Member postings for Russell Eberhardt
Here is a list of all the postings Russell Eberhardt has made in our forums. Click on a thread name to jump to the thread.
Thread: Boiler water
25/04/2012 21:10:17
If you capture rain water and use that you'll have no further issues, as this is true pure ( slightly acidic often) water. Mind you filter it as bugs love to grow in it, before you fill your tank.
Or collect the water from a dehumidifier. You'll need one in the workshop given the current "drught" conditionslaugh
Russell.
Thread: magnetic base's
25/04/2012 09:28:14
Posted by Stub Mandrel on 24/04/2012 20:08:56:
"He who destroys a thing fto find out how it works has surely left the path of wisdom".
I started to dismantle things to see how they worked when I was about six and haven't stopped in the last sixty years. Most things have worked again after reassembly smiley
Russell.
Thread: Why are flywheel keys square?
25/04/2012 09:23:38
Posted by Stub Mandrel on 24/04/2012 20:20:33:
For small bores (say 1/4" to 5/32" I use a 'top hat' shaped filing guide with a slot in it and a square file.
That must be a tiny file. What size key do you use on a 5/32 shaft!
Russell.
24/04/2012 17:28:29
John S is right of course, however I have used round keys with a bit of locktite to overcome the tendency to roll and never had a problem. If you can drill both the wheel and the axle with it assembled you can get a good fit easily.
Russell.
Thread: Threads
22/04/2012 19:24:49
They said it was aluminium but I expect they use some exotic alloy, but clearly not exotic enough!
Russell.
22/04/2012 15:58:25
If you don't mind spending the cash I'm afraid I wouldn't know what "the very best" magnetic devices would be made from
edit: would actually be interested to know the answer to that one
It depends entirely on your application.
Years ago I used to use "MuMetal" (an 80% nickel alloy) for magnetic screening of cathode ray tubes as it has a very high permiability (about 100,000).
For mains transformers, grain oriented silicon steel as it has a high operating flux density
Ferrite for high frequency devices.
Etc.
Russell.
Thread: Expert projects
21/04/2012 20:53:27
That certainly looks challenging! Bon chance!
Russell.
Thread: 55 degrees or 60 degrees
21/04/2012 12:50:14
Posted by Gordon W on 20/04/2012 11:26:52:
I've still got some bits left over from my M1000 days, a spanner for head bolts 19/32" AF from memory.
More likely 5/16 W.W.
Russell.
20/04/2012 10:14:27
The old Moggies sure had a different thread but my father in law, who spent a lifetime in the motor trade always told me that Morris, and for that matter Wolseley, nuts and bolts were 1tpi out to British standards in order to boost parts sales.
No. It goes back to the early days of the Bullnose Morris. Morris made the early engines for these cars under licence from the French Hodgekis (sp. ?) company and they had French Automobile threads throughout. The chassis used the standard practise at the time of using Whitworth threads so, as garages at the time would only have W.W. spanners they decided to use these metric threads but with W.W. head sizes.
The practise continued for some time.
Russell.
19/04/2012 21:30:19
I find it amusing that pipe fittings here in France are specified by the (approximate) diameter of the thread, e.g., 12mm, 20mm, 26mm. But they are really BSP threads with a 55 deg. angle. A case of the British beating the French but the French not admitting itlaugh
I once owned a vintage Morris car. The engine used French Automobile thread (metric) but nuts and bolt heads were to Whitworth sizes!
Russell.
Thread: John Parslow skeleton clock
19/04/2012 21:10:12
Thanks for the suggestions regarding pivot polishing. The finest wet and dry I have been able to get is 1000 grit. I have some rouge powder, it is recommended for non ferous metals but I will give it a try.
Micromesh looks interesting although the website is a bit confusing. They show a micrograph of 400 grit "sandpaper" beside 1500 grit Micromesh and the Micromesh looks rougher to me! However I see it is recommended for refinishing acrylic windows so I might be able to find something similar in one of the nearby boat chandlers.
I see M & P (who have an outlet in France) sell "Diamantine " powder for polishing steel in medium and fine grades - anyone tried this?
I can see some experimenting coming on. I'll try making a burnisher as Martin suggests and try various polishing mediums and see what gives the best finish.
Russell
Thread: Carbide Tip Sises
19/04/2012 13:31:35
You can find an explanation of the coding system for sizes here: http://www.ccpa.org/pdf/B212_4.pdf
Russell.
19/04/2012 13:19:31
Nice one Harold. You always come up with good ideas.
My mill has X stops but no Y stops. Having seen this I must fit something similar.
Russell.
19/04/2012 09:19:56
Posted by Springbok on 19/04/2012 04:53:23:Wish I could cut gears like that looking at your pic's lovely work and must take a lot of patience.
It's not cutting the gear teeth that takes the patience. It's the crossing out!  Done by hand - no cnc (yet).
Russell.
Edited By Russell Eberhardt on 19/04/2012 09:20:59
18/04/2012 20:18:31
I've made a bit more progress. Wheels and pinions now cut. Will start on the arbors tomorrow. Don't have a pivot file so I will polish after turning with 1000 grade wet and dry and hope that is good enough (any thoughts?).
I have put a few photos in an album here to show progress.
Russell.
Thread: Cracks in mill-to-lathe attachment Hobbymat MD65/BFE65
18/04/2012 11:18:46
Just make sure you don't overtighten the new one smiley
Russell.
17/04/2012 16:36:19
I'd make a replacement one in steel to give it a bit more strength. I presume that it is attached to the lathe by bolts through the two holes on the left. If that is the case the damage was almost certainly done by over tightening the bolts.
You should be able to set the block up in the four-jaw chuck to face it and bore all the holes.
Russell.
O.K. just seen your second post, not quite so straightforward.  How about making a thick steel plate so that the broken part is sadwiched between the lathe bed and the plate?
Edited By Russell Eberhardt on 17/04/2012 16:42:28
Thread: Mazak castings
14/04/2012 17:03:22
Posted by mike T on 14/04/2012 00:16:30:
The problem seems to be that Zinc alloy casting is another skill that has been lost in Great Britain
This is not really true. There are die casting companies all over the place using both aluminium and zinc alloys. Do a Google search for "zinc die casting" in your area. You may well be able to scrounge some scrap castings.
Russell.
Thread: mercury or quicksilver........Barometer?
11/04/2012 16:52:28
Posted by Swarf, Mostly! on 11/04/2012 10:10:29:
As regards barometer manufacturers - there was an EU edict last year that outlawed mercurial barometers.
What has actually been owtlawed is the sale of new mercury barometers and thermometers to the general public. It is legal to make one for your own use or for sale to the trade. The repair and sale of antique instruments is not restricted. Hence the easy availability of mercury.
Russell.
11/04/2012 09:38:45
Don't take it to a waste disposal centre. It is quite valuable. Mercury can be readily obtained from clockmaking suppliers and currently costs about £200/kilogram.
As has been said, it is not particularly dangerous in its liquid state. Just don't heat it and keep it in an airtight container. Be careful not to leave spilled mercury lying around as it can gradually release vapours.
Russell
