Here is a list of all the postings Funnyturn has made in our forums. Click on a thread name to jump to the thread.
Thread: MT2 collet slipping |
07/02/2011 09:48:38 |
Can you clarify whether slippage is at the MT2 taper or is it the end mill slipping in the collet? |
Thread: help with seeing |
08/09/2010 17:59:28 |
You could look at: https://www.glassesuk.co.uk/acatalog/index.html They do prescription safety specs: single vision, bifocal and varifocal I have a pair with plain lens and flip down close lens which works well, giving full field a view. Down side they are a bit heavy and top heavy with lens flipped up! Makes one feel ones age.... |
Thread: Small Arms models |
01/09/2010 16:02:34 |
Amazing to think that 50+ years ago one of the workshop projects at prep school was to make and fire a miniature canon(bout 6'' long). Now we hardly dare speak of such things... |
Thread: Prescription Safety Specs |
26/01/2010 10:06:19 |
I bought some from http://www.safetyspecs.co.uk. Great advantage for me was a pair that have plain lenses and a flip up/down reading lens. Work really well as long as you do not need long lenses aswell. Only drawback is increased weight on the nose(like clip on sunglasses)and cost at about £80. Brian |
Thread: bonded crankshaft |
17/01/2010 16:10:30 |
Using a large font is not shouting, but using capital letters/upper case is. Entries are much more readable if typed in upper and lower case, a space is added after a full stop and an extra line added between paragraphs. Good old fashioned punctuation is nice aswell! Brian |
Thread: Workshop Heating |
15/01/2010 11:27:47 |
There is an anti corrosion product caled ACF-50 which many motorcyclists etc swear by. See: www.acf-50.co.uk/ It is available on ebay at around £14. Brian |
07/01/2010 14:28:15 |
I use a portable gas heater in my garage workshop - just have it on while i'm playing and have had no problem with condensation/rust. I assume the air volume is relevant, also a large metal garage door makes a good 'condenser' and I assume sweats first! Also this heater only provides local, mainly radiant, heat and probably has little effect on overall garage temperature. Brian |
Thread: Rear mounting parting-off tools |
12/10/2009 14:02:10 |
If you put lathe in reverse and turn parting tool the other way up, does this have the same effect as rear mounting? Seems the geometry would be the same! Brian |
Thread: Milling collet arbor jammed in milling machine |
22/09/2009 10:47:05 |
Does that explain the' physicists' behind David (amongst others)!! Brian |
17/09/2009 17:36:58 |
Right or wrong, should I (lightly) oil/grease the taper before fitting? As a newbie I thought this a 'good idea'... Brian |
Thread: Subscription number going AWOL? |
29/08/2009 20:06:11 |
Same here! Have to 'save' every time! Brian |
Thread: Movable lathe |
23/08/2009 20:44:25 |
Many thanks for suggestions. Plenty of ideas, but wil keep it fixed for time being... Brian |
20/08/2009 20:46:10 |
I am rearranging my workshop(new mill coming so space has to be 'created'). I would like to be able to position my lathe in such a way that it can be easily moved out of the way should the need arise(it's a garage workshop and other 'machinery' needs access at different times. The lathe - a Chester Comet - is on its own stand and could be mounted on castors, but I feel this would lead to stability problems and so on...What I need is some sort of wheel arrangement that could be screwed down to the floor when needed and then retracted. Anyone have any suggestions? I doubt it is a unique problem! Brian |
Thread: Engineering Course at Eastleigh College, Hampshire |
13/08/2009 16:26:55 |
If only I wasn't in N.Yorkshire.... Anyone know if Redcar & Cleveland are running courses again? Brian |
Thread: Beginners' projects |
31/07/2009 22:58:57 |
Dave Many thanks. I have this book and will take the plunge soon! In fact I see this series of articles has just begun in latest issue of ME - must have missed it when I had a brouse! Brian |
29/07/2009 14:30:17 |
Where will I find this series? Is it on the website or in one of the mags? I have a 10V kit and would welcome the guidance... Brian |
Thread: Lathe height? |
02/07/2009 17:59:51 |
Having recently aquired a Chester Comet with reccommended stand, I am surprised to find the working height of the lathe is only 1metre(spindle height).
This seems a little low to me(I am 5'7'').
Are there any reccommendations for the correct height?
Brian |
Thread: Nuts and bolts |
23/05/2009 09:52:25 |
Many thanks! Emkay are just what I need. |
21/05/2009 15:19:42 |
Can anyone suggest a good online supplier of nuts and bolts. I often seem to need just a few of one size and don't want to buy in quantity.
www.ebolt.co.uk are good for stainless. I need someone similar for HT etc!
Thread: Material Suppliers |
20/05/2009 23:31:42 |
If you want to buy online I can recommend:
http://www.nogginend.com/
Prompt and friendly service. |
