Member postings for Ken Strauss
Here is a list of all the postings Ken Strauss has made in our forums. Click on a thread name to jump to the thread.
Thread: Set Screws on TTS Gauge Holders
15/04/2021 03:04:34
The default on Tormach's PathPilot is for the spindle nose to be considered Tool 0 and all tool table offsets are relative to the nose. This has the nice bonus of being able to measure tool lengths with a surface plate and height gauge if you don't have an ETS. For what it is worth my Haimer is tool 98 since Tormach assumes that an electronic probe is tool 99 for their inbuilt probing routines.
A hint about your Haimer: the concentricity adjustment uses 4 setscrews which are M4 as I recall. These are somewhat delicate in the internal hex recess so I replace them with M4 SHCS which are much more robust. The original setscrews didn't have them but adding brass tips to the adjustment screws seems a good idea.
Thread: Learning CAD with Alibre Atom3D
19/11/2018 14:02:45
If you prefer to have both windows full screen you can press Alt-Tab to swap which is on top.
18/11/2018 15:46:24
So far so good but has anyone tried Atom3d in conjunction with a CAM package? There doesn't seem to be a .dxf export and .stl is not really appropriate. The Mecsoft CAM costs from than Atom3d!
Thread: Marlco Thread Measuring Parallels
04/07/2018 18:37:50
Thanks for having solved my Marico usage question. For added points, is there a similarly clever tool to accurately gauge internal threads (not plug gauges)?
04/07/2018 15:38:45
The patent number for the Marlco thread gauge tool is 555830 and was patented in 1941. This patent is available online at https://worldwide.espacenet.com/publicationDetails/biblio?II=9&ND=3&adjacent=true&locale=en_EP&FT=D&date=19430909&CC=GB&NR=555830A&KC=A
04/07/2018 13:37:40
So the pitch diameter is simply Y-X? Thanks!
04/07/2018 03:55:38
I have a set of Marlco thread measuring parallels (US sizes) but no manual. There was a posting years ago (https://www.model-engineer.co.uk/forums/postings.asp?th=49467) that included a link to the manual but that site is no longer active. Where can I find it now?
Thread: flip up toolholder
15/07/2011 03:11:22
I'm curious about the German design that you mentioned. Any links to an advert or other details?
