Member postings for modeng2000
Here is a list of all the postings modeng2000 has made in our forums. Click on a thread name to jump to the thread.
Thread: A Quiet Air Compressor?
05/02/2021 20:41:07
Dental air compressors are generally very quiet
The compressor where I go would not seem out of place in a garage surprise
Edited By modeng2000 on 05/02/2021 20:42:37
Thread: Gmail virus?
05/02/2021 14:41:19
My account is ok as well.
Thread: cateracts.
25/12/2020 19:55:51
I would like to add that I only wish I had had mine done earlier.
The improvement is really dramatic, finding out the true colours of things again was a bit of a revelation.
I had both mine done at the same time. This had two benefits, lower cost and reduced hospital visits.
It has taken around two and a half months for things to really settle. Now my optician says I don't need specs for driving anymore so that is a bonus.
Thread: What am I?
27/11/2020 13:33:34
Fred's presence here is to show that a person can be respected for their skills just as much as someone with qualifications. Media personality or not, I would like to see another of his equal.
Thread: Jim Cox's books on Electric Motors
10/11/2020 15:40:12
Richard,
I guess I'm showing my age but yes I do remember the triplers.
what about the 25kv eht shunt regulator triode in it's x-ray shield.
Thread: LED Constant Current Source Scheme
10/11/2020 15:17:06
Didn't know about the AL5808, thanks.
10/11/2020 12:21:31
Television cathode ray tubes behave the same way. The capacitor is the aquadag coating with a glass dielectric.
Could be a bit awkward if you get a shock while carrying the tube!
Thread: Converted Computer Fan + Steam Engine = Electricity
05/11/2020 07:45:27
I can only see 8 bulbs?
Thread: cateracts.
01/10/2020 13:40:06
Just an update re my surgery that happened yesterday.
The ability to see has improved remarkably. The decision to have both eyes done at the same time was the right thing to do for me. There was no discomfort at all and I had a running commentary as the operationn progressed.
Colour vision has changed back to how it used to be. I don't need help for distance now and what astigmatism I had seems to have improved as well. The down side is that I do need specs for close-up work but this was expected.
25/09/2020 16:07:12
I have found this thread very interesting. I have one eye worse than the other but as both will need attention at some time the consultant suggested having them both done at the same time.His reasoning was reduced exposure to the hospital environment in view of the covid situation. I have opted for distance vision as this seems to be the best compromise.
Thread: The Workshop Progress Thread 2020
20/09/2020 08:22:07
With camoflage like that you'll never find the workshop again. crying
Thread: Reminiscences
19/09/2020 17:59:47
My best tram memory was when a tram came into Wimbledon terminus at some speed with part of the rear platform on fire. The conductor poured sand over the flames and all was well.
Thread: A new [to me ] style of scam eMail
16/09/2020 07:01:18
I have had the charging area one as well.
Thread: Ian S C message
25/08/2020 11:02:41
Ian, you have a PM.
Thread: Sensor
19/08/2020 20:13:22
I have used one similar to the PestBye available on Amazon. A bit cheaper than when I got mine some years ago.
Thread: Adept and Wizard lathes
19/08/2020 16:25:29
Ok Rod, many thanks. The spindle looks well made with no wear so it was a guess as to its hardness. I have tried the spindle with a file now and it is not hardened.
The background to this question is that I have been given both a Wizard and a Super Adept. The Wizare is in good condition together with most accessories. Not so the Adept but it might not be beyond restoring.
19/08/2020 15:05:55
Can someone let me know the considered upper spindle speed for these small lathes please? The headstock bearings are plain cast iron with a hardened shaft (or so I believe)..
Edited By modeng2000 on 19/08/2020 15:06:10
Thread: By Crook or by Fluke
12/08/2020 13:45:49
Stuart, i understand the difference now.
Robert, Thanks for the info about cleaning the zebra strip and contacts. I have IPA and so when things cool down I'll try to sort out the problem.
11/08/2020 20:21:50
Stuart,
I have a fluke multimeter and my display has some segmente dimmed seemingly caused by the zebra strip connectors. Were you having this problem?
Thanks for the weblink
Thread: Silver soldering a Minnie traction engine boiler
09/08/2020 17:07:49
There is an interesting article on joint testing called 'Joint Design Tests Subminiature Boilers AWS' that an internet search should find..
