.
(Just realised this thread has woken up again). I know where you're coming from, Andy - there are surfaces at all angles compiunded by the fact that when you lay the thing down on the bench it isn't in the attitude that it would be when cutting. I sweated it for a bit too in designing a mount but it'seasier than it looks. One of those angular surfaces was parallel to the blade (and therefore vertical in use) and that's the key. I simply bolted a piece of 1-1/2" or 2" x 1/2" bar to that surface. Since it's thin metal, I actually put a back-up piece inside, sandwiching the surface between the two. That takes care of mounting the saw and rest is just a couple of bearing-blocks from the hardware store and a piece of drill-rod or bar for a pivot shaft. Here's another view of mine that might make it clearer: |
Thread: Express Mag subscriptions |
04/12/2012 01:46:40 |
Glutton for punishment, eh Don? |
Thread: ML7 Lubrication |
28/11/2012 22:07:35 |
Posted by Robin teslar on 27/11/2012 18:00:57:
How did you gat the original spring ball oil tips out? Are they screwed in or a push fit. The flip top oilers sound entirely sensible. I had oil nipples exclusively on mine and they just unscrewed (2-BA thread). The oilers (eBay) had M6 threads which I turned down and threaded #10-32 UNF which is what I have here and is close enough. The Myford manual for the ML-7 (with exploded parts diagrams and parts list as well as lubrication info) is kicking around the internet as a pdf in various places if you don't already have a copy. The relevant Yahoo group(s) used to have it. PM me if you have any problem. |
27/11/2012 16:54:11 |
I picked up on that when you mentioned it some time ago David and it always worked well for me with a scrap of soft kitchen towel ..... thanks. Based on another thread, I've recently replaced what nipples I can with regular, brass flip-top oilers which has simplified things enormously. |
