Here is a list of all the postings Circlip has made in our forums. Click on a thread name to jump to the thread.
Thread: Flash Steam Hydroplanes |
17/11/2009 14:19:27 |
Sorry Windy, had to post this:- http://www.ffscale.co.uk/page4d.htm for Niloch.
Regards Ian
PS., chuck "Jetex" into the Bing box. |
17/11/2009 12:19:29 |
Well I'll raise your Veron to a "Sea Hornet" with a POS ED Hornet and an "Adamcraft Seaplane Tender" with an ED Racer.
![]() Regards Ian. |
Thread: Beginners start here in Model Engineer |
17/11/2009 12:15:23 |
And don't forget "Handmaiden" built Bart either.
Regards Ian. |
Thread: Metric vs Imperial - Practical or Traditional? |
17/11/2009 08:34:14 |
Sorry to disagree Bowber but decimals with everything gives some the problem of trying to chase "Thous" that aren't neccessary in lots of cases. 1.000" ?? instead of 1" bar or plate? It's one of the ills of the cad programmes (programs) if the "designer" isn't conversant with the engineering required and sadly with the advent of cheap drawing programmes EVERYONE and their dogs are DESIGNERS.
"Six munce ago I cutent even spell ingineer an now I are one"
Regards Ian. |
Thread: new project |
15/11/2009 16:25:25 |
ANOTHER Tuit Roy
![]() Regards Ian |
15/11/2009 15:18:59 |
Try these Patrick :- www.cauzzi.it/ftp/Oldboatguys_Engine_Plans.pdf
Regards Ian. |
Thread: Taper cutting |
15/11/2009 10:42:31 |
MT 4 Taper Ian S C ?? The ball ended centres can have a barn dance on that one.
Regards Ian. |
Thread: Cutting male threads |
15/11/2009 10:40:46 |
DON'T belittle yerself Dunc, you'll get about a dozen answers and then you can pick which works for YOU.
Many roads to Rome an all that.
Regards Ian. |
Thread: Small Drills |
15/11/2009 10:37:31 |
" the stone must be in god shape "
Hopeing for "Divine" intervention Jim?????
![]() Sorry, couldn't resist.
Regards Ian. |
Thread: Taper screw |
14/11/2009 11:18:34 |
Use Tailstock offset method for tapering and screwcut as normal. Use Ball end centres.
Regards Ian. |
Thread: Which screw thread system to use? |
14/11/2009 08:51:27 |
Most of the screw sizes can be changed for Metric, and if you make your own bolts and nuts, the BA flat size Hex material can be used.
HOWEVER, when it comes to adjustable items, Valve rods etc., it could be prefferable to use BA threads.
Regards Ian |
Thread: Painting a Restored Machine |
14/11/2009 08:44:41 |
Just as a heads up V8., Water soluble Suds is pretty effective at dulling and dissolving the original Hammerite, don't know what it's like on the American userper.
Regards Ian. Edited By Circlip on 14/11/2009 08:44:58 |
Thread: Safety |
12/11/2009 11:14:45 |
Starting a new topic for this one, as, looking on another Forum the other day, it was suggested that a certain material was far more suitable for a given application than the norm in Toy sizes. What the poster ommited to mention, possibly due to ignorance of the material involved is that it is highly toxic and a LITTLE care is required in its use.
One of the problems with todays education system is that the "I've got some spare time/cash so i'll have a go at that" brigade have never or will, learn about the pitfalls of some methods and materials without some old fart giving them the Heads Up.
Seen what happens to PTFE when you burn it ????
First don't SMOKE over the vapours, - you can DIE.
Second, don't touch the black sludge, it's called HydroFlouric Acid, (Look that one up for Yerselves.)
Oiled brown paper over the slides? Good idea, especially when you're machining Titanium - NOT. And Titanium is being used more extensively nowadays for Toys - cos it's available. Have a read at the FLAMABILITY warnings, makes Magnesium almost safe. I read that another well respected old Fart has a large metal Baking tray clamped between his milling table and the vise, THAT stops turnings falling into the slots, easy to clean too.
After having to ensure that ones workforce didn't hurt themselves (Or the equipment they used, or THEIR workmates) in industry, whilst NOT trying to be a Galactic Guardian on safety, it is rather annoying when some glib gobby twits seem to regard it as second nature to everyone and scoff at attempts to EDUCATE those without the experiance of an engineering career to SOME of the pitfalls.
Capt. Mainwaring and Cpl. Jones may find it amusing, but Fraser finds it sad.
Regards Ian. |
Thread: O-ring coming off pulley when motor power is cut |
12/11/2009 10:24:18 |
If you see the principle Maff you could easily make a single rollered version.
Regards Ian. |
12/11/2009 07:27:15 |
Check yer P/M Geoff. |
11/11/2009 19:54:57 |
You dissin the well good bro's?? Innit |
Thread: Coverage of comments |
07/11/2009 14:41:26 |
Earwig o again, the adverts overlapping the comments on the compressed(Sic) air thread, You really should get the webmasters to sort this one out David.
Regards Ian. |
Thread: Compressed air on lathe |
07/11/2009 10:45:56 |
Need to be careful with a vac David, spray swarf like Brass is ideal for letting the magic smoke out of electrics.
You COULD always try this :- http://www.cgallery.com/jpthien/cy.htm
Oh Bu**er, sumat else to make.
Regards Ian.
OOOPS, forgot the baby version :- here
Edited By Circlip on 07/11/2009 10:51:21 Edited By David Clark 1 on 07/11/2009 17:58:29 |
06/11/2009 11:40:27 |
Some of the "Re-invented" technology uses a combination of compressed air and atomised cutting fluid fed to the cutter/workpiece interface for "Mist" spray cooling.
Thought to be the best thing since sliced by some, "Duplex" did an article on it in 1957. Sadly only have pages 1,2 and 5 of it. (Hint David and s*d the subscription
![]() ![]() Regards Ian. Edited By Circlip on 06/11/2009 11:40:51 |
Thread: Overheating grinder |
06/11/2009 11:28:13 |
By ell Peter lad, tha deserves Yorkshires highest award, FC and Bar, (Frugality Cross).
As tha tried resharpenin t files by pickling em?? Aye, an keep thi powder dry, dowant tell em abart usint files fo cutters, fytin thi way tert front on car buwit sales is bad enuff bart damn kids gerrin under foot.
They mek damn good wood chisels anorl. Brok one of me Grandads that i left me, by ell, a did weep, saved bits tho.
Keep upt good work lad, best wishes fromt reyt side oft Pennines.
Regards Ian. |
