Member postings for Russell Eberhardt
Here is a list of all the postings Russell Eberhardt has made in our forums. Click on a thread name to jump to the thread.
Thread: 3D CAD for Linux
16/12/2012 17:08:54
You could have a look at FreeCAD, it's written in Python so works on Linux, Windows and Mac. Haven't tried it myself I run Autocad in Virtualbox on my Linux computer Autocad is available free to students and retired engineers.
Russell
Thread: Chinese Lathe Accessories.
16/12/2012 11:24:18
Posted by Raymond Anderson on 16/12/2012 11:09:42:I have seen the equiptment at his place of work and it is all High end gear DMG , Mori Seiki WFL Millturn ,and guess what? NO
Perhaps this is one of the reasons for the UK being uncompetitivelaugh
Russell
14/12/2012 09:53:27
Posted by Lambton on 14/12/2012 09:13:17:
Myford which after all is only a development of a 1947 machine aimed mainly at the amateur and educational market.
Which, in turn was based largely on the 1930's Atlas lathe.
Russell.
Thread: workshop heating
14/12/2012 09:34:01
Don't know if you are anywhere near a ferry port but if so one of these might be worth the trip.
Brico_Depot
Russell.
Thread: Text formatting in posts
11/12/2012 16:01:11
Posted by Stuart Chesher on 07/12/2012 16:29:06:
Thank you Russell for pointing out that it works OK on your Win 8 / IE10 machine - theres hope for this old bloke yet. ATB Stuart
You'r welcome.... but it wasn't me. It works fine here on Linux/Firefox and with XP/IE6.
Russell
Thread: shot blasting
09/12/2012 21:37:31
Posted by Phil P on 09/12/2012 16:09:59:
Please stop using sand and get some proper blast media.
http://www.silicosis-injury-attorneys.com/pages/sandblasting_risks.html
I work for a company that makes these machines, so I do know........ stop using sand !!!!!!!
This isn't a problem when using wet sandblasting with a pressure washer.
Russell.
09/12/2012 21:33:10
Posted by SLOTDRILLER on 09/12/2012 20:23:59:
I was thinking of using a small reverse cycle air conditioner as they pull moisture out of the air and can heat as well as cool .
I use one here to heat the whole house. They are very effective and about 300% efficient (3 kW heat from 1 kW electricity); However the efficiency does drop off fairly quickly below about -5 deg. _ not a problem here.
Russell.
07/12/2012 13:02:09
The answer is not to use Windows 8. On the rare occasions I have to use Windows I stick to XP, it does't have all the bloatware!
Russell
Thread: Offline copies
30/11/2012 15:20:55
Can't you create the pdf file on a computer then copy it to your iPad?
Russell.
Thread: Myford Gearbox and Metric/BA
30/11/2012 13:28:03
Have a look at the links on this page.
Russell
Thread: Flood Preparation
26/11/2012 21:35:57
Bon chance Neil
Russell
Thread: Meccano Gears
20/11/2012 20:59:01
The Meccano gears are an odd DP so that combinations can be made to mesh at multiples of 1/2".
As stated above most gears are 38 DP but there are also some 16 DP abd 20 DP. See here
Russell
Thread: Laser Cut Flywheels
17/11/2012 10:58:56
How does the cost compare to casting?
Russell
Thread: Advertising banners
17/11/2012 10:53:21
Posted by Michael Gilligan on 17/11/2012 08:17:42:in IE, press "F12"
in Firefox there is, I believe, something rather clever.
Right click on the page and select "View Page Source"
Russell
Thread: Who does the best catalogue???
17/11/2012 10:45:46
Depends what you want; tools, materials, castings, kits? For a start have a look at the adverts in the digital editions of M.E.
Anything specific you can't find - ask here.
Russell.
Thread: myford ML7 - choice of motor
16/11/2012 20:47:34
Go for it. You have nothing to loose. It won't damage your inverter and you can easily change the motor later if you find the lack of power to be a problem. I would buy an inverter capable of driving a 1/2 hp motor though - just in case.
Russell.
16/11/2012 11:13:45
Posted by davethomas on 15/11/2012 19:59:06:
Now morre questions! It would seem that if this motor is healthy then it should run with an inverter drive, but underpower by about 40%,.So, as its slightly bigger than the minimum recommended motor for an ML7, is it reasonable to assume if I can get it to work it may do the job?
If you run a 1/2 hp 230 V motor it will be capable of supplying 1/2 hp at normal speed, not 40% less. However at reduced speed, as Andrew has pointed out, the torque will remain the same so the power is reduced more or less in proportion to the speed reduction. It's not quite that simple but a good enough approximation.
The rated power of a motor is for continuous operation. For the sort of intermittent use it is likely to be subjected to on a home lathe you can squeeze more power out for short periods. The limiting factor is the heating.
Modern motors can run at higher temperatures due to improved insulation materials so can be made smaller fpr a given power. I replaced the old 1/2 hp motor on my lathe (a bit bigger than Myford) with a 3/4 hp 3 ph motor as it had the same frame size. It is more than adequate and has never got too hot. However, you will still need the belt changes for heavy low speed cuts.
Russell
Thread: Sieg X2
16/11/2012 10:57:56
Unless you are using the mill as a bench drill as well the spring, whether gas or the original, is a waste of time. I just removed it for my CNC conversion.
Russell.
15/11/2012 16:14:35
Posted by davethomas on 14/11/2012 23:39:21:
( I'm still a bit unsure about this 3phase 230v business, but I'll just ride with it for now).
230 V delta puts the same voltage across each winding as 420 V star.
Sorry, not familiar with 2 speed motors. Personally I'd go for a new motor. Have a look at Marelli motors on this site.
Russell.
Thread: Lathe tool insert bits
14/11/2012 20:02:26
Yes, blue steel chips from Carbide are great, unless you are moving the carriage by hand, then your wife/husband wonders what disease you have because your hands and arms are covered
Yes, so why do so many lathes have the handwheel at the left hand end of the apron?sad
Russell.
